Question about Daewoo Televison & Video
I can't get a Logitech Harmony universal remote to learn the Daewoo DVD IR commands Any ideas?
I learned the IR commands as raw data and then transferee them to the Logitech remote. So far it seems to work
Posted on Dec 13, 2009
SOURCE:
Remote will allow you to "choose an activity" to
Hi. It sounds like some of the IR commands on your remote (menu, exit, guide, info, play, skip, etc.) for your TV and DVD player are not correct. Luckily, the Harmony remote is a Learning remote, meaning you can use your original TV or DVD player remote to teach the Harmony remote the correct commands. The following tutorial by Logitech will assist you with this:
http://logitech-en-amr.custhelp.com/cgi-bin/logitech_en_amr.cfg/php/enduser/std_adp.php?p_faqid=3859
Regards,
D
Aug 26, 2011 | Logitech Harmony 890 LCD Remote Control
I can't turn the closed captioning off. I have went to device tv tried turning cc off. It won't turn off
If you are able to turn the closed captioning off with the original TV remote, then I suggest doing it that way. If you want that functionality on your Harmony One, you can use the original remote to teach the Harmony the closed captioning command. To learn commands, do the following:
1. Log in to the Harmony software. 2. On the "Devices" tab, click "Learn IR" next to the icon for your TV. 3. At the bottom of the screen where it says "MyNewCommand," enter the name that you want the command to have, and click "Learn." 4. Follow the on-screen instructions to learn the button. 5. Update your remote.
Jul 26, 2011 | Logitech Harmony One Advanced Universal...
Won't control Sony da4400es receiver
Hi. If your remote is not able to control any of your devices, you can take advantage of its learning capabilities. The Harmony One remote is able to learn commands from your original device remote, so that it can properly mimic the remote.
To learn commands, log in to your software account and click on the "Devices" tab. Next to the icon for your receiver, click "Learn IR." This will take you to a page with all of the receiver's commands, which you can learn one by one by selecting them and clicking "Learn."
Hope this helps.
Jul 10, 2011 | Logitech Harmony 900 Remote Control
I recently bought a Logitech Harmony One universal remote for my VIzio HDTV and Vizio soundbar. Following the setup instructions on the DVD I sucessfully set up the remote to control the TV, cable box...
Great remote but not always easy to find right category for device.
Had a look for you and sure enough the device IS listed in data base under AMPLIFIER- then select amplifier again and input vizio for make and soundbar for model and click next.Problem solved!
Jan 09, 2011 | Logitech Harmony One Advanced Universal...
I don't have the remot of my DAEWO LCD20 KAT-T Flat Panel TV and i bought a logitech harmony 700 remote but their database is not correct. Logitech ask me the all HEX IR CODES in PRONTO FORMAT of DAEWO...
You wont find that anywhere - that format is proprietary and noone else is using it. All you can do is to take advantage of the learning capabilities of the logitech harmony 700 remote: buy a cheap universal remote make sure its buttons are fully functional , then enter the commands one by one from the universal to the remote : put the remotes face to face then press the same button on both . The exact procedure is in the manual of Logitech. Once all the commands/codes are in you can upload them directly from your remote.
Oct 15, 2010 | Daewoo Sensy LCD20KAT 20 in. LCD...
We own the Logitech Harmony 550 universal remote and recently purchased the Insignia NS-L32Q-10A for some reason we can't get the Logitech to work with the Insignia, any suggestions?
Does the device not respond at all?
You can try learning the commands from the original remote to ensure that they are correct.
1. In the software, click 'Learn IR' next to the icon for the device. 2. Go through the list of commands and learn the ones you think you will need by clicking 'Learn'.
The important commands of course are the power commands and input commands. Also channel and volume commands.
Hope that helps :)
Apr 05, 2010 | Logitech Harmony 550 Remote Control
Red/ Bright Tint/Color on Sylvania SRCD227
Your Logitech Harmony 550 is able to learn commands that are not included in its command database.
To teach your Harmony 550 a new button follow these steps:
  1. Connect your Harmony remote to your computer to start the Harmony remote control software.
  2. Click Devices.
  3. Click a device.
  4. Select Learn Infrared Commands.
  5. Click Next.
I hope that helps.
___________________________________
Harmony 550 Manual Download
Logitech Harmony Firmware Update
Harmony Mac Software Download
Harmony Win Software Download
Logitech Harmony Safe Mode Fix
Harmony Remote Glow Light Fix
Feb 11, 2010 | Sylvania SRCD227 27 in. TV/DVD Combo
How do you set up a harmony 550 to be able to use the record on a dvr
Click 'Learn IR' next to the icon for your DVR in the software, learn the command, then assign the command to a button in one of your Watch TV Activities.
Feb 11, 2010 | Logitech Harmony 550 Remote Control
Logitech Harmony One remote is controlling 2 TiVOs at once.
Please try learning the some commands from one of the original remotes for thr tivo. If this fixes the problem, i suggest that you learn all commands from that remote.
Launch the Logitech Harmony Remote software and login to your account
1. Click on the Devices tab
2. Click on the Learn IR button for the device you want to learn command(s) to.
**NOTE: When learning new commands, there are three different options available:
-You want the Harmony Remote to learn a single command that is already listed in the software
-You want the Harmony Remote to learn more than one command at a time
-You want the Harmony Remote to learn a new command, which is not listed in the software
a. Click on the Learn button next to the command you want to learn - Proceed to Step 5
a. select one or more commands by clicking on the check box next to the command(s) you want to learn and then
b. click on the Learn Selected Commands button
c. Proceed to Step 5
You want the Harmony Remote to learn a new command, which is not listed in the software:
a. Scroll down to the button of the page
b. In the Learn a New Command box click on the text MyNewCommand
c. enter the name of the command you would like to teach.
d. Click on the (Learn New Command) button
e. Proceed to Step 5
5. Follow the onscreen directions for learning commands, plugging in your Harmony remote when asked and lining up your original remote to the Harmony as illustrated on the screen.
6. When a command is successfully learned, a check mark will appear next to it. If learning more than one command, the software will then prompt you to learn the next command.
7. The commands that were learned should now be identified as from "Your original remote" and highlighted in turquoise.
8. When you have finished teaching the commands, click Done button to save your changes
9. Click on the Update Remote button to update your remote
If this does not work, try :
To teach commands for your Device that did not work properly in normal mode:
1. Click the Devices button on your home page.
2. Select the Device you wish to learn commands to.
3. Select Learn Infrared Commands.
4. Click Custom. The page will reload.
5. Select the boxes for commands you would like to teach, and click Learn Selected as Raw.
NOTE: When teaching each command, press the button on the original remote for as long as required to control the device. The commands will be learned with the exact format that is sent by the original remote.
If you have any trouble teaching the commands in RAW, complete the following steps:
1. Verify you are pointing the original remote at bottom end of your remote, and are holding the remotes 2-4 inches apart.
2. Minimize the amount of light that could interfere with the learning process by covering the distance between the remotes. Block out sunlight, or turn off the lights.
3. Check that you have installed new batteries in the original remote you are trying to use to learn commands. If the batteries are low, the signal coming from your original remote may be too weak for the remote to detect.
4. Be sure to hold down the button on the original remote for at least 1-2 seconds, otherwise the signal may be too short for the remote to process.
5. If you continue to have trouble teaching the commands, start with the remotes 2 inches apart. Then try again with, slightly increasing the distance each time (2.5 inches, 3 inches, etc).
6. Vary the angle at which the original remote is pointing at the bottom of the remote.
7. Ensure the device's original remote is sending infrared (IR) commands.
NOTE: The original remote is sending RF or UHF commands from the original remote if it will control the device from another room, through a wall).
Oct 04, 2009 | Logitech Harmony One Advanced Universal...
Logitech harmony 550 volume problem
I would call or email in to logitech and suggest that they copy some of the learned commands for your bose system into your harmony remote account.
The commands they add are learned from other customers and they will only copy the best ones. Give it a shot.
Jul 21, 2008 | Logitech (9662080403) LCD Remote Control
Televison & Video Logo
77 people viewed this question
Top Daewoo Televison & Video Experts
 Grubhead
Grubhead
Jaime Hernandez
Are you a Daewoo Televison and Video Expert? Answer questions, earn points and help others
