Question about Dell 924 All-in-One InkJet Printer
Printer busy message
I keep getting a printer busy message when I try to print, can anybody please tell me how to fix this problem?
  • 3 more comments
  • Anonymous Feb 07, 2008
    My a924 keeps giving me a busy message,than after that I get a (no paper) message.I used to think I could get some advice from Dell but no luck.This may be my last Dell printer and maybe computer.
  • Anonymous Apr 04, 2008
    Same problem but in A10 printer 922. Message on computer screen is powering off. Also when I try to print anything a message appears and states the computer is busy
  • Anonymous May 25, 2009
    I have the same problem too.
    this would be my last dell printer. i will get a hp next time.
  • Ot Tap
    Ot Tap May 11, 2010
    will not power on with up and down buttons pressed.
  • Anonymous Mar 23, 2014
    After the message center records the incoming call and the person hangs up the system sounds a busy signal
  • 58 Answers
See if this works:
Turn computer off
  1. Power off the printer.
  2. Close all printer covers and doors.
  3. Hold down the printer busy message - uparrow.jpg and downarrow.jpg (up arrow and down arrow) buttons on the printer and power the printer on.
  4. Release your fingers from the buttons when the message Diagnosing... appears.
  5. When Customer Mode and ESS Diag display, press the downarrow.jpg (down arrow) button until Test Print appears, and then press the select (center) button.
  6. Pressprinter busy message - downarrow.jpg="" alt="downarrow.jpg" class="h_mi" /> (down arrow) button until ContaminationChk appears, and then press the select (center) button twice.
  7. After the LCD displays Busy and the printer prints the ContaminationChk pages, power off the printer and power it back on.
Posted on Feb 14, 2008
Printer keeps saying busy printing another document
A quick fix for most communication errors can be achieved by resetting the printer and/or rebooting the PC. Simply disconnect the printer from your computer (if USB connected)> reboot your pc > unplug and re-plug the printer into the power source to reset it. When the printer turns on, reconnect it to your computer (if USB connected). Then try to print again once the computer fully recognizes the USB connection or when the WiFi light on the printer turns solid green (if WiFi connected.).
If that doesn't help, try the steps below:
  1. Disconnect the USB cable connecting the printer from your computer.
  2. On your computer, go to Control Panel > Printers and Faxes.
  3. Delete the Lexmark print object.
  4. Reboot computer.
  5. Re-brick your printer by pulling out the power supply - black box where the power cord is plugged into on the back of the printer, and re-plug after 30 seconds.
  6. When the printer turns on, reconnect it to the computer.
  7. Wait until your computer fully recognizes the USB connection. To check, go to Control Panel > Printers and Faxes. If you see a new Lexmark print object in the list, try to print a document to verify that the problem is fixed.
Feb 10, 2012 | Lexmark X4580 InkJet Printer
My printer keep saying clear carriage jam but there isnt anything that is still jamed. How do i fix this problem . I can't get it to work now
The printer is telling you that something is jamming the printer carriage, or the rod, that the print cartridges ride on. Open your printer up to where you would install your print cartridges, either front load or top load. See if you can find anything in the path of its movement.
Remove it, and try printing again.
Look for paper that may have jammed recently in the printer.
If that doesn't fis it, try moving the printer cartridge holder manually and then try to clear the message again.
Hope this helps.....
Please rate my response!!
Jan 29, 2010 | HP Photosmart C7180 All-In-One InkJet...
My HP Photosmart C5180 printer keeps coming up with an error message 'Ink System Failure. Does anybody know what is needed to solve the problem.
The "Ink System Failure" error is causes by air in the ink feed tubes. We have a step by step guide purging the air from the feed tubes posted on our web site. Go to our site at:, click on the printer repair link and then the HP link. Follow the steps and you should be back printing in no time at all.
I hope this helps, If so please rate our solution.
Corporate Computer
Nov 01, 2009 | HP Photosmart C5180 All-In-One InkJet...
Prints one or two lines & then stops & says "outbind" error
Hi lhessel,
The best solution is to contact Cannon on the net, ask for tech support and download any updates available for your printer (make sure they are for the operating system you are using, i.e. Windows XP Home or Professional Version, Windows Vista).
May 20, 2009 | Canon PIXMA iP1500 InkJet Photo Printer
Print head error message
reset it in window printing menu. perhaps it works.
Dec 03, 2008 | HP Business InkJet 2800 Printer
Printer Spooler service!
1) Click the Star>Run, type in "Services.msc" in the Run dialog box.
2) A services window popup, find the service name "Print Spooler", double it and change the Service Status to "Start".
Now u can use your printer now.
YBC (/\)
Aug 04, 2008 | HP LaserJet 1018 Printer
Printer error
go to microsoft word and under tools go to letters and mailings under the options button you will find business cards the business cards that you bought has a code in the right hand corner go down until you see your code and click on it and hit new document and it should format for you
Mar 25, 2008 | Canon PIXMA iP1800 InkJet Photo Printer
Canon Pixma MP160 printing problem
Hi I hate to be a pest but can anybody tell me how to fix a scanner error when I turn on the MP180 printer the alarm light comes on and the i get the scanner message regards Ted
Feb 18, 2008 | Canon PIXMA MP160 All-In-One InkJet...
Dell 924 All-in-One InkJet Printer Logo
3,544 people viewed this question
Top Dell Office Equipment & Supplies Experts
Are you a Dell Office Equipment and Supply Expert? Answer questions, earn points and help others
