Question about Honeywell Programmable Thermostat Heater
Turning off the A.I.R. on the Honeywell PRO4000
I've seen the advice on turning off the A.I.R. on the Honeywell PRO4000 Thermostat. Do I need to run through the entire setup diagnostic as listed in the manual if I'm only switching the A.I.R. from on to off?
  • 614 Answers
No just turn off
Posted on Dec 13, 2009
Heat won't turn on
Is the heat not turning on because the thermostat stop functioning? Or because there's a problem with the heater itself?
If the thermostat is not working, replace the batteries...if the problem is not with the thermostat, then the problem lies in your heating system.
Feb 28, 2015 | Honeywell TH4110D1007 Pro4000 Thermostat
Rth2520b Honeywell thermostat won't turn on
If known-good batteries were installed correctly, the thermostat may have failed.
Dec 23, 2013 | Honeywell Programmable Thermostat Heater
Honeywell heat/cool thermostat keeps turning furnance on
This is not the thermostat, it is most likely the controller in the furnace.
Aug 10, 2012 | Honeywell Heat/Cool Thermostat
Dont no how to work central heating system
Honeywell Focus Pro 5000 non programmable is the easiest heating cooling thermostat that I've seen.
Dec 23, 2011 | Heating & Cooling
How do I switch the honeywell pro4000 thermostat from reading in Fahrenheit to Celsius?
Hi, The procedure is fairly simple.... the easiest way is for you to look up the manual and have the proper steps right in front of you...
Here is a tip that tells you how to get a manual for most any Honeywell productonline...
Manual Honeywell How to Find Honeywell Manuals
heatman101
Nov 07, 2010 | Honeywell Programmable Thermostat Heater
make sure not turned on @ tstat to man ,also were you in the heat or cool mode when this occured .
Oct 26, 2008 | Honeywell Programmable Thermostat Heater
Cold air will not turn on
What you can do is you can go to any store for special like bottles that you put inside the AC unit to get cold air.
Thank You!!!!!!!!!!
Jun 23, 2008 | Honeywell CT87B ROUND HEATING&COOLING...
Thermostat
I have seen some thermostats that have a ceramic stem attached to the inside end of the control shaft. The ceramic stem is non-conductive and heat-resistant. If this stem is broken or missing, then turning the knob will have little or no effect.
The solution is to replace the thermostat.
Feb 21, 2008 | Honeywell HZ2110 Utility Heater
Heating & Cooling Logo
119 people viewed this question
Top Honeywell Heating & Cooling Experts
Bill Long
Paul Carew
vance jones
Are you a Honeywell Heating and Cooling Expert? Answer questions, earn points and help others
