The dial will press in, but won't turn to the designated wash cycle. Model WBSR3140DAWW
  • 1 more comment
  • ginazinniawa Dec 13, 2009
    OK, Sorry about that, not very washer technical...The actual smaller white knob on top of the dial, you can press this in and pull out, but after you press it in, and attempt to turn it to delicates, permanent press, etc. It almost feels like it is stripped. I can put all my pressure on it to turn, and it sometimes will turn a few inches, then nothing...
    The knob does firmly click in and out when puched....This works wonderfully, just when you puch it in, it will not rotate to the cycle necessary to wash your clothes.
  • bsc100 May 11, 2010
    Does the timer knob turn at all? Stuck, or just free-wheels? Can't remember exactly on the GE's - Ages since I saw one last. Does the knob firmly click in & out when pushed & pulled ?
    I fear that something might have broken in the timer, if it won't engage with the timer gears.
    Difficult to diagnose without being in front of it... Usually with a push-pull knob, it will have a central screw or a cir-clip holding the knob on the timer shaft. If it is a round knob, hold the base skirt, & see if the top part will unscrew by turning backwards. NB: Make sure you're not turning the timer shaft backwards - you can break it. If there is a pointer strip on the knob, it may unclip at one side, to reveal what's underneath (like a lot of the older Simpson/Westinghouse w/m's). Getting to the timer shaft itself might allude more, to what is going on with it. Hope this might be of some slight assistance...
    Problem Solver:
  • 14 Answers
Hmmm...
I don't normally say to rip things open, but maybe...
Disconnect the power. Open up the control panel - from memory, I think there are screws along the top of it, & it pulls forward (???).
What I'm thinking, is to check that the timer hasn't (somehow) dropped back slightly, to the point that the knob is touching the facia, not allowing the shaft to go deep enough into the timer to mesh.
If the timer is solid against the front panel, and (when holding the timer body hard against the inside of the front panel) it still doesn't work properly, it is probably the timer that will need replacing. As I said - Unplug it first.
Removing the knob assm completely (to make sure there are no problems there) might be an alternative starting point.
Don't know - how do you feel about that ?
Jeff. New Zealand.
Posted on Dec 13, 2009
  • Washing Mach... Master
  • 43,501 Answers
The "timer", meaning the mechanisim behind the dial has gone bad and will need to be replaced.
Just take your time and be careful when replacing it as there are many wires to get hooked back up right. If possible move one at a time from the old one to the new.
You can find parts for your unit by doing a search for “appliance parts”.
Once you get the results of the search, pick a site and when it comes up it will usually ask for the model number of your unit.
Enter your model number and you will then get a page with exploded views and a parts menu.
Find the part you need and then order it.
Check a few different sites to be sure that you are getting the best pricing.
Most sites can have the part to you in a couple of days.
I hope that this will help you to solve your problem!
Thanks for using Fixya!!
Heatman101
Kenmore model 23832100 washer will not spin in rinse cycle kenmore model 23832100 washer fills, agitates, and drains, but will not spin. Makes noise after draining. BUT if I manually turn off the machine...
Check door switch: If the lid switch is bad it will not drain or spin. Try this test: With lid open let it finish wash cycle. Press lid switch down with screwdriver. Washer should begin draining. Release switch. Motor should stop. Press switch a second time. Washer should start spinning as it continues to drain. If motor doesn't come on while lid switch is pressed, replace the switch. OR
http://www.youtube.com/watch?v=q942xn_2VXY
Mar 30, 2013 | Washing Machines
Hi, my Beko washing machine, WMA 1512 W stops half way through wash cycle and leaves conditioner in drawer, won't rinse and I have to manually turn dial to spin, any ideas please?
Beko washing machine, WMA 1512 W stops half way through wash cycle and leaves conditioner in drawer This video will show you how to keep your soap draw clear and how to service the parts
Please remember to subscribe to our YouTube channel for all appliance tutorials
a 4 THUMBS rating is appreciated for answering your FREE question.
And don't forget to like us on facebook
Jan 26, 2013 | Beko Washing Machines
My Hotpoint wf000 1000 spin model won't spin. It goes through a full wash cycle, agitates fine, but just won't spin at the end of the wash. Any help appreciated.
Sorry if it may be too obvious, but have you checked the philtre? generally they stop spinning when it's stuffed... when you open it, make sure you have a mop and bucket handy, some water will come out!
Nov 06, 2012 | Washing Machines
Logixx 8 beeps at the end of the wash cycle
Start with program dial at " off position", then turn 1 notch to the right, and then press and hold eco-perfect button and turn prog.dial 1 notch to the right. a number will appear in the display. press"clock" button until number is 0. then turn prog.dial one notch more and do the same. all sounds are off now.
Oct 21, 2012 | Washing Machines
Just replace motor coupler a few days ago...now washer filled up, washed & got to rinse cycle then stopped. Turned dial back to wash cycle, won't work. Checked lid switch, not broken. Jumped outer...
since the coupler is new and lid switch was jumped i would be looking at the connections on the motor plug that you disconnected to replace coupler depending on your exact model there is the main plug the 2 wires on the capicator and a smaller plug. BUT FIRST recheck lid switch what must be jumped out is the connection leading up to control panel and NOT the part in the cabinet
to me a appliance tech w/30 years experience it sounds like a bad lid switch!
Aug 10, 2011 | Kenmore Washing Machines
MAV4755A Top Load Washer: When I turn the dial to start wash cycle, nothing ...
if press button selection, make sure that no 2 buttons are pressed
Jan 27, 2018 | Maytag MAV4755A Top Load Washer
WHDSR209DWW on/off button will not engage to spin the cycle selector dial
The cycle selector is not engaged onto the timer shaft. Need to remove the on/off knob by removing the plastic "U" clip. Remove the cycle selctor knob and check that the steel spring clip on the selector is fully seated. Re-install the cycle selector onto the timer shaft aligning the selector key with the with tthe notch on the timer shaft. Re-install the on/off knob.
The cycle selector and on/off combination is a poor design. Users press the on/off knob in and turn clockwise to set the wash cycle. If you're not gentle this action wears the teeth on the timer shaft and the user has to press harder and harder to set the wash cycle. This pressing causes the cycle selector to be pushed off the timer shaft and you can no longer operate the machine.
VERY IMPORTANT:
Stop using the on/off knob to set the wash cycle. Press on the cycle selector to set the wash cycle. Use the on/off knob only for starting or stopping the machine. Don't press or pull too hard on the on/off knob or you will wind up pushing the cycle selector off the timer shaft.
Jan 12, 2010 | General Electric WHDSR209DWW Top Load...
Asko w6221 front load washer stops after wash cycle
Do all of your cycles work when you turn them manually? If one cycle does not work when you turn the dial on it then it will be your timer (The dial assembly $100-up) If all your cycles work manually, then it could be your timer motor which is attached to your timer assembly. If you turn the dial pass the wash, on to the rinse, does the dial automaticly move (when finishng the rinse cycle)to the spin cycle? If so then your timer motor is ok. The only wires close to the bottom are the motor, but these should be high enough out of the way.
Apr 01, 2007 | Asko W6221 Front Load Washer
Washing Machines Logo
60 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
Marvin
Marvin
