Question about Siemens Dishwashers
How to extend the drain hose Siemens SL34A006UC/22 Dishwasher
I need to extend the drain hose on my Siemens Dishwasher model # SL34A006UC/22. I would like to purchse a longer hose from Siemens. the stock hose is conneted to the machine with a gasketed slip in connection so a universal drain hose is not an easy option.
  • 115 Answers
Get another hose same diamiter and two hose clamps and a splice nipple from hardware store, cut hose to lenght with some extra insert nipple into both hoses and clamp with hose clamps make sure you get them tight.. use a metal nipple as a plastic one may crack when you clamp hoses
Posted on Dec 13, 2009
No power
Hello
Plug the Siemens dishwasher into a working electrical outlet if nothing on the dishwasher is operating. Check the household circuit breaker or fuse and reset or replace as needed.
Push the door closed fully if the dishwasher has power but isn't starting. The unit will not operate if the door is open.
Sep 11, 2011 | Siemens 24 in. SL34A006UC Built-in...
Soap dispenser spring is unsprung
There are three common problems that cause the Soap Dispenser or Cup not toopen. I have a tip that will explain these problems in detail....
Dishwasher Repair Problem Detergent Cup does not Open
heatman101
Apr 24, 2011 | Siemens 24 in. SL34A006UC Built-in...
My dishwasher does not do a final drain at the end. Water always staying in dishwasher
Here is a tip that I wrote that will help you with your dishwasher not drainingproblem...
Dishwasher Problems - Waterwill not drain out
heatman101
Apr 05, 2011 | Siemens 24 in. SL34A006UC Built-in...
Siemens dishwasher sl33a002uc takes 4 to 5 hours to complete a cycle - what is wrong?
Take the control board out, open it up, and resolder the heater relay or replace the control. It may be under the recall and you can get a new control replaced for free.
Feb 07, 2011 | Siemens 24 in. SL34A006UC Built-in...
Why does my siemens dishwasher take 4 hours to finish running
Should only take 120 minutes to run a complete cycle. Your drain pump might not be expelling all the water.
Jul 18, 2010 | Siemens 24 in. SL34A006UC Built-in...
Drain line attachment
It is better to have it hooked to its own drain with a airgap.  Hooking it up to the disposal can create a cross connection with the potable water supply.
Dec 20, 2007 | Siemens 24 in. SL34A006UC Built-in...
Dishwasher won't drain all the way
After cleaning the air gap thingy my machine works fine again. This thing sits on the left lower back side of the machine (left when you are standing in front of the machine). It is a transparent plastic box with 3 hoses attached (drain hose from pump, drain hose to the outside and water). Inside the box is a black plastic float. If debris gets caught in there the float gets stuck.
Solution is to remove the part by pulling the 2 drain hoses out (there is a small black clip holding them in) and unclamp and remove the water hose. Rinse and shake the housing until the float moves freely again and reassemble.
Jul 31, 2006 | Siemens 24 in. SL84A305UC Built-in...
Dishwashers Logo
1,002 people viewed this question
Top Siemens Dishwashers Experts
aliasger yq
Mike
Are you a Siemens Dishwasher Expert? Answer questions, earn points and help others
