Question about Comfort-Aire BHD-501 Dehumidifier
Iced up coils and will not dehumidify
Unit used to fill up within a couple days. now it won't fill up within a week. went to look a little deeper into unit and found the unit was frozen up with large amount of ice on condenser coils. unit is less than 2 years old..
  • 2 more comments
  • CragA Jun 26, 2008
    I have the exact same problem. I have have this unit for less than 1 1/2 years when this problem started. I clean the filters and the coils on the condenser where clean. I could see right through them. I think the dehumidifier is cheaply made and the welds on the cooling system are poorly welded, thus resulting in slow freon leaks, thus resulting in freezing. I would not buy any product from Comfort-Aire or parent company again.
  • Anonymous Sep 11, 2008
    Same problem. I have had it for less than 1.5 years and it is freezing up at the top of the coils. It had been working fine for about a year. It's supposed to be a low temp unit good to 42 F. Called Comfort Aire and was told only the compressor would still be covered. Pretty poor quality product. Not happy with it!
  • jimbojone310 Sep 16, 2008
    Oh yeah, same story here. What a piece of junk this is. I have had it for two years and the unit has always been EXTREMELY noisy. Now I am having the ice problem on top of the unit. Taking it apart and cleaning it didn't help at all. I will never buy Comfort Aire again.
  • sump0 Sep 28, 2008
    same exact problem. about 2 years old - icing up. Very dissapointed.
I did a little digging around on the internet and found out that if the basement (or where ever you have your unit) is in an area where the room temp might dip below 65 degrees the coils may start to become "too efficient" in pulling the moisture/humidity out of the air and it begins to freeze on the coils before it can drip off into the reservoir. The site said to turn off the unit and let it thaw out, then restart it and see if everything works ok after that. If the temperature gets too low you might need to warm up the air in the room/basement before it will operate correctly again/not continue to freeze up. Hope this helps. Mine just did the same thing but we've had some pretty cold weather recently and the basement is fairly cold as well.
Posted on Feb 16, 2008
Why does Frigidaire dehumidifier LAD704DUL has ice on the coils?
Hello Friend, thank you for your question!
I see that you have frost accumulating on the coils of your Frigidaire dehumidifier, LAD704DUL. Typically frost appears on coils either because your dehumidifier has been turned on recently or the room temperature is too low. Sometimes this is normal due to refrigerant rushing through the coils and usually it disappears within 60 minutes. However, if your dehumidifier is not removing moisture, then at this point your dehumidifier may possibly been experiencing a sealed system issue. Is your appliance still in warranty? If so, you might want to reach out directly to the manufacturer to determine the coverage on your dehumidifier and the procedures to any potential remedy in that regard. Hope this helps! - Z
May 15, 2014 | Frigidaire Dehumidifiers
Moisture collecting at the top front when running, even at mid power, over the control panel, sometimes turns to ice. if I shut it off when it is doing this the problem stops for awhile
Well, sounds like you have a good cold section in the dehumidifier-- that is good!-- But I agree-- we don't want water condensing on the surface-- and we surely don't need it turning to ice!
A couple questions to help us get to the next level of trouble shooting this problem:
1.) How cold is the room you are running the dehumidifier in?
(Obviously-- the warmer a room is, the easier to remove moisture--
the colder the room, the easier to drop the air temperature well below the freezing point-- making ice.)
2.) Have the air filters been cleaned/changed recently?
A dehumidifier needs a steady fast moving supply of air across its whole condenser/evaporator surface, in order to remove the maximum amount of water from the air, and not freeze up. (I would winder if something isn't blocking the flow of air toward the top of the coil?-- so that the coil in that area is going well below freezing temperatures, and thus allowing water (or ICE!) to develop near the top of the coil?-- Can you check air flow for us?
3.) You have suggested a good solution,-- especially if the above problems can not be easily corrected: Turn off the unit every few hours, and allow the warmth of the room, to defrost the coil....
In fact-- just to make sure that the air flow is not being restricted by ice deep within the coil-- let it stay off over night-- or bring the dehumidifier into a much warmer room, to make sure no ice is still blocking air flow deep within the coil..
Let us know what you learn about air flow, and get back with us-- THen maybe we need to take the trouble shooting deeper insicde the device.
I hope this helps-- MB
Aug 22, 2013 | Comfort-Aire BHD-301 Dehumidifier
Icing up on a dehumidifier
The gas can pass through the pipework slowly by osmosis especially after several years use. However, check fans, heat exchangers etc first before condemning unit.
May 15, 2012 | Whirlpool Dehumidifier 40-Pint
It ran for a couple days, went to empty the bucket and maybe a inch of water was in it. normally i'm empting it everyday. when i took the bucket out i noticed a little ice under the machine.
There are many reasons why a dehumidifier willnot work or collect water.
Here is a tip that I wrote to help people to figure out what is going wrongwith their dehumidifier
Dehumidifier is running but no water is in bucket
heatman101
May 07, 2011 | Fedders A7DH45B2A Dehumidifier
Bucket not filling - ice forming on lid.
You've developed a sealed system problem.
Apr 07, 2010 | LG LHD45EL Dehumidifier
Coils icing
the unit either has dirty evaporator coils and this will make them ice up,or the unit is low on refrigerant/freon,try cleaning the whole unit of dirt and dust first,then you may need to install a saddle tap on the sealed system and add some refrigerant/freon as these systems seem to leak more often than other sealed systems
Feb 06, 2010 | Whirlpool Gold AD70USS 70 Pint Per Day...
Freezing up
check the filter make sure it is clean the unit maybe a little low on freon that will cause the icing up
Jun 25, 2009 | Kenmore 54501 Dehumidifier
Icing on back of coils on dehumidifier
could be dirt coils or low freon either way needs to be checked
Mar 27, 2009 | Goldstar DH3010B Dehumidifier
LG dehumidifier developing ice
First you would need to clean the filter. LG recommends cleaning the filter every 2 weeks on their dehumidifiers. The second thing you need to do is clean the coils periodically. On this dehumidifier it should include a brush for cleaning the coils. It is located on the top of the bucket. To access the coils the following needs to be done:
1.) Unplug the unit from power
2.) Remove the bucket and also the air filter
3.) Remove the front pannel by removing the 2 lower screws and depressing the tabs.
4.) Once the panel is removed you will see the coils. You need to clean them with the brush. Go in an up and down motion to remove the dirt and dust.
Now use the reverse steps to put it back together. If your dehumidifier runs often I recommend you clean the coils about every 3 to 4 months. This is a common problem on alot of dehumidifiers and people think their dehumidifier is broken. Most of the time the coils are just dirty which causes the water to stay between them and freeze. Keep me posted. Also if you found this response helpful, please rate this solution when you get a chance. Thanks - Tech101
Jul 01, 2008 | LG Goldstar LD65EL Dehumidifier
Really thick ice on back of dehumidifier
It is now frozen because the humidistat, which controls the on/off cycle, is starting to age and forgetting to turn off the dehumidifier. Try removing the humidistat and, using compressed air, blow it out thoroughly of any dust. Then spray the rotary control area, including electrical parts, with WD-40. Then, blow dry again with the compressor and try again.
Jun 23, 2007 | DeLonghi DDE50E Dehumidifier
Comfort-Aire BHD-501 Dehumidifier Logo
519 people viewed this question
Top Comfort-Aire Dehumidifiers Experts
Mike Squire
Bill Long
Michael Youngman
Michael Youngman
Are you a Comfort-Aire Dehumidifier Expert? Answer questions, earn points and help others
