Question about Coleman Heating & Cooling
I have an older coleman oil gun burner, it was running fine until yesterday it just quit.I took it apart cleaned everything put it back together itcame on an ran for six cycles and now it want do anything.
    Problem Solver:
  • 5 Answers
If it does nothing, then its most probably the "primary control" the one with the red reset button. If it does make noise but the motor does not run, it could be a bad burner motor. If its real old system, then it could be the old stack control in the flue pipe which also has a reset and if this is what you have, then try reseting by the red button and if it works,that then have it changed by a professinal to a more modern style primary control soon.
Posted on Dec 13, 2009
  • rhchvacone Jan 23, 2011
    on your buner check your pump if it wester they a filter in to get to they 8or 10 3/8 bolt you have to remove them then be careful not to ruin your seal then pull your filter out and clean it with pd blaster or seaform after that to set your spark take a nickei hold vertical and set prob then to set nozzle then set about a 1/2 in high over the nozzle it must not go over in the fuel it will not light if you do
Why won't my pressure washer start?
Im currious what on a pressure washer required "cleaning" what were you running thru it other than water ?
do you think you might have dissasembled something on engine part and might not have assembled it back quite right?
May 03, 2014 | Stanley 2350 PSI 2.3 GPM Gas Pressure...
I own a tippman a5 with an UMP shroud and fake metal clip. I took apart for some maintinance and ever since i put it back together its been acting like im out of air after 2-3 quick shots. I took it apart...
There is an O-ring up in where the Tombstone slides in. That O-ring has to be lubed (oiled)
and should be toward the rear of the gun when installing the Tombstone. Also, drop-off
in firing can be caused by lack of lube on the internal O-rings. 2 drops of oil in the inlet hole
where your bottle screws on and then dry firing to cycle the oil thru might help. You may need
to completely tear down the gun and clean and lube the internal O-rings. If you can switch to
air AKA...HPA (High Pressure Air) it will be better for internal parts and better consistency overall.
Here is your manual for reference.
http://www.tippmann.com/pdfs/products/A5/a5manual.pdf
Jan 26, 2011 | Tippmann A 5 Standard Paintball Gun
The shaft or pin that drives the nail does not retract on my mastercraft 3 1/2 framing nailer. #58-8434-4
take the back cap off of the nailer. There is another loose cap in that head, most times that gets stuck. Believe me, I was raised by a carpenter that had nail guns before anybody else did. Also, sometimes that plunger gets bent, just straighten it out. Check for blown o rings. If it is old, take the trigger assembly out and clean it out. Be sure to oil everything well before you put together. We use marvel mystery oil, or nail gun oil.
Jul 08, 2010 | Air Tools & Compressors
Spark but no fuel . coleman Powermate 6250
Check the oil level. The protection on low oil level may have stopped it.
Jun 23, 2010 | Coleman Powermate Premium Plus 6250W...
Black soot on Coleman propane burner
Had same problem. Coleman tech support said, " clean with pipe cleaners". No directions....I would think they would provide a step by step protocol. So, I chose to take the knobs off and use the pipe cleaner where I could. I was able to take one of the two burner control knobs apart. After sticking the clean in every nook I could find, I put back together, and the flame on that burner is back to normal,
Good Luck--Daryl in Burnsville, MN
Sep 11, 2009 | Coleman Grilling
My GE Side by side is not cooling. I believe it is the defrost heater, how do you replace this?
The defrost thermostat is located behind the freezeer firewall, on top of the evaporator.
It is part 240 on the diagram below:
Regards.
G.
Aug 14, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
My paslode will not drive a 3 1/4'' nail in pine lumber, but it will drive a 2'' nail in the same lumber. i have took it apart and cleaned it with the paslode cleaner and used the paslode oil put it back...
check your air tank for moisture , drain it and put a oiler on it, or just oil it your self. put at least 3 to 4 drops run the proper amount of air they want you to run.
Jul 25, 2009 | Air Tools & Compressors
Heating & Cooling Logo
208 people viewed this question
Top Coleman Heating & Cooling Experts
Bill Long
Paul Carew
Paul
Paul
Are you a Coleman Heating and Cooling Expert? Answer questions, earn points and help others
