Question about Kenmore Washing Machines
I only get hot water, even when I put it on cold water. What could be the problem?
  • Kenmore Master
  • 43,501 Answers
The problem is probably one of two things.
First check that you have cold water coming to the machine, by taking off the cold hose and then cracking the valve running water into a bucket to make sure there is water coming. While the hose is off make sure that the screen at the washer is not plugged. It will be right inside where you hook the hose up.
If that all checks out then the solenoiud valve is bad. This valve body is the part that you connect the hoses too. There are little electric valves that open and shut to allow the water to flow into your machine. If the cold doesnot open then no water flows.
Verify that you are getting power to the cold side of the vavle before replacing it. But usually it is the valve and not an electrical probelm....
I hope that this will help you to solve your problem!
Thanks for using Fixya!!
Heatman101
Posted on Dec 13, 2009
Water is cold regardless of the setting
I would check the water tempeture knob with a multimeter, u did check the water outlet hoses to see u are getting hot and cold water from them? Also if ur water inlet valve is bad it may only allow cold water or only hot water?
Feb 26, 2015 | Washing Machines
Washer only throws out cold water if i change water to just hot nothing comes out only dipping water and not even hot if i put on warm setting still just cold what should i check first or is it better to...
Is the Hot water hose connected to a Hot Water source? Is that source turned on? It almost sounds like you aren't getting hot water to the spigot.
Good luck,
Mark
Apr 01, 2011 | Washing Machines
Cold water runs hot even when hot water valve is turned off.
check to see if the cold tap is connected to the cold valve on the machine and the hot tap to the hot valve. on the machine it will have cold or c for the cold valve and hot or h for the hot valve. please reply if you need further help.
May 19, 2010 | Washing Machines
F&P GW611 with a cold water trickling in. Looked like a weak solenoid so replaced with a new one part 420148P and no real difference. To get by swapped hot with cold solenoids. Now finding hot water is...
Check 1st if water is flowing well from the hose. hold it over the sink or bucket/if not could be faulty water valve..Put valves back to original as hot may have a reducer to cut down pressure hence the pulsing that you say...
Feb 08, 2010 | Washing Machines
Our temperature control isn't working. If we put
You must have water to both inlets. Even with cold/cold, Your washer will mix the water some. Detergent will not activate if your water is extremely cold as it comes straight from the ground.
Nov 18, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Washer was working fine! Moved washer to new house, and now it will run but only with hot water. put washer on Auto controll, and cold cold or warm cold setting, and it wont even turn on.
Have you tried checking your cold water supply faucet? Are you sure there is cold water running out of that faucet before you hooked up the hose? Is it possible there is a shut off on the supply valve that isn't turned on? Therefore it will not run on cold water setting? This actually happened to me once. We went away for a week and turned the water off for the hot and cold supplys. Came back to do laundry and only turned the hot one on and not the cold. Good luck!
Aug 17, 2009 | Maytag Atlantis MAV6000 Top Load Washer
Kenmore front load washer: no cold water problem
that's odd.
if you choose cold/cold then check your hose orientation. you could have put the hot water to the cold solenoid.
or the wires have been interchange, the hot water wire was plug to the cold solenoid and the cold water wire was plug to the hot water solenoid.
or hot water is still flowing to your cold water line.
if the cold water solenoid is the problem, then there should be no water at all going to the tub.
try to experiment, try to switch to hot/hot and see what would come out...
tnx 4 using fixya,
drcool
Oct 02, 2008 | Kenmore Energy Star 44092 Front Load...
Help my washer wont fill with cold water
they are one unit but before you replace be sure have ckd the screen inside the cold side of the valve if screen is clean and no hum from valve on cold setting change the valve..i don't think sears would even charge more than 200 and probably less
Aug 10, 2008 | Frigidaire Washing Machines
Maytag performa washer hot water runs continuously
Littleone.. please check your instructions.. some washers now dont need Hot water connection to them...they heat their own as part of the efficiency settings on the wash programmes themselves!
Regards Faggly
Mar 19, 2008 | Whirlpool Estate TAWS750PQ 27-Inch Washer
Washing Machines Logo
24 people viewed this question
Sal De
fordexpert
Jim Goldsmith
Jim Goldsmith
