Question about Refrigerators
Right side refrigerator door of side by side does not lift when opened. Part on bottom lift appears to be broken. Is it fixable.
    President:
  • 1,218 Answers
Good day,
The cam assembly on the bottom of the door has broken.
Common problem. With the complete make, and model number, go to any appliance parts house that sells parts for your brand. They'll know what you need.
To replace, remove all food from the door. Remove the top bracket of the door, and lift the door off. Replace defective parts, and re-assemble.
Posted on Dec 13, 2009
The refrigerator door on the right hand side is making a noise everytime you open it. What do I do to fix the problem?
The hinge on the door has nylon cam inserts that "lift" the door as you open it. One of these cams is worn or broken.
Oct 16, 2014 | Whirlpool Refrigerators
My side by side refrigerator door swings open (somewhat out of control). It appears that the door stop is no longer working How can I fix this?
There is a self closer stop mechanism under the door between the door and the hinge, The door must be removed by removing the top hinge and lifting off the lower hinge flip the door and you will see a plastic piece which is probably broken there is also a piece on the hinge . Both should be replaced
Feb 27, 2011 | GE Refrigerators
The right door of my Kenmore side by side
You may have a broken cam riser which is located at bottom hinge. Compare the 2 hinges with the doors open. The right side is probably missing 1 piece.
Feb 16, 2010 | Refrigerators
Built in freezer compartment only gets cold on right side and some on back, not left side, bottom or top. Is it fixable or do we replace refrigerator....GE Model GMS10AAMLWW
Try defrosting it for a day or 2, could be ice build up on the coils, just empty it, unplug and leave the door open, have something handy to wipe the water up with as it thaws out.
Aug 22, 2009 | GE GMS10AAM Top Freezer Refrigerator
The washer/spacer on the bottom of my right side door fell off, and the door now rubs when I open it. Can this be replaced?
Yes , order the parts by model number , then remove the 3 top screws (hinge) , then lift door up and off bottom hinge .
Jul 16, 2009 | GE GSS25JFM Side by Side Refrigerator
Fridge motor is loud when doors closed stops when open-3.5 yrs old- first time same problem fixed with replacing sensor 2/08 now sensor broken again???
the fan goes off when door opened and when closes it will turn back on is normal operation of fan and door control --as to noise --fan may be failing ---iced over ----if seal failing will cause unit to run more and allows more moisture into evap which can cause more ice over
Apr 25, 2017 | LG LRFD22850 Bottom Freezer Refrigerator...
Broken hose at the bottom of refrigerater door that feeds into
to remove door there are screws at top door hinge, them and door should lift right off. fold back gasket and you will find a lot of screws under gasket remove them and inner door panel should lift off exposing hoses .
Jan 26, 2009 | Refrigerators
Right Door is making loud popping noise
After reading these posts, I fixed my refrigerator door in less than 5 minutes. The little black plastic cam on the bottom hinge was loose. To fix it, take the hinge cover off of the top with an 8mm socket, and remove the three 8mm screws holding the top hinge on. Remove the door by lifting up off of the bottom hinge and set it aside. On the bottom hinge is a black plastic cam held on by an 8mm screw. The screw on mine was really loose. Tightening it and putting the door back on made it work like new. You probably don't have a bad cam, just a loose one.
Sep 12, 2008 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Ice chute door does not open
the solenoid is right beside the ice chute door. there is an arm coming off he door to the side and the solenoid has a stirrup hooked to the arm. you have to remove the trim surrounding the dispenser area to access this stuff. you don't repair the solenoid you replace it. ca. 20 bucks for the part
Apr 25, 2008 | Maytag MFD2560HES Bottom Freezer French...
Bottom hinge on fridge door broken
Yes, there is supposed to be a plastic bushing/washer under there. Usually 1/8 inch thick. If a dealer is not handy you may cut some out of plastic to put there. Then undo the top hinge, and carefully lift the door off (you might want to empty the shelfs). Put your spacer on the hinge pin, and replace the door and the top hinge.
Jan 28, 2008 | Liebherr Premium CTP 3153 Top Freezer...
Refrigerators Logo
56 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Marvin
Marvin
