Question about Toshiba Satellite P35-S611 Notebook
Toshiba satellite p35-2611 2 inch(1
Toshiba satellite p35-S611 2 inch(1" light white, 1" a little darker) right next to each other blicking vertically across entire screen. its there as soon as the screen comes on at pre boot, post boot and while windows is up... it is transparent so i can see through it... other colors come through no problem... but its very annoying and im guessing its going to lead to a worse problem if i let it continue... any thoughts?
  • Toshiba Master
  • 3,866 Answers
The worse thing it could be is the lcd going out in a very bad way. Yes likely to get wrose over time, No not the video card because it happends on every screen, boot,preboot,and windows so guess what? If you have the lcd replaced you will be looking at a good laptop once again. Price aroung $75-100 bucks where? Ebay of all sources. Thanks I hope this was Very Helpful to you if so lay ing your ratings.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/edwy_1a56970cf1ea4620
Posted on Dec 13, 2009
Got white vertical lines on left side of display
Vertical lines on an LCD screen are not a good sign. This usually means that your screen is going bad.
Jul 21, 2010 | Toshiba Computers & Internet
Left 1/4 of the screen is black( vertical) the remaining has multicolor lines running vertically
This is an issue with your LCD cable that hooks your LCD to your motherboard.
You can try this site for the part.
http://www.laptopking.com/lcdlist.asp
Apr 21, 2010 | Toshiba Satellite P35-S611 Notebook
Harddrive malfunction and white lines on screen about 1 inch wide 3 lines also some light coloured lines
Did you get a solution for this? I would be interested in hearing from you, I have the same display problem. rayfuss[at-nospam]gmail-dotcom
May 18, 2009 | Toshiba Satellite P30 P35 Series Notebook
Toshiba satellite P35-S6111
It is complicated in that you have to unscrew just about the entire case just to get to the motherboard connection for the lcd, but more or less straight forward. Just don't lose the screws or put them back in the wrong holes. I found a number of replacement screens on ebay.
Jan 27, 2009 | Toshiba Satellite P35-S6111 Notebook
Toshiba 52WM48 - Dark line across top of screen about 4 inches
replace the vertical ic, LA 7833 and four capacitors near it, i encountered this last two days.change the parts and it ok now.
cost of this parts is about $20.00
Jan 22, 2009 | Toshiba 42H83 42" Rear Projection...
Thin Vertical lines on the screen
Ebay - new screens $110-$135. Google for step-by-step replacement instructions.
Dec 30, 2008 | Toshiba Satellite P30 P35 Series Notebook
Vertical lines in my laptop screen
what i recommend you to test is to press behind your monitor and see that the line goes off or not.If it does..that mean you have a loose connection,it can be fix.Incase no then you have problem with your LCD.Normally if its LCD problem then you fix this problem,all you have to do is change the LCD.
goodluck,takecare.
May 04, 2008 | Toshiba Satellite P30 P35 Series Notebook
Check it on External monitor prior to replacing the screen.. If the problems there as well its not the screen..
Feb 06, 2008 | Toshiba Satellite P35-S609 Notebook
Screen problem.
Does your LCD look like this or similiar? (below) If it does, there should be a female plug similiar to the picture also below.
Hook smaller end of cable to your laptop, the other end to your external monitor. Turn on your laptop. If the vertical lines are not present then its probably your LCD, which will more than likely have to be replaced. If lines are present, then like tom19511 said it may be the video drivers. I've had this same problem with my Toshiba Satellite p35 5 times already. Toshiba had to replace my LCD each time. LCD's are more expensive than an inverter. Good luck, I hope you get it fixed.
Dec 13, 2007 | Toshiba Satellite P35-S611 Notebook
Toshiba Satellite P35-S611 Notebook Logo
103 people viewed this question
Top Toshiba Computers & Internet Experts
pankaj rautela
pankaj rautela
Alun Cox
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
