Keep getting unsupported mode message after hooking up xbox360 using hdmi cable. can anyone tell me how to fix this.
  • 11,361 Answers
It is complaining because it cannot support the resolution thaat the xbox is feeding it, what is the TV maximum resolution it can display?
Posted on Dec 14, 2009
  • Bud Martin
    Bud Martin Dec 14, 2009
How do I get HDMI cables to sync or talk to each other. We had this problem when we hooked up an Apple TV box to a Denon AVR-E400 and our Sony HD TV. We were told to disconnect all HDMI cables unplug
Personally I would use an RCA cable and hook up the AVR.
((RCA out of TV to AVR audio in))
((cable box HDMI cable output to TV HDMI Input1))
(As far as the AppleTv I would use a separate HDMI Input2)
If your AVR has a dvd or blue ray player Hook up a
HDMI cable out to another Input HDMI3 of the TV
using separate inputs on the tv will allow your surround system to be
used on all modes(CABLE,DVD/BLUERAY,APPLETV)
Sep 27, 2014 | Denon AVR-E400
I can't connect my xbox360 to my sony pfm-42b2 tv
Keep in mind that your Sony IS NOT A TV, but a monitor instead. There is an actual XBOX360 VGA adapter that's available at most gaming retailers. It was initially designed for those who wanted to use their PC monitors for there console gaming. HDMI is NOT compatible with a VGA input as HDMI is a digital signal type and VGA is an analog type connection. You must also remember to have the XBOX set to a NON-progressive resolution (480i) if trying to hook it up using the standard XBOX video cables.
Apr 17, 2012 | Sony Televison & Video
I have a Jensen (JE1909ACB) 19 LCD TV Can't get it to hook up as a monitor on my desktop. It reply's unsupported mode.
Are you using the VGA port on the Jensen TV? What is your computer's OS?
The usual reason for the unsupported mode message is that the the computer did not recognize the TV as a monitor on boot up or that the previous settings were incompatible with the TV. (For example, if you previously had a CRT connected to the computer and used a refresh rate of 75 Hz, the TV can't handle the refresh rate. It needs to be set at 60 Hz.)
First turn off both the TV and the computer. Then turn on the TV and set it for the PC input (assuming you are using the VGA port). Next turn on the computer. If you have Windows XP or later, it should find the TV and set the resolution without any input. (If it doesn't, use a different monitor and set the resolution to 1366 x 768 and 60 Hz. Then try again.) If you used the HDMI port, try the VGA port. This TV doesn't understand a computer signal over the HDMI port (only set top boxes).
I hope this helps.
Dec 08, 2011 | Car Audio & Video
My ps3 is hooked up though HDMI to my emerson lc195emx. but the tv says its an unsupported format. why? is it because the tv only has 720p out put??
Try turning off the power to your console using the power switch in the back (first shut it down properly). Unplug the AV cables (if applicable) and the plug in the HDMI cable. Turn on the system and switch your input on your Television to HDMI. (Keep in mind that there may be a few inputs; HDMI1, HDMI2, etc.) The HDMI connection takes a few seconds so be patient. If that doesn't work, re post or ask to chat.
Feb 05, 2011 | Sony Playstation 3 (PS3) Console
Says my hdmi ports are unsupported. they worked yesterday but now it wont work on the dvd player, xbox 360, or the ps3. got any idea of how to fix this or how i can reset the tv?
Hay there i have the same problem and found out my LCD does not support xbox360 via hdmi have to use a componets cable not the standard av cable its the ones that go in to the YB,YR,PR slots like an RCA but they are actualy HD quality cables that will give same affect as using the HDMI cable and its hlf the price to!!. With the use of the components cable you will be able to veiw xbox360 in full hd up to 1080i or 1080p hope this helps as there many unanswered questions here! Who the hell runs this site? They arent very helpfull ay!!!!!!!!!!!!!!! Regards Matt Rocket
Oct 16, 2010 | Hitachi Televison & Video
Panasonic TH-46PZ85U Plasma TV All 3 HDMI was working fine with cable box, PS3, XBOX360. I used to connect my pc to the tv with a dvi-hdmi cable, but recently unplugged it. So I tried to plug in the same...
Symptom:
TV shuts off unless all the input (phono and HDMI) cables are disconnected. The
symptom may be intermittent.
Cause:
There is an abnormal AC voltage entering the TV from one of the input cables or AC
outlet.
Remedy:
Follow the Testing procedure to determine if there is a problem external to the product.
Concept
Constant symptom
If the TV no longer shuts off when all input cables are disconnected, then one of the
input cables is introducing abnormal voltages into the TV. Panasonic Plasma TV sets
have 3 wire AC plugs.
As a result, abnormal voltages introduced into this TV will cause the TV to shut off for
protection.
Intermittent symptom
If the abnormal input voltage is borderline (marginal), the TV shut off symptom may be
intermittent. However the cause may still be detectable with a voltmeter.
Protection Proof:
Release the protect mode - the TV has to be unplugged to reset this protection circuit.
Threats from the HDMI input:
Excessive voltage from an HDMI cable connected product will activate the Plasma TV’s
protection circuitry. Placing an isolating / buffering connector (sometimes called a voltage
conditioner) between the TV and the HDMI input cable often solves the problem.
Testing -
Unplug all the HDMI inputs from the TV. Turn on the TV. Plug in the HDMI inputs one at a
time. The cable that causes the TV to enter the protection state is connected to the product
that has the excessive voltage (and signal). Avoid connecting this product until an isolating
connector is found.
Jan 27, 2010 | Panasonic Viera TH-46PZ85U Plasma TV
Hi, i have a flx-2211b element electronics tv and I have a xbox 360 hooked up to it through a HDMI cable but the tv says unsupported mode. what do i do to fix it?
I have the same problem with my 360 i am just going to by a new tv i cant find the remote code. or any thing and the hdmi port don't work that's my answer this TV sucks and it is ****..
Jan 07, 2010 | Element Electronics FLX2211B 22 in. LCD TV
'MODE NOT SUPPORTED' message appears on my TV screen
i have samsung 22' lcd series 4 tv but i connected it with the dvd player via hdmi it shows mode not supported. but the same dvd works very well on another samsung lcd of same configuratition. please help me
Jul 13, 2009 | Samsung Televison & Video
HDMI XBOX360 Elite -"No Signal"
The connection order can be a key issue as to whether or not the HDMI signals will pass through the system. For best results the receiver should be turned on first, then the source device(s) and then the display. The reason for this has to do with getting the equipment to handshake properly for the HDCP protocol.
If HDMI video will not pass through your receiver, you may with to just connect the xbox using the component cables. Since component will pass through 720p and your TV is 1080i you should expect the same qualtiy and a more crisp picture.
Oct 12, 2008 | Denon AVR-2307Ci Receiver
Televison & Video Logo
493 people viewed this question
Top Televison & Video Experts
Marvin
Marvin
