Question about Audiovox 8610 Cellular Phone
Audiovox 8610 cell phone screen flashing on and off and is displaying: "Please wait, user data is being restore....[4]". Have tried it with each of two batteries and this is all it will do
I need forget security code
hi Sunil kumar
try this one
note all data will be deleted
*#7780# FOR SOFT-RESET- does not delete user info such as contacts, sms, etc
How to do it:
- at Standby Screen type-in => *#7780#
It will ask for "Restore all phone settings-phone'll restart...."
Then it asks for security code enter factory default => 12345
*#7370# FOR HARD-RESET- deletes all user info
How to do it:
- at Standby Screen type-in => *#7370#
FOR FLASHING- TOTAL RESTORE: (Do this if your phone does not boot up) - you can say this one gives you the "New" OS, and of course deletes all user info
How to do it:
1) Remove the battery, and then wait for about 20 min or so before putting it back
2) Press and hold these three keys together -Green dial key, Star key[*], Three key [3]
3) switch ON the phone.
4) Do not let go the three keys until you see the WELCOME screen displayed and just let it complete the boot process
Jul 07, 2014 | Nokia E63 Cell Phone
My phone says "please wait. user data is being restore!"
Hi, messages like this are caused by either when you are installing update or an application.
What you will do is this in other to restore back the phone, you will need to flash the phone to restore back the phone memory.
You can use this link to flash the phone and restore back the memory of the phone.The truth is that you cannot unlock the phone for free.
There is a free site you can try out first but it is for soft
unlock not hard unlock.You can use this link for the soft unlock,
then trying out that with this site unlocktotalk.com/UnlockCodeInstructions.htm,
you will now try out the hard unlock with the site below
Note:hard unlock is not free,You will be charged to get your unlock code.
The only way by which you can get the unlock code for free is by calling your service provider
and requesting for your unlock code.
If you service provider refuses to give it to you, then there is no other place where you can
get a free unlock code.
Visit the link below if you are interested in buying the unlock code:
mobileunlocked.com/mobile_unlocking.php
Good luck.
Jun 01, 2010 | UTStarcom Blitz Cell Phone
When I try to charge my Audiovox 8610, the phone beeps & flashes
Either the phone needs a full reset / maybe battery issue / maybe mother board has partly destroyed itself! Lots of luck
Mar 04, 2018 | Audiovox 8610 Cellular Phone
Contact information
When i drove over my lg phone and also smashed the screen, it was still accessible through the data cable to the computer and I was able to download everything and upload to the replacement. If you have the software try it, if not the software may be(will be) far less expensive than a screen eplacement
Jul 12, 2008 | Audiovox 8610 Cellular Phone
"User Data Is Being Restore..."
Ok - been researching this for a year or so - Apparently this is likely to happen if you delete something on the phone like contacts or messages or apps etc. and the phone doesn't have the memory available to handle the process... there is also some data that is added or moved during the shutdown process, so even if it looks ok to go, there might actually be a problem on restart. Not quite a solution, but at least an answer... It would appear from all sources that recovery from this is not possible - I have not found anyone who successfully even reflashed it with original software.
This is my 8th 8915 which is also prone to this - and it fits exactly with the pattern of destruction. I actually was avoiding deleting items via data cable b/c someone advised me that would be bad... turns out to be just the opposite! So watch your memory limits when adding contacts and apps with this phone.
My guess is that this is applicable to the entire family of pantech pn-200,212,215,300 .utstarcom 7025/7075.audiovox 8610, 8900, 8912, 8915, 8920, etc, that were similar
Aug 01, 2007 | Audiovox 8910 Cellular Phone
Charging problems
The phone has manufacturing problem... if you have a warranty, then return it to the seller for repair or replacement, it free.
Oct 18, 2017 | Audiovox CDM8610VM
Phone won't turn on
Just today I had the same problem with my phone. It's not the battery. You are going to have to either take it back to where you bought it from, or get a whole new phone altogether. It's a error with the phone, not the battery.
Nov 17, 2006 | Audiovox CDM8910VW
Wont turn on
My phone is doing the same thing. It wasn't wet or anything. What's the deal? Black screen but green light when charging. Is there anything to be done?
Oct 27, 2006 | Audiovox CDM8910VW
Audiovox 8610 Cellular Phone Logo
70 people viewed this question
Top Audiovox Cell Phones Experts
svicari124
svicari124
Level 1 Expert
Laxman Bisht
Laxman Bisht
Are you an Audiovox Cell Phone Expert? Answer questions, earn points and help others
