Question about Sharp XR-30X Projector
There is no more picture. i thought it was the bulb i replaced the bulb but still no picture or light coming out
  • 2,237 Answers
May be the colorwheel. if the colorwheel doesn't work, the lamp won't light. if the colorwheel and the lamp are ok, replace the ballast/power supply.
Posted on Dec 16, 2009
TV turns on, hear sound but no picture. Bulb isn't coming on. TV goes off after about 2-3 minutes. Bulb was just replaced 5 months ago.
Need the model number of the set and also if any lights on the TV come on or blink when the picture goes out or not.
Feb 09, 2013 | Televison & Video
Picture goes out, comes back, sound is fine
I found several instances of this probllen on various forums, and determined that it is the bulb after all. It seemed that a bulb should either work fine or be burnt out, so I thought it might be something else, but so many other customers had this identical problem that I am 99% sure it is the bulb. I found a replacement bulb with housing for about half the price of the Sony Store, so i ordered it. In the meantime, another customer offered a suggestion to try adjusting the Power setting to Power Saving instead of Standard. I tried this last night and the picture worked fine! I will replace the bulb when it arrives and keep the old one on hand in case this happens in the future. Thanks to all of the posters out there!!!
Dec 07, 2009 | Sony KDF-E55A20 55 in. LCD Television
Problems with mitsubishi WD 65737 tv is locked. what do we do?
problem with mitsubishi wd65737. thought the bulb was bad, bought a new bulb replaced it and now the screen doesnt want to come on. light on the front of the tv turns green, you have sound but no picture then the tv turns off the light on the front is now steady red. resetting the sytem worked yesterday but not today.
Oct 20, 2009 | Mitsubishi WD-73827 73" HDTV DLP TV
Thought the bulb was bad, replaced and still no light.
where did you get the lamp from? if you got it from a reputable dealer, then i'd say the ballast is bad and needs replacing. if you got it from "bob's bulbs", then it may be the lamp. but the only way to test it is to put it in a known good projector.
Sep 11, 2009 | Sanyo PLC XU48 Multimedia Projector
I have no picture on my sony KDF-50WE655
check the fan again with a flash light. I had this same problem and changed out the large fan behind the bulb...no more problem. my brother has the same tv and he has had to replace the fan at least three times.
Jun 08, 2009 | Sony Grand WEGA KDF-50WE655 50" Rear...
Sound but no picture. can not find listing for a bulb
probably is a light. you can easily replace it yourself, but prepare to spend 2 to 3 hundred for thr bulb.
Apr 25, 2009 | Televison & Video
Optima H30 warning
OK, found the solution on the net, you have to use the buttons on the projector instead of the remote to access the menu item.
Aug 25, 2008 | Optoma H30 Multimedia Projector
Minolta X-370 35mm SLR camera won't turn on
that means that your light bulb in your camera is dead. you should replace your light bulb.
Mar 26, 2008 | Minolta X-370S 35mm SLR Camera
Toshiba 52Hmx94
How many times does it blink?
I replaced the ballast in my 62HM84 and it fixed it. The problem was TV would not turn On, Red light solid green light blinked 9 times then TV would try to restart. At first I thought it might of been the bulb, so I replaced it, same results. Next I replaced the ballast which is pretty easy, just take pictures before you remove the light engine so you can go back to the picture to verify the connections when reinstalling.
Dec 25, 2007 | Toshiba 52HM95 52" HDTV Projection...
Sharp XR-30X Projector Logo
174 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
k24674
jasbo
jasbo
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
