Samsung MAX-945D Hi I have just bought this hifi 2nd hand, but cannot work out how to connect it to my HD tv, for audio output, as there is no instruction manual...can you help is there a downloadable version online... look forward to your reply...thanks
  • rs8399 Jan 21, 2008
    unless there is some free assistance for this problem, i cannot afford to pay for anything... thanks for your help
  • donnaleer Apr 04, 2009
    Hi, I have a similar problem. I have the Max 945D that I just pulled out of storage. When I try to play a CD is get the error code "Code CO" and it moves to the next disc but will not play any. I cannot find the manual.
    Any idea what this problem means or how it can be fixed?
    And . . . can you email me the manual - donnaleeroberts@netscape.net
    Thanks so much!
Purchase an sterio audio cable for computer out put. connect it to the computer output sond, and the on the other side connect to both pin in aux. then play sond and press the aux button of your dech samsung_max_945d.
i have this manual, i you need just tell me than i will email. to you.
Posted on Oct 23, 2008
How do I get audio from tv to receiver?
There should be audio output's on your TV and cable box. There are usually multiple options on most newer model a/v equipment. If u check the manual look for the page showing you about the various connections on the back, you're lookin for anything to do with audio output, there are many different types optical, digital, and analog. Again depending on your specific equipment there's almost always at least one way you can connect them
Feb 15, 2015 | Pioneer HTP-071 5.1 3D Home Theater System...
How connect an LCD tv to hi fi when dvd player is connected in hdmi to THE LCD TV?
you need to see if you have audio out on the tv, if so! you need to go from audio out on tv to input on your home stereo! everything played on tv will work through home stereo! if no sound, you have to go to menu on tv and into sound and change TV's output from internal speakers to external output! hope this helps!
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/michael_8fc219ce5f384208
Jun 12, 2017 | Akai LCT2715 27 in. LCD Television
Audio output to hi fi from d530 sff
Yes there is. You can use the same connector you use for headphones / speakers. You need a cable - type depends on your HiFi inputs could you specify what HiFi you have?
Although Jack-2xCinch (Male-Male) should work on standard HiFi towers.
Dec 31, 2011 | HP Computers & Internet
Sony midi Hifi switching itself off
These digital amps are very prone to blow if the speaker wires are shorted so Sony appear to have put in a protection system that mutes the amp when this happens. You have to unplug the amp for a minute till the light goes off, make sure no speaker wires are touching each other and then it should work ok. I found the same problem with one I bought 2nd hand.
Feb 03, 2010 | Sony Audio Players & Recorders
I have just recently bought a second hand PS£
Ohhhhh u got there a problem i had months ago. PS3 only gives u one output signal at a time, that means either u use it hdmi or u use it the normal rca way.Bad thing is that the ppl at sony didnt think of this kind of situation.
What u need to do is go to ur friend's house and use his hd tv to config ur ps3 to the correct output signal(rca), both on video and audio. If u bought the ps3 from ur friend, he should know how to do it, since he had to config it to hd in the first place. Be sure to probe it with the config u are going to use at home :)
Nov 01, 2009 | Sony Playstation 3 (PS3) Console
I am about to receive an LG32LF4700 Freesat/HD TV If I disconnect the SKY Box and connect the TV direct to the Dish cable will I receive Freesat HD channels. Also can I connect an extra bedroom TV into the...
Yes you can split the signal out from the back of the Freesat/HD (not the TV)to the second TV.
Look what outputs are on the Freesat box - the RF (standard cable) output should go to the 2nd TV (TV set to CH3) and the a/v cables,HDMI or DVI cable should go to the new TV - Note:To receive HD the output from the Freesat should be either HDMI,DVI or Composite output (RGB video jacks) with red White for audio. If you have HDMI this is best - it also provides audio.
Oct 28, 2009 | LG 42LC2D 42 in. LCD HDTV
Question regarding audio connections Akai 30" LCD TV
a switch box is needed the s video shares the red/white audio with the yellow rca that is being used already
May 07, 2008 | Televison & Video
HD READY
I have the same TV & I've tried connecting it through "component" & the DVI but neither work & a Virgin media tech says only an HD TV will work 'the boxdoesn't recognise component
Steve
May 05, 2008 | LG RZ32LZ50 32 in. LCD Television
Game video input enabling
Dear krismedia
You should first confirm that Audio/Video output cable from the hifi is connected to the TV , then you should connect the game console to the input section in ur hifi system. And finally see if the TV is in AV mode and also see if the HIFI is detecting in the input mode.
Dec 12, 2007 | Sony MHC-RV777D 220 Volt Hi-Fi Music...
376 people viewed this question
 Grubhead
Grubhead
