Question about Daewoo DTQ-14N2FC 13" TV
How do I hook up a dvd there are only 1 audio and 1 video and I have 3 one red, one white and one yellow on the dvd and a cable
4 Suggested Answers
nfandres
  • 168 Answers
SOURCE: Why won't my TV pick read my portable DVD player?
probably you need to change your input setting using the menu in your tv. use your remote control in finding that menu. good luck!
Posted on Feb 13, 2007
  • 24 Answers
SOURCE: needinformation on how to hook up to tv,with red
need more info what connections does the dvd palyer have and tv in the back?
Posted on Mar 27, 2010
  • 6771 Answers
SOURCE: How to I set it up?
Hook to the back
Posted on Apr 25, 2012
I have a polaroid hdtv 32gsr3000 and trying to hook up a sanyo dvd to and when we play a dvd it has no coler all black and white we are using 3 cables that came with the dvd player.
Make sure you connected wires right both on player and tv. There are Two ways to connect it.
1. Use 3 wires: white, red, yellow. White and red are for audio and yellow is for video. Yellow need to be connect to yellow port on TV and DVD player
2. 5 wires. Again red and white are for audio. And there is another red plus green and blue. Those 3 are for video and have to be connected to corresponding ports on TV and pkayer. Make sure you don't mix up red wires
Dec 03, 2017 | Polaroid Televison & Video
I have the 3 RCA red, yellow, white cables on back of dvd and to tv. Video only plays when I select video 1 under the input. When when I select video 3 only sound and no video. What else can I try?
Sounds like from the symptoms that you have plugged the white and red cables into AV3 input on the back of the Teleivsion and plugged the yellow cable into AV1 on the back of the Television.
Check the cables are all plugged into AV1 input ports on the back of the Television. Red and White go into the Audio inputs and Yellow goes in the video input. Also make sure you have not plugged cables into component inputs on television look for AV1 in on back of Television .
Mar 08, 2015 | RCA Televison & Video
No signal fromdvd player video 1 (av)
yellow is video and red and white are audio you a get by with one audio. i think you are missing your video cable you can get by with two cables just use the white cable as a yellow and plug it into the yellow dvd plug and tv yellow plug and the red will stay hooked up for sound ( you wont have stereo but it should work)
Aug 05, 2012 | Audio Players & Recorders
HOW TO CONNECT
You have 3 options coming out from the DVD player:
1) Composite (Yellow, White, Red)
2) S-Video (Round and Black)
3) Component (Red, Green, Blue)
Composite is the easiest, as both video and audio are taken care of through the 3 connectors.
S-Video has slightly higher quality, but is largely outdated and requires a separate audio cable.
Component has the best quality, but also requires a separate audio cable.
If you have a composite cable (it should have come with the DVD player), then just hook up the Yellow/White/Red cable from the back of the DVD player to the same color connectors on the back of your TV.
S-Video and Component connect in the same manner (respective color to respective color), but you'll need to determine whether your TV can support a separate audio input or not.
Jul 12, 2012 | Yamaha DVD-S540 DVD Player
Trying to hookup a dvd player model #DX-DVD2
You need 3 RCA plugs... generally colored red, white, and yellow. on the back of the DVD player plug the yellow to video out, the red to audio out (stereo), and the white to audio out (mono). The other side of them goes to the back of the TV... the yellow video input 1, the red audio (R) input 1, the white Audio (L) input 1. Then take the cable service round coax cable and screw it into the back of the DVD unit where it says Coax. Get another short coax cable and hook to back of the DVD unit on Cable out, and the other side to the back of the TV under cable/vhs. And that"s it! Hope that helps you!
Chuck
Jun 23, 2012 | Dynex DXDVD2 Player
I don't know which cables to use to hook up my sony plasma to a samsung dvd player, or how to hook it up.
Hi there. To enable your Samsung DVD player to work on your Sony Plasma, you will need two things:
1. The Power cable for the DVD player
2. The Audio(Red and White) and Video(Yellow) cables that should have been provided when the DVD player was bought. If ever these cables are not available, you may buy these at any Hyper Market such as Wal-Mart or a technology store such as Best Buy. These are called Composite Video and Audio Cables.
If you have the previous cables, connect the 3 Audio/Video cables to the back of the Plasma TV, it should contain the appropriate ports. Yellow cable(Video) for the Yellow port. White and Red for the Audio Left(L) and Right(R) ports. Then connect your power, turn the DVD on and switch from TV to other input which should display the Samsung Logo.
Please rate and comment, thank you.
Apr 14, 2011 | Video Game Consoles & Games
I am trying to hook the dvd player up to my old tv and am only getting sound, I am using the red, white and yellow cord.
I hope this will clarify things, you have 3 connections on each end.
DVD
  • Yellow Cable goes on Video Out (Yellow)
  • White Cable goes on Left Audio Out (White)
  • Red Cable goes on Right Audio Out (Red)
TV
  • Yellow Cable goes on Video IN (Yellow)
  • White Cable goes on Left Audio IN (White)
  • Red Cable goes on Right Audio IN (Red)
the coaxial audio connection does NOT need to be connected.
I hope this helps,
Magoo
Mar 10, 2011 | Toshiba SD4990 DVD Player
How do i hook up a nintendo to my tv which cords go where and can someone walk me through it
Round peg into the round hole. Red peg on the red slot. etc. If the wire from the nintendo doesn't fit the slot on the tv then you're in the wrong slot. if the wire from the nintendo fits the slot on the tv (and is the same color if you are using red/white/yellow rca cables) then you're good. here's a hint on connection types (you will not mix): 1. RCA (red/white/yellow round connectors) Red=right audio sound White=left audio sound Yellow=video connect to the slots that look like they want some. 2. Coaxial (stiff cable with a pinner poking out of the end -- same cable that connects you to cable tv) just hook it up by itself; it carries audio and video. 3. Component (red/green/blue)(red/white) two 'bundles' red=red component of video green=green component of video blue=blue component of video red=right audio white=left audio 4. VGA + (red/white) VGA=video (computer monitor cable) red=right audio white=left audio 5. HDMI (flat hdmi cable. you spent $30 on this 3 foot ****) HDMI=audio and video 6. hugs and kisses hugs=video kisses=audio (both sides)
Jul 15, 2009 | Video Game Consoles & Games
DVD plays only in black and white
Hey, I had this problem on Thanksgiving Day, trying to watch a dvd on my mother's HDTV. You should be able to hook up most standard dvd players to hdtvs. First you have 3 cords, mine were red, yellow, and white. The connections go as follows:
HDTV:
Audio| Component. The white cord should be in a white audio slot. The yellow cord should be in a yellow component slot (video) and the red cord should be in a red video component slot labeled Pr/Cr. Make sure you match the component numbers. For instance, if you want to use component one, then hook all of the cords into the slots for component one. Most hdtvs have multiple component hookups ( think multiple "channels" for your game system, dvd player, etc) so it's important that the corresponding cords go to the correct component slots.
DVD:
Match the yellow and white cords to the appropriately colored slots. The red cord should go into the slot labeled component video out Cr/Pr. Not the red audio out. This worked for me. Hope this helps.
May 02, 2008 | Televison & Video
Can't get my dvd/vcr to tape and play back
Color codes for A/V cables:
Yellow: Composite Video
Red: Right Audio Channel
White: Left Audio Channel (mono)
Does your TV have a video & audio OUTPUT on the back of the TV?
If so, will need another set of audio/video cables and you need to connect the yellow cable from the video OUTPUT of the TV to the video INPUT (yellow) of the DVD/VCR and connect the Red cable from the right OUTPUT of the TV to the red INPUT of the DVD/VCR. Then connect the white cable from the left OUTPUT of the TV to the white INPUT of the DVD/VCR. If your TV is not in stereo, just connect up the white cable for mono audio.
If your TV set does NOT have audio/video OUTPUTS, then you will still need another set of audio/video cables and connect the yellow cable from the video OUTPUT of the cable box to the yellow video INPUT of the DVD/VCR and connect either the red or white (or both if possible) to the red or white audio INPUTS of the DVD/VCR.
You need two sets of cables because you want to watch DVD's & tapes on your TV (Path #1) and you want to record the TV channel shows back to your DVD/VCR (Path #2).
Please let me know if I can be of further assistance to you.
Good Luck!
- Jim
Feb 21, 2008 | Televison & Video
Daewoo DTQ-14N2FC 13" TV Logo
27 people viewed this question
Top Daewoo Televison & Video Experts
 Grubhead
Grubhead
Are you a Daewoo Televison and Video Expert? Answer questions, earn points and help others
