Question about ION Audio iTTUSB Turntable
Only the left audio seems to be working - ION Audio iTTUSB Turntable
  • 3 Answers
Try cleaning your cartridge and tonearm connections with a pencil eraser...if that doesn't work you may have a problem with your RCA connections or your tonearm may be going out.
Posted on Dec 13, 2009
I have a Yamaha RX-V2092 with a 7 speaker set up. Purchased new. Everything has worked great until recently. Now the center channel speaker, left front effect speaker & left main speaker short off...
It seems that the main sound processor comes into an error and so seems a fault on the board. Since checking for a component level solution is very tricky as the access is not friendly, what could be done initially is to remove and reset the boards, check for faulty connectors that seems to vibrate and bring in these faults. Check the solde joints of the connector pins on the board. Check and solder the processor IC and the allied circuits. If the fault seems to disappear when the set heats up then you must check using a magnifier.Check the solder on the audio driver outputs of the center, main , front and rear are clean.
If not refer and proceed with consensus as a false move can cripple the set.
Oct 28, 2011 | Yamaha RX-V2092
I have an old Sansui 400 receiver. I get no sound from the left channel--both A and B speaker options. The speaker and wires are OK, because they work when hooked to the right channel contacts.
The problem seems to be the left transistor part of the unit. Try this:change A versus B speakers, asuming speaker A was working properly. If still speaker A, now connected to left output does not work, you will probably have transistor malfunction on the left channel of the receiver. Any electronic store will substitute the left transistors.
Good Luck.
Flavio/BRAZIL
Jul 23, 2010 | Sansui Audio Players & Recorders
I have cambridge audio azur 640a amp. Problem I have is only the one speaker is working. Both speakers seem to be ok working off the left speaker terminal. Seems to be problem with output from right...
The fault is on the amp! It sounds like the protection circuit is detecting a surge on the channel and shuts it down to protect the speaker. I would check the semiconductor device(s) for the right channel on the heatsink of the amp. You might even see damage of burning on one!
Dec 29, 2009 | Cambridge Audio Azur 640A Amplifier
No left channel audio on eMachines T6212
Download and install proper driver from;
http://downloads.emachines.com/drivers/audio/D00334-001-002.exe
and check again.
Hope this will work.
Regards;
Hassan
Jul 31, 2009 | Computers & Internet
Left speakers are not working on my onkyo tx-ds575
Check the units internal "menu" settings for speakers and audio. beyond that, there would be an internal problem and neded service. Hope this helps
Jul 05, 2009 | Onkyo TX-DS575 Receiver
Tuner not working - denon AVR 3805
turn left hand knob to select tuner (round knob on top left front side)
Dec 31, 2008 | Denon AVR-3805 Receiver
Need wiring diagram for bmw-483 1000w 4 channel amp bought used
left + goes to the amp left - goes to the + on the right sub and the right - goes to the amp try that
rate pls
Nov 18, 2008 | Nitro BMW-482 Car Audio Amplifier
Connecting
please follow me:-1-bring two audio spliters(split one audio to two audios(from near radio shack).2-connect single end of both one to the right out of dvd and the other to the leftout.now you have 4 jacks.
two audio right channel.
two audio left channel.
connect one right and one left to amplifier input right and left.
connect one right and one left to lcd screen audio in.
enjoy it.
Jan 28, 2008 | Audio Players & Recorders
Suggestion
it seemed to have a problem in the audio preamplifire ,if you know how to just open and check any dry soldering terminal at the audio amp. board regards please don't forget to rate ,thx
Nov 20, 2006 | Panasonic NV-FJ700AM VHS VCR
ION Audio iTTUSB Turntable Logo
112 people viewed this question
Top ION Audio Audio Players & Recorders Experts
 Grubhead
Grubhead
Morne Olivier
Ben Armstrong
Are you an ION Audio Audio Player and Recorder Expert? Answer questions, earn points and help others
