Question about Vtech mi6896 Trio Cordless Phone
Every handset is showing me connecting ...
When phone call comes in, the base rings, but no handset can be used to answer the phone. They all showing me Connecting ... text in the LCD display. I bought mi6896 a little more than a year ago.
  • 4 more comments
  • van79 Jan 22, 2008
    I have the exact same problem, except it happened to my AT&T cordless phone (base and one extra handset). I've unplugged the battery packs from both phones, disconnected the phone line, and unplugged the base. Nothing has changed. Someone help!
  • Anonymous Jan 26, 2008
    the base rings and answering machine will pick up, but all the hand sets say connecting. I thought it was just one, so I tried to switch the batteries out and then all of the others said it.
  • Anonymous Feb 22, 2008
    Same exact problem as stated by others--very frustrating
  • dgriep Jul 11, 2008
    I have the same problem but my phone #2 comes in and out of service.
    I was wrong...unplugging everything DID eventually work. You just have to let them sit for a while and they will reconnect.
  • myaolemail Nov 09, 2008
    I had the same problem today. Every handset says "Connecting..." The answering machine can still answer incoming calls, but none of the handsets work. Followed the advice from this site: unplugged the base for several minutes. When I plugged it back in, everything is working fine! Thanks!
I am having the same problem. I unplugged everything, and nothing changed. Phone #2 comes back sporadically. Has anyone gotten word from Vtech?
Posted on Jul 11, 2008
Try unplugging the base for a minute and then plug in
Posted on Jan 26, 2008
I had the same problem.
I unplugged the battery from headset 1, plugged it back in & all was back to normal.
Posted on Apr 16, 2008
When answering mode is on I do not want to hear the ringing(4x) tones before going to answering.I've switched off the 'call screen' option. still I hear the ringing although not recording at least.
Just set the ringing volume to off.
You can choose from four ringer volume settings (off, low, medium, and high) separately on each handset or the base.
With the phone in standby, press or on the handset or VOLUME or VOLUME on the base. The handset or base sounds the ringer at that level. Use on the handset or VOLUME on the base to make the ringer volume louder. Use on the handset or VOLUME on the base to make it softer or turn it completely off.
Note: If you set the ringer volume to Off, the handset or base won't ring. Other handsets or base will ring according to their individual settings
May 29, 2015 | Uniden DECT 6.0 Cordless Phone ID
Phone rings once, but then stops ringing and I can't answer the call
If you have a landline, most likely you have a short in it. Not enough to kill line, but, when the 90 volts a.c. comes in to ring it jumps short. The short answers the phone.. It doesn't stop out going but can cause static. Check the line at the box outside. if bad there call your phone company, if good there, trouble is in house
Oct 03, 2017 | Uniden DECT 6.0 Cordless Telephone...
How do i turn off the silent mode on a uniden phone, ive held down the # sign and nothings happening
Silent Mode
You can silence the ringers on the base and all handsets for a specific period of time; the answering system answers any incoming calls without playing anything through the speaker.
With the phone in standby, press and hold # on any handset. The phone prompts you to select the number of hours (1 - 9 or Always On) that you want it to stay in silent mode.
To confirm, press # or just wait about 5 seconds. The phone turns on the answering system and displays Silent Mode On on each handset.After the selected number of hours, the phone automatically exits silent mode. To exit silent mode manually, press and hold # again.
If the phone is in silent mode and you turn off the answering system, the phone exits silent mode.
Multihandset Features To use the features in this section, you need at least 2 handsets.
Your base supports a total of 12 cordless handsets: the one that came with the base and up to 11 DCX160 accessory handsets.You must register accessory handsets to the base before using them. (Handsets that came packaged with the base are already registered.)Handsets that aren't registered display a Not Registered message. For registration instructions, see p. 18, or see the accessory handset manual.If a handset was ever registered to a base, you must reset it before it can register to a new base; see p. 18, or see the accessory handset manual.Conference Calling
When an outside call comes in, two handsets can join in a conference call with the outside caller.
To join a call that's already in progress, just press Talk/flash or SpeSpeSpeaker.To leave the conference call, hang up normally; the other handset remains connected to the call.
Aug 18, 2011 | Uniden DECT 2080-5 Quint Phone
How can i do two way on panasonic 5.8ghz
These directions are for the KX-TG5451, KX-TG5452 and KX-TG5453.
If you want to use the intercom feature, you need to know the handset number for the unit you want to contact. The base is zero. The handset number is set when you register the handsets. So to communicate with the base, press Intercom on the handset followed 0. The base will ring until someone presses Call to answer it (or one minute whichever comes first). (Alternatively, you can use the up/down arrows to select H1, H2, H3 or Base. Then press the right arrow key.)
To communicate between two handsets, press Intercom and then 2 (from handset 1 or 3 to connect with handset 2). Again the handset will ring for one minute or until the person with handset 2 answers. (To answer, they can press the phone, speaker or intercom button.)
If someone at the base wants to use the intercom, they need to press Select until the appropriate handset number is displayed. Then press Call.
To transfer a call, press Intercom and then select the desired handset. When the intercom message is picked up, indicate that a call is being transferred and press Off at the handset or base that initially answered the call.
For a conference call, initiate the call then press Intercom and select the handset to join the conversation. Once that person picks up, then press Conf. (I believe that Conf is a softkey so check the display.) This is only possible with the handset. (Another handset can join the conference by pressing the phone or speaker button on that unit.)
The manual for the KXTG5453 is available here: http://service.us.panasonic.com/OPERMANPDF/KXTG5451S.PDF .
If you have a different model of the Panasonic 5.8 GHz phone, please add a comment with the model number and I'll try to give the directions for that unit.
I hope this helps.
Aug 11, 2011 | Panasonic KX-TG5453PK 5.8 GHz DSS Cordless...
Base station on SPP-N1000 rings in steady tone when call comes in and continues ringing after handset is answered. Handset rings normally. How do I fix?
Ok IF you can answer the Call and it still continues to ring, then this is a real wired problem, Usually, the "Ring" cycle, is used to "Trigger" a "Alerting" circuit that then makes a sound, when the call is answered, this "Resets" this circuit. Now IF it does continues, to ring AFTER the handset has answered the call as normal, then obviously, either the handset, is sending the correct signal back to the base, and the base is putting the call through, BUT the Ring Circuit, isn't being Reset. The fault, then must be with the base. You will have to get it looked at. As an aside, when does it stop, I mean it must, or that would have been your query too? No? So I assume, that it does eventually, stop, I expect it would, as usually, you would design in a "Watch Dog" circuit, that would, time out, if the circuit, didn't reset itself after a pre-defined period. So, Thats the Diagnosis, you will have to repair or replace. As usual though, remove from power, reset as if new, if still faulty. You know what to do.
Apr 16, 2010 | Sony SPP N1000 Cordless Phone
No dial tone. Base will ring. Handset has no
Check the Battery on the Handset. remove the pwr frm the base unit n connect aft 30 sec. aft this if it still says the same msg, then the handset needs to be replaced.
Mar 03, 2010 | Vtech DECT 6.0 Cordless Phone with Digital...
Uniden 5.8Ghz phone.
You need to reset the main base unit. Unplug the power from the back of the base. While the power is disconnected, press and hold the delete key while reconnecting the power. Wait for a long beep tone. When the display shows 88 or P, press play button one time. If you have a phone without an answering machine, disconnect the power from the back of the base, press and hold find hs button while reconnecting power.
Jan 20, 2008 | Uniden Cordless Phone
Phone rings, but once answered its not possible to hear a voice.
Similar issue - brand new phone - but incoming calls (skype or landline) would ring - and then nothing, and outgoing calls the handset would just reset.
The handset would just lose signal constantly (less than 2 meters from the base station).
The phone shipped with the latest software - but eventually I reinstalled it - no change, then de-registered the handset, powered everything down and re-registered the handset and that *seems* to have done it .....
So
1 - reflash / re-install latest software from philips website (even if the phone already has the same version)
2 - de-register handset (follow instructions)
3 - unplug base station and remove batteries from handset
4 - turn on base station, put batteries in handset
5 - re register handset (follow instructions in manual)
and that seems to do it.
Nov 18, 2007 | Philips VOIP8411B/37 IP Phone
UNIDEN 5.8 GHZ CORDLESS PHONES
Registering Handsets to the Base
Whichever handset you choose to charge in the base is automatically
registered to the base. Any additional handsets must also be registered to
the base before you can use them.
Be sure both handsets are fully charged.
One at a time, place each handset in the base. The charge/in use LED on
the base begins to flash, indicating the base is registering the handset.
Wait for at least five seconds, then pick up the handset and press
[talk/flash]. If the display shows TALK, the handset is registered. If not,
place the handset in the base to try again.
Press [end] and continue with the next handset.
Note:
Once both handsets are registered, it doesn’t matter which
handset is placed in the base or the charger.
When you charge the handsets, Caller
ID summary screen and the name of
the handset appears.
This can be find from uniden website.
http://www.uniden.com/pdf/DXAI4588-2om.pdf
Oct 17, 2007 | Uniden TRU8885-3HS Digital Cordless Phone
Vtech mi6896 Trio Cordless Phone Logo
430 people viewed this question
Top Vtech Lands Phones Experts
David Burbee
David Burbee
Are you a Vtech Lands Phone Expert? Answer questions, earn points and help others
