Question about HP Photosmart C5180 All-In-One InkJet Printer
Ac adapter where can i get information or schematic of ac adapter? There is no voltage out.
    President:
  • 4,402 Answers
Http://h10025.www1.hp.com/ewfrf/wc/document?docname=c00709333&lc=en&cc=us&dlc=en&product=1153481&rule=44546#N621
Posted on Jan 24, 2008
Need to know input, polarity and voltage to ensure I have the right adapter.
Complete Guide to Using the Correct Charger or Power ...
www.groovypost.com/.../choose-right-power-adapter-charger-phone-lap...
Jun 24, 2013 - If the device has a DC input of +12V / 5.4A, get an adapter that has a DC output of +12V / 5.4A. If you have a universal adapter, make sure it has the proper current rating ... Ideally, you'll have the same voltage, current and polarity on your ......or hdmi on my laptop .can you say what's the reason for the same.
How to select an AC to DC power adapter - ApogeeKits
www.apogeekits.com/power_adapter_selection.htm
An explanation of regulated versus un-regulated AC to DC voltage power adapters. ...voltage output power adapters and how to use this information to select the right one... Some (more expensive) DC voltage output power adapters have voltage ... Care should be take to ensure that the maximum input voltage of the load ...
AC/DC Power adapter ' Laptop Parts 101
www.laptopparts101.com > Laptop parts
Dec 26, 2008 - It's very important to use the right adapter for your laptop. ... Polarityon the new adapter's plug must be the same as on the original ... AC/DC power adapter voltage and amperage ..... I have purchased an non-hp dc-dc convertor (150W), 12Vinput, 19V output. .... So the cable component has to be replace.
Determining Proper A/C Polarity - Galen Carol Audio
www.gcaudio.com > Resources > How-To's
Jan 10, 2016 | Computers & Internet
What is the AC adapter specs on the charger for the T5000
No polarity. The adaptor puts out AC , low voltage. Just traced the schematic and found out.
May 04, 2013 | Motorola TalkAbout T5000 2-Way Radio
HI, unfortunately I lost the power adapter of my Gemini FX 7000. I want to replace it with a universal power adapter with the accurate voltage but the connector is quite weird for a power supply (RJ 45)...
Don't even think of using a universal adapter !!! I could not find the schematic of this unit, but other Gemini mixers like this use center tapped AC power transformers. Any universal adapter will be DC, not AC. I have found that the FX7000 indeed uses an 18 VAC adapter... Try this as a source:
http://www.topdjgear.com/gemini-110vac18v.html
Jul 05, 2011 | Gemini Sound Products Gemini FX7000 10...
What is the DC voltage, current, and polarity of AC adapter
Howya mate , i wouldn't use a adapter which your not 100% sure belongs to it , even something you'll have the right connection and the right voltage on the plug it will still fry the chip or electrics cause the designers of the item designs adapters in such a way the voltage might be the same but the current is altered and that's why you have to buy a replacement adapter at double the price.
Aug 19, 2009 | Office Equipment & Supplies
Use Sony ICF-C1IPMK2 in Europe
A transformer type (Linear Mode Power Supply) AC to DC power adapter with a 9.V nominal output, measures about 12.V without load when tested with a multimeter. A power adapter with a nominal output of 7.5 V, measures a little over 9.V. Considering a number of people across different forums reported the adapter's measured power output as 12.V, I think the nominal rating of the AC to DC adapter should be 9.V. However, keep away from Switch Mode Power Supplies.
Jul 21, 2009 | Sony ICF-C1IP White Powered Speaker System...
AC Adapter melting
It could be a fault with your laptop which is drawing more current than what the AC adapters can supply.
OR
The adapters are under too powered for your laptop.
Check the voltage and current rating requirements of your laptop, this information is printed on a label on the bottom of the laptop.
The adapter should have the same voltage and current rating or same voltage with a higher current rating.
Jan 28, 2009 | Compaq Presario Notebook
Missing AC adapter
If you look at your DVD player, it will have information such as 5V, 2.2A. This information will help you choose the correct AC adaptor. Head over to The Source, FutureShop, BestBuy, etc and bring the DVD player in.
As for a universal AC adaptor. These range from $15 - $50. Just make sure the one you get has the correct plug and voltage/amp range and polarity for it. The salesperson should be able to help.
Here is a picture of such an adaptor. This is a picture of the back of an electronic device, showing 5V and the polarity. If your player has no information with the AC port, you will need to look for a label on the device with this information.
Dec 01, 2008 | Mintek MDP-5860 Portable DVD Player
Camera lense
There is a very very easy way to fix this problem..
This can happen if...
1.) If the battery dies when the camera lens is open (and you close it manually, or sometimes, even if you dont.)
2.) If you used a AC adapter with too much voltage or not enough. (this can happen even if you used the correct voltage, refrain from using AC adapters at all)
... all together its ethier a voltage or camera lens problem...
TIPS:
1.)NEVER PUSH THE LENS IN AFTER CAMERA DIES, BUY A NEW BATTERY IMMEDIATLY AND TURN IT BACK ON, CLOSING THE LENS!
2.)NEVER USE AN AC ADAPTER, USE A RECHARGEABLE BATTERY OR A REGULAR BATTERY!
..to fix this...
Do as i say..
1.) Remove battery
2.) Remove front plate (screw driver may be needed)
3.) Check all gears, make sure they are correctly fitted in place)
4.) Move the gear manually to make the lens come out.
5.) keep it out, put the front plate back together.
6.) reinsert the battery, turn it on.
or...
1.) Remove the battery.
2.) Wait about 6-8 hours.
3.) Reinsert the battery.
or...
2.) Try hooking it up through AC adapter, put correct voltage.
3.) Try turning it on.
4.) Remove AC adapter, reinsert battery.
5.) Turn it on.
Hopefully all this information helped,
May 05, 2008 | Minolta Vectis 2000 APS APS Point and...
Bad adapter?
Dear Kerman,
Sounds like AC hum on your adapter; please find out the adpter voltage and polarity, on the adapter tips, maybe you user manual might have the information. Also the current rating of your adapter.
Try a replacement of the same rating and tip polarity.
That might solve the problem.
sidlahora
Jan 31, 2008 | Sangean ATS 818 AM/FM/SW Radio
Schematic / service information for Black and Decker VP 130 battery charger
Power supply for the VP130 is a 4.32v 210ma AC transformer.
The AC supply is fed to the charger battery box where there are two diodes one for each battery.
each battery is 3.6 volts.
Jan 17, 2008 | Dewalt DW056 18 Volt Cordless Impact...
HP Photosmart C5180 All-In-One InkJet Printer Logo
175 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
