Question about LG DLG2524 Gas Dryer
My Whirlpool GOld Ultimate Care II electric dryer is not drying well any longer. It is 5 years old and a load must be run 2-3 times to get it to dry. Please help.
  • 194 Answers
It could be your heating element but if you use dryer sheets take your lint trap out and see how well water will run thru it it may need to be washed in hot soapy water hope this helps
Posted on Dec 13, 2009
3 Suggested Answers
david04928
  • 102 Answers
SOURCE: whirlpool ultimate care II dryer: dry clothes sensor
Make sure that the vents are cleaned to include outside. Where it hook on to the dryer make sure that the housing is cleaned also. That should take care of the problem. Thankyou and if you need more help let us know.
Posted on Mar 16, 2009
  • 286 Answers
SOURCE: I have a whirlpool gold ultimate care II electric
first how is the clothes out of the washer? That might not be spinning fast enough in final spin. When was the last time the dryer vents was cleaned. Do you have a flow out the vent? If so then something might be going on with sensors.
Posted on May 19, 2009
My gas dryer has no heat
long dry times are a venting problem. if no heat at all it could be your ignitor, a thermal fuse, or the secondary gas coils, all are replaceable and reasanoblyy cheap between 30-90 dollars usually so its up to u it u want to repair it.. if long dry times i would unplug the venting from the rear and dry a load if it heats faster than u know ur venting is clogged and u might wanna clean ur ducting and replace that venting tube. also u can go outside while running and see or feel if air is being pushed out while its running hope this helps let me know how it goes
Feb 22, 2010 | Whirlpool LGB6300 Gas Dryer
Whirlpool Ultimate Care II dryer trips breakers.
No way to know unless you do some checking. This video shows how to get into the machine: HERE
I have a repair manual that features the same basic style of dryer you may want to take a look through: HERE
Feb 14, 2010 | Dryers
I have a Whirlpool gold Ultimate Care II gas dryer and 2/3 times the ignitor glows and lights the gas, 1/3 times it won't. When the gas does light, it doesn't seem like it's getting hot enough to do...
I would suggest the coils on the gas valve . Also check the vent to make sure good air flow is getting out of the dryer . Try disconnecting the vent hose and drying a load to determine if maybe the vent is the problem .
Jul 14, 2009 | Whirlpool LGB6300 Gas Dryer
I have a whirlpool gold ultimate care II electric dryer and have to dry everything on high twice to get it dried. any suggestions?
May 18, 2009 | Whirlpool GGQ8831L Gas Dryer
Whirlpool ultimate care II dryer will not dry clothes
does dryer heats up if yes take hose out from back of your dryer run dryer if you have good power air coming out from your dryer i think your dryer is fine you need to clean your air vent. system.
Feb 28, 2009 | Whirlpool Ultimate Care II LSQ9549L Top...
Whirlpool Ultimate Care II Quiet Dry I, LEQ9508PWO
I would suspect the timer is on it's way out the door. Do you have any areas the timer has dead spots? Check the exhaust for any plugging also.Is this only on a first time start up or is it after this dryer has been running? If after running it could be a high temp sensor, that by the time you are playing around with it, the temp has changed.
Jan 24, 2009 | Whirlpool LEQ9858P Electric Dryer
My Whirlpool Dry Model GGQ9858JQ1 turns off in heat mode after a few minutes
HI. thanks for the question. the motor seems to be at fault here. did you clean the venting from the dryer to the outside. , did you clean the lint inside the dryer. if not do that, thanks.
Oct 07, 2008 | Dryers
Whirlpool super cap. electric dryer imperial
element or thermal fuse at top of element housing most likely if either is bad ck vent system before using very long plugged vent can cause overheat long dry times and premature failure of element
Apr 30, 2008 | Whirlpool Ultimate Care II LSQ9564J Top...
LG DLG2524 Gas Dryer Logo
379 people viewed this question
Top LG Dryers Experts
Tim Whalen
Dan Webster
Dan Webster
Mike
Mike
Are you a LG Dryer Expert? Answer questions, earn points and help others
