Yui.dll I have Yahoo Messenger running on Vista.....i keep getting can not locate yui.dll file....re-installing the program may fix the problem....to no avail.....does'nt work...please help
  • 1 more comment
  • Anonymous Apr 01, 2008
    This application has failed to start because yui.dll was not found.Re-istalling the application may fix this problem.
    Ranjeet
  • Anonymous May 09, 2008
    the application has been failed to start because yui.dll not found.reinstlalling may fix the problem
  • Anonymous Jul 10, 2008
    yui.dll problem whenever system is on display reinstall yui.dll file
    What to do?
    Is there any solution to remove it?
    Please advice...
    With regards...
    Genius:
  • 1,067 Answers
Remove it all run ccleaner dl that tool on line free then dl latest java ok and adobe flash shock then reinstall it cheak msconfig for startup junk uncheak it
Posted on Jan 20, 2008
    Problem Solver:
  • 9 Answers
Re installation of the messenger can fix the problem.
I tried searching for yui.dll on the net and end up with nothing.. So i installed Ymessenger to my PC just to get yui.dll
You can download it from http://www.dll4free.com/yui.dll.html
Posted on May 29, 2009
When downloading yahoo messenger, why do I get an error that says Yahoo did not finish installing because there is a missing component?it says d3d9.dll was not found
Install the latest version of Microsoft DirectX. Chances are, upgrading to the latest version of DirectX will fix the d3d9.dll not found error.
Note: Microsoft often releases updates to DirectX without updating the version number or letter so be sure to install the latest release even if your version is technically the same.
Note: The latest version of DirectX should be installed no matter if you're running Windows 7, Windows Vista, or Windows XP. The installation may include DirectX10 and DirectX9 files but they run side-by-side without problem on all of these operating systems.
Dec 03, 2011 | Yahoo Messenger
My webcam
please download the missing dll file from here
http://www.nodevice.com/dll/kdu_v32R_dll/item9440.html
then place it in c:\windows\system32\
and try again
May 23, 2008 | Computers & Internet
When i am installing yahoo messenger during installation an error comes d3d9.dll not found reinstall it........now what can i do plz help me.........
ANY Yahoo! Messenger program will not install properly if a former program, or an incomplete install, has not been completely deleted from the computer first. (Don't worry - your Contacts List will be saved into the fresh installation of an updated Messenger!)
Delete all Yahoo Messenger references from the registry.
  • Use the Control Panel > Add/Remove Programs method,
  • Then double-check by going to Start > Search > files and folders > Yahoo! Messenger (notice the exclamation mark in the title).
  • Write down and delete all references manually if necessary. The uninstaller works well for Vista and Win 7, but not for XP - it leaves behind MANY junk files when uninstalling.
  • If you are using Internet Explorer 8 or 9 as your browser, Yahoo Messenger 10 will not work properly without Flash and Java programs installed, and possibly the .NET framework update. (Messenger 11 is still in beta format, so be wary of using it yet.). you'll have to download Flash and Java programs as well.
Last, you could used this link to fix a dll error:
http://fix-all-dll-errors.com/d3d9.dll/
Just click on the link, then click the button "Fix dll errors now." This should fix the issue. Hope this helps. Thank you for using FixYa!
May 20, 2011 | Yahoo Messenger
While i am installing yahoo messenger, i got the masssage cannot find resouce dll
'Resource DLL is a basic part of the installation, so you will need to un-install and re-install the program - sorry about the trouble, since it takes time.
ANY Yahoo! Messenger program will not install properly if a former program, or an incomplete install, has not been completely deleted from the computer first. It requires deleting all Yahoo Messenger references from the registry, except your archived messages and profile and contacts lists, perhaps. Use the Control Panel > Add/Remove method, then double-check by going to Start > Search > files and folders > Yahoo! Messenger (notice the exclamation mark in the title). Write down and delete all references manually, except for your Profile folder. Also, go to My Computer > Local Disk > Program Files and delete any Messenger files there.
Mar 03, 2011 | Yahoo Messenger
I cant see any message on ym window
The first thing to check is to make sure you have scripting enabled in Internet Explorer. Internet Explorer is integrated into Yahoo Messenger so things that go wrong with IE can affect Yahoo Messenger. Here is the yahoo help page about that: http://help.yahoo.com/l/us/yahoo/messeng...
2) In the Start Menu click on Run. Type, without the quotes, "regsvr32 jscript.dll" and then click OK. Next, repeat the process but this time type in the Run box "regsvr32 vbscript.dll" and click OK. Please note, if you are using Windows Vista temporarily disable the User Account Control (UAC). You can easily turn it back on. On the Control Panel (Category View) choose User Accounts and Family Safety, next choose User Accounts, and then click Turn User Account Control on or off.
3) If the above does not fix your problem and you are using Windows XP, you can update your Windows Script to version 5.7. In my experience helping others, this is the step that has helped the most people. Exit all browser windows and chat programs including Yahoo Messenger before installing. run registry cleaner reginout cleaner to easily fix it
Feb 02, 2011 | Yahoo Messenger
I install today the least version of messenger11. after i install i cannot open my yahoo messger... it said cannot d3d9.dl cannot locate... i already retry to install but its the same problem what should...
If you've already downloaded d3d9.dll from one of those DLL download sites, remove it from wherever you put it and continue with these steps.
  1. Restart your computer if you haven't yet.
    The d3d9.dll error might be a fluke and a simple restart could clear it up completely.
  2. Install the latest version of Microsoft DirectX. Chances are, upgrading to the latest version of DirectX will fix the d3d9.dll not found error.
  3. Assuming the latest DirectX version from Microsoft doesn't fix the d3d9.dll error you're receiving, look for a DirectX installation program on your game or application CD or DVD. Usually, if a game or other program utilizes DirectX, the software developers will include a copy of DirectX on the installation disc.
    Sometimes, though not often, the DirectX version included on the disc is a better fit for the program than the latest version available online.
  4. Uninstall the game or software program and then reinstall it again. Something might have happened to the program files that work with d3d9.dll and a reinstall could do the trick.
  5. Restore the d3d9.dll file from the latest DirectX software package. If the above troubleshooting steps haven't worked to solve your d3d9.dll error, try extracting the d3d9.dll individually from the DirectX downloadable package.
  6. Update the drivers for your video card. While it's not the most common solution, in some situations updating the drivers for the video card in your computer could correct this DirectX issue.
Applies ToThe d3d9.dll error message could apply to any program that utilizes Microsoft DirectX, most commonly video games. Any of Microsoft's operating systems since Windows 98 may be effected by d3d9.dll and other DirectX issues. This includes Windows 7, Windows Vista, Windows XP, and Windows 2000.
Dec 21, 2010 | Computers & Internet
Everytime I try to download and install yahoo messenger I get an error message saying that I'm missing d3d9.dll.
~ d3d9.dll is a process belonging to the DirectX program . d3d9.dll is DirectX DLL for DirectX9. It adds DirectX functionality for Windows Multimedia tasks and games. ~ Determining whether d3d9.dll is a virus or a legitimate Windows DLL depends on the directory location it executes or runs from. ~ Click to Scan your PC including d3d9.dll to Detect any Security Threat. ~ You can download it separately.
Jul 02, 2010 | Yahoo Messenger
Yahoo messenger 10 is not installing in xp. i get the message 'install unsuccessfull'
This may cause either of the following:
1. You didn't have right fine software
or
2. U didn't load it in fine, may be you missed some dll's
if you any lower version of yahoo in your system, try to make sure of update directly by web for fine installation and running concerned.
if you want alternative means, then have the option of Y mail in-built messenger function but that doesn't support voice / video or any attachment concepts! have fine!
Dec 17, 2009 | Yahoo Messenger
My yahoo messenger when opened says "cannot load resource DLL"
The error message indicates your operating system is not able to load one of the files required for Yahoo messenger to work.
To make sure Yahoo messenger is installed properly, download the installation files and save them to your desktop.
Once you have the installation file...
Open the control panel and uninstall the existing version of Yahoo messenger. This will remove the program from your computer and clear out the registry entries that were created during the first install of Yahoo messenger.
Reboot your pc and then run the Yahoo messenger installation file you downloaded to your desktop.
The system reboot is a precautionary measure to ensure that none of the files used by Yahoo messenger are loaded into memory during the reinstall.
Sep 08, 2009 | Yahoo Messenger
I cant hear others on yahoo messenger
hi
install yahoo messanger new version.
check u not mute the sound in ym.
check your sound connection.
Mar 25, 2008 | Microsoft Office Outlook 2003 for PC
Computers & Internet Logo
1,594 people viewed this question
Alun Cox
David Payne
David Payne
