Question about Linksys Wireless-N WRT150N Router
Mu WRT150N Router appears to have stopped working. If I hook the modem direct to the laptop it works. If I put the router inbetween with the same direct connection, no internet. I have tried several cables between the router and modem, but no change. Any suggestions??
    Novelist:
  • 94 Answers
When connecting the devices make sure that you turn on the device in this manner: modem (wait for the lights to be solid) then router, then the computer.
Check if you can get online, if not then follow the steps below:
1. Open a web browser and type this in the address bar: 192.168.1.1
2. Then you will be in the setup page of the router. You need to know what is your connection type obtained from your ISP.
If DHCP, internet connection type should be: Automatic Configuration - DHCP should be selected.
If PPPoE, select PPPoE and type the username and password provided by your ISP.
3. Then save the changes.
Once that the internet connection is working from the PC hardwired connected to the router, then check the wireless settings under the wireless tab. Take note of the SSID, wide channel, and the wireless security and preshared key.
Put those settings on the wireless adapter of the laptop and you should be able to get online.
I hope this works! Good luck!
Posted on Dec 15, 2009
  • Linksys Master
  • 32,281 Answers
Are any of the LED lights switched on in the router when it is powered up?
If not check the power adapter plug with a multi-meter, the output voltage should be slightly higher than the voltage that is printed on the label on the bottom of the adapter.
If the voltage is zero or very low then the power adapter is faulty and needs to be replaced.
Posted on Dec 13, 2009
SOURCE:
I have a phone modem ( arris emta) , my internet was disconnected and i had to reregister to get back on line by unplugging the ethernet cable from my router straight to the modem in order for my computer...
Make sure that your computer is able to go online directly through the modem.
If your computer is able to go online through the modem, that means the modem is working fine.
You will need to connect the computer to the router and the modem to the router.
open the set up page of the router and change the settings of the router according to the ISP.
Click Here for more information about the routers and network
Oct 02, 2010 | Linksys WRT150N Wireless N Router -...
I have a wrt150n wireless is not working
Jul 03, 2010 | Linksys Wireless-N WRT150N Router
Not worker right?
Apr 30, 2010 | Linksys Wireless-N WRT150N Router
My internet works fine when i hook it up directly from the modem, but when i try to use the router it says no internet connection. cables all work fine. My lights are all lit like they are suppose to be.
Are you trying to install the router.
You can do it manually without the CD.
Make sure that your computer is able to go online through the modem.
Then you need to connect the computer to the router and the modem to the router.
Click Here for step by step by instructions
Jan 15, 2010 | Linksys Wireless-N WRT150N Router
My linksys WRT150N router won't recieve internet signal from my dsl modem. The router sends out a signal to my lap top, but no internet connection can be made.
Try connecting your laptop directly to the dsl modem to make sure that it is working correctly.
If the dsl modem is working correctly then:
1. Turn off the power on the router and dsl modem.
2. After about 2 minutes, turn on the dsl modem.
3. Wait another 2 minutes, then turn on the router.
Occasionally you need to do this to get them back in synch. If this doesn't work you may need to use the software utility to reconfigure the router.
Dec 27, 2009 | Linksys Wireless-N WRT150N Router
Linksys WRT150N router disappearing from PC
If you aren't able to access the router even using the hard wired connection, there seems to be a problem. Resetting won't work. You must hard reset the router. And here are the steps.
1. Push the reset button and hold it for a minute
2. While you are holding the reset button pull out the power cable every 10 second and put it back in right away. So in a minute you would be doing it 4-5 times
Try this a couple of times and if this still doesn't work, its time for getting your router replaced from linksys.
regards
Sandeep
Oct 13, 2009 | Linksys Wireless-N WRT150N Router
Cannot access internet with a linksys router
Make sure DHCP is turned off on the modem or else you will get ip conflicts. Also make sure it is plugged into the wan port on the router
Jan 15, 2009 | Linksys Wireless-N WRT150N Router
Cannot access internet through WRT150N router wirelessly OR wired
Same problem here, the motorolla surf board works way better. It also coult be your ISP.
Apr 02, 2008 | Linksys Wireless-N WRT150N Router
Siemens S765IP w/ router linksys wrt150n
What VoIP provider are you using?
Try connecting router directly to the modem and the laptop to the router and see if your laptop can get out onto the internet. If you cannot, then your router might not be handing out IPs to the devices on the internal network. You can enable the DHCP server on the router using the administrative web interface at http://192.168.1.1.
If you can get out onto the internet with your laptop behind your router then look at defining a DHCP reservation on your router for your VoIP phone and then forwarding the following to your phone:
5061 UDP
5060 UDP
10000-20000 UDP
These are common ports amonst the VoIP providers.
Hope this works, if not we'll give it another shot.
Jan 30, 2008 | Linksys Wireless-N WRT150N Router
Linksys Wireless-N WRT150N Router Logo
366 people viewed this question
Top Linksys Computers & Internet Experts
Prashant M
Prashant M
mark
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
