Question about Kenmore 55612 / 55614 / 5561 / 655619 Side by Side Refrigerator
Water drains into drip pan at bottom of fridge.
I have been noticed lately that water drains into drip pan at bottom of fridge. Not very much, but enough to concern me. What could be the cause and how do I clean it out?
  • Kenmore Master
  • 4,655 Answers
You should not be concerned about that. It is a good thing that the water goes to the pan. Depending on your Kenmore model number there is a time set either mechanically or electronically to cause the freezer to go into defrost. The defrost water runs down a small pipe and enters that condensate pan where the fan and heat from the compressor and condenser return the moisture back into the room or home. The problem is only when that drain line becomes blocked is when the real problems happen. Please rate me if this helped you or not rate me if I did not answer correctly y explaining more clearly that this is the subject. You can clean the pan with clorox and water but that requires unplugging the refrigerator and pulling away from wall removing cover behind compressor and wiping clean. The only reason you would need to do that is if food or something spoiled inside refrigerator and that would be done through the freezer and back panel. Ask me later about that. Right now I think you are working fine, Thanks, Sea Breeze
Posted on Dec 13, 2009
Testimonial: "thanks for the quick feedback. you definetly saved me the cost of bringing out a repair man. will keep you guys in mind should other concerns pop up"
  • John Tripp
    John Tripp Dec 13, 2009
    .You can find me here at Fixya or=> Here or here=> Sea Breeze Appliance Parts and Technical Services if you need answers let me know! Thank You, Sea Breeze
  • John Tripp
    John Tripp Dec 15, 2009
    Thanks For The Rate wtchdoctr!! I have been so busy trying to help out I just noticed your rate. If you need me remember where to find me, Sea Breeze
I have mold! in the drain on bottom of fridge i assume because of the water dripping down the walls all the time?
Try to put a tray under the fridge to collect the dripping before handling the mold.
Dec 07, 2015 | Liebherr Refrigerators
PLHS267ZA is leaking water from the bottom (freezer side)
I would look under the fridge for a drip pan that might be full, so when it defrost it overflows the pan and runs on the floor. If not that you must have a blockage somewhere in the drain line that runs to the drip pan. Take out the shelves and take off the plastic panels to access the drain and drain line, pour some warm water down the drain to unplug it.
Jan 03, 2014 | Frigidaire PLHS267ZA Side by Side...
Maytag Fridge MFF2558VEM is leaking water from bottom of unit. Suspect a clogged drain hole. Need to access the drip pan and clear drain hole. Drip pan is not behind the toeplate grill at the front
Fridge has a design issue. Duckbill drain valve clogs. They have a new ptrap drain replacement but you have to ask for it, as customer service will deny a problem exists. Here is the service bulletin which was supposed to be for internal use only! https://docs.google.com/file/d/0BzIiBNwRIV4NNWJNNmx0andROGs/edit
Sep 11, 2012 | Maytag MFF2558VEM Bottom Freezer French...
Referring to previous problem. I have defrosted the drip pan, but the water is still pooling up in it. I notice there is a drain hole in the back of the pan, but the water is not draining out of it. I...
It goes through the defrost tube to underneath unit. Poor very hot water in that hole and watch underneath unit where it comes out. If nothing is coming out, then it is still blocked.
Sep 26, 2017 | GE GSS25JF Side by Side Refrigerator
Trickling water noise coming from the bottom of the fridge.
It may be nothing to be concerned about. The water produced during the defrost cycle drains into a pan at the bottom of the refrigerator. This water is then evaporated by heat from the refrigerant coils.
You may be hearing this water dripping into the pan from the tubing that carries it from the inside of the refrigerator.
Oct 10, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
My refrigerator is leaking water underneath it. the ice maker is not hooked up
Is it leaking water INSIDE the fridge at the bottom - if so that is an indication of a clogged defrost drain - if you have a drip cup in your refrigerator, that connects to a tube at the back of your fridge, to carry the water from the defrost cycle down the drip pan at the bottom.
If you see water OUTSIDE your unit, the only explanation is an overflowing drip pan ! Water from the defrost cycle drains and drips on a pan that sits on the compressor or besides it - the hot air from the compressor will cause water in the pan to evaporate quickly - either through a fan or when the pan is placed directly above compressor. If your model has a fan at the bottom next to compressor, that blows the hot air on it, check to see if it's working when compressor cycle is on.
There is no reason for that drip pan to overflow otherwise, it is quite big enough, and the water from the defrost cycle is usually around 2 ounces and should evaporate quickly.
Oct 09, 2009 | Whirlpool Refrigerators
Samsung Fridge Freezer leaking water
hi August.
Cause: A blocked defrost drain is one of the most common causes of water leakage. This happens when food particles or other debris clogs up the drain hose, which can lead to ice buildup and, eventually, water leaking out of the freezer and refrigerator.
3 common refrigerator problems you can easily fix yourself
The freezer drain hose will drain the defrost water into a drip pan at the bottom of the freezer. When this pan becomes full, it will leak water onto the floor. This is a regular maintenance task whenever the freezer defrosts. Empty the drip pan during the defrost cycle.
How to Fix Water Leaking From the Bottom of Freezer
Why is my fridge leaking water on the floor? If the refrigerator is leaking water it's possible that the refrigerator has a clogged or freezing defrost drain. If the defrost drain freezes the defrost water will overflow the drain and drip down to the bottom of the compartment, If enough water accumulates in the bottom it can run out onto the floor.
SOLVED Water leak in refrigerator Refrigerator
Dec 03, 2017 | Samsung CoolTech Plus / Basic Bottom Mount...
Ice and water on the bottom shelf
the blower motor of your fridge which is located at the back panel of your fridge is not running
Mar 06, 2009 | Refrigerators
Drip pan overflow
you could need more freon, because it is causing the pipes to warm up a bit more then they should be, then the condensation builds up. If the problem still percists after you have this checked, i would put a drain hose on it temporairly and aim for a new fridge if it is from before 1994.
Jun 18, 2008 | Kenmore 64702 Top Freezer Refrigerator
Kenmore 55612 / 55614 / 5561 / 655619 Side by Side Refrigerator Logo
224 people viewed this question
Top Kenmore Refrigerators Experts
Sal De
Jim Goldsmith
Jim Goldsmith
rlrguitar
Level 1 Expert
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
