Question about ASUS Eee PC 1000H Laptop
Asus PC ee 1000M how to replace LCD display
Asus PC ee 1000M - how to open up the lid so that I can replace the LCD display .
    Guru:
  • 689 Answers
Goto <http://beta.ivancover.com/wiki/index.php?title=Eee_PC_Internal_Upgrades
you might find some good photos of what you need!
Posted on Sep 05, 2010
I put on my asus notebook pc but the screen didn't come on, what should I do?
have you tried hooking up an external monitor. If you can and it works you could possibly have an issue with your lcd panel
Or it could possibly be that your outputting to the wrong screen - most laptops have a "Fn" button that can be pressed in conjunction with a little screen on the keyboard to switch to either internal display or external(say F1 or F2).
there are several problems which cause the screen to experience the blackout.......
JUST TRY THESE SIMPLE STEPS TO SEE IF IT GONNA HELP.
Electrical hitches.
Remove your laptop's battery, unplug the power, hold power the button for 1 to 2 minutes, turn on computer with power plug only, then shutdown, add battery and restart
Magnetic On/Off Switch to detect of Close/Open Lid
Your magnet switch is fubar some how. Open up the speaker cover and see if your lid actuator switch that come in contact with the magnet on your lid cover is stuck or not (find where the magnet is in the back of the front lid cover, trace where the magnet area actually touches the base of the computer and you will find the switch) Workaround, start windows with lid at 30 degree angle
Software
Try Fn + F5 or something like that
Aug 18, 2015 | ASUS Computers & Internet
My ASUS laptop doesn't boot and displays vertical lines when plugged in
Try pressing in near the bottom of the screen near the battery, you should be able to make if flicker and come back to normal, even if you have to keep it pressed in. I have the exact same problem on my U31F.
It's 95% a loose connector inside the screen, or near the hinges.
I'm trying to figure out how to approach it myself, but will probably end up taking to asus for them to fiddle with.
Jun 22, 2012 | Computers & Internet
Vertical lines on lcd d520
Time to replace your LCD Screen. To verify that it is the lcd screen on the laptop, borrow a Monitor from a neighbor, friend, relative or co-worker and plug it into the laptop.
It can be any kind of monitor even the old big fat crt monitors as long as it has a vga cable to connect to your computer's vga port. If so that proves your video card is ok. The video will show on most systems when you reboot without you having to do anything. Some systems will require you to hit the FN (Function key) + F1 thru F12. Hold down the FN key then hit the correct key for displaying on the monitor (F1 thru F12). The correct key will normally have CRT/LCD on it or it will have the icon of a display.
May 14, 2012 | Dell Latitude D520 - Celeron Intel Celeron...
Asus ee pc 900 screen distorted display due to scratch. can this be repaired or replaced
You will need to replace the screen, no fixing that. They run about $50 if you want to replace it yourself (There are how-to videos on YouTube) and are easily found with a Google or Ebay search.
Jun 30, 2011 | ASUS Eee PC 900 Notebook
How to install web cam on asus ee pc
If you have the cd, install the software first, the connect the webcam. When the install device window opens, select install automatically. If it asks for drivers after that, point to the driver folder on the software disk.
Jan 21, 2010 | ASUS Eee PC 1000H Laptop
IE cannot display webpage eventhough wireless network connection is excellent on a brand new asus ee PC
Open IE then in the tool bar click on tools then internet options.
When the internet options box opens click on the advanced tab, at the bottom of the box click on restore advanced settings and then click on the rest tab
close IE then try and see if it works
Hope this helps
Dec 21, 2009 | ASUS Computers & Internet
ASUS EE 1005HAB with Malware issue - Cannot access wireless
Avast is the best solution.Just you unplug the net connection and run the avast scan(from boot scan)
Copy the exe of avast from your pen drive and save it to your local PC.RUN it
Dec 15, 2009 | ASUS Eee PC 1000H Laptop
Asus Eee PC 701 display problem
Your screen is probably delaminating and as it seperates, the lcd inner panel is failing. The screen is going to have to be replaced, they should not be serviced, the bezel on the lid has to be removed and the screen panel replaced. Here is a service manual for the notebook. The below guide takes a few minutes to load because of the pictures, but well worth it.
http://www.r3uk.com/index.php/tech-tips/34-disassembly-guides/78-asus-eeepc-model-4g-disassembly
Oct 04, 2009 | ASUS Eee 4G Notebook
Wireless internet connectivity problem
On an unsecured access point (not WEP or WPA) it should work.
Try here for advice http://forum.eeeuser.com/
Presumably you don't need to set a proxy in Mozilla?
Aug 06, 2008 | ASUS Eee 4G Notebook
ASUS ee Laptop Computer
Go into your graphics card setting and rotate the screen 90 degrees.
Jul 05, 2008 | ASUS Eee 4G Notebook
ASUS Eee PC 1000H Laptop Logo
173 people viewed this question
Top ASUS Computers & Internet Experts
Alun Cox
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
