No sound using component from a digital cable box
I have connected using component from a digital cable box ... thru the receiver to my samsung tv... I am getting video but no sound
  • 757 Answers
Connect the audio out from the digital box to the television.
Posted on Dec 13, 2009
How do I connect Samsung smart TV to a Yamaha receiver and get sound to come out of surround sound speakers?
Generally you will connect the Digital audio or optical audio cable from TV to the input of Receiver. Then using the remote control of Receiver you will program the source for digital audio or optical audio as TV. I am assuming the speakers on the receiver are already connected and working. All you do is then turn on TV and turn on Receiver and select TV on Receiver. The TV audio will play through the receiver. Make sure the TV sound is in Mute.
Aug 07, 2014 | Yamaha Audio Players & Recorders
I bought a Sharp Aquos HDTV. Am trying to use a digital co-ax cable to run tv thru my reciever. I get no sound. there is only 1 place on each device to hook up this cable. Any suggestions?
I dont wish to assume that when you say receiver, you mean sattelite or cable. Since you may be trying to hook this up to a surround sound reciever...
Let me also clarify, if this is the case, the receiver needs to be turned on AND the selection signal device set to TV or AUX wherever it is you've connected the TV.
Now by receiver, if you actually meant cable or sat box, then the Ext antena from that service connects to that units ANT IN.
Then from there on that unit ANT OUT to your TV SIGNAL IN.
If you want the external surround sound and have the connectors for this. Then you need to send them OUT to the Stereo/Surround receiver TV IN.
Now having said that and assuming that your TV does not have the Red and White Audio RCA connectors... Your Sat or Cable box does... You connect those to the surround sound Receiver Audio IN
Hopefully you'll find this useful.
If this has not answered the situation. Please feel free to come back and provide all components your working with. Surround reciever, Sat, cable, DVD, VCR whatever etc. etc... I'd be more than glad to help you through this
Good Luck
Respectfully
Jun 10, 2011 | Audio Players & Recorders
WD-73837 73 in. HDTV TV: hook up the coaxial cable from the tv to the recei...
7.1 surround sound will not work with a coax connection OR Composite (yellow video with Red and White audio). You either need to use an HDMI cable or the Component connection (Red, Green, and Blue connection along with the Red and White audio or the optical audio connection).
May 18, 2010 | Mitsubishi WD-73837 73 in. HDTV
When I connect HDMI from a Time Warner DVR to my Vizio thru a DVI/HDMI adapter, I get no sound. I can only get sound if I use Component input (RGB+ audio R&L). Is this a DVR issue or a Vizio issue?
Use the Time Warner remote and hit the settings button twice. Scroll down to "audio: digital out" and select HDMI. That solved it for me.
The only issue I have now is that I also have component sound outputs going from the cable box to a receiver. When I turn off the TV while the HDMI cable is hooked up to both the box and the tv the sound goes out to the receiver...
Nov 15, 2009 | Vizio P42HD Television
Hi denon to cable box to samsung lcd
Unless you are having res. issues you can use component / optical / coaxial cables to connect all your devices to your denon and from your denon to your tv using component cables also
Feb 25, 2009 | Denon AVR-5803 Receiver
Right cables for connecting devices
You have connected from PC to TV right???
1.To get the video you have to connect to TV
2.Please take a separate cables for to listen audio and to watch video,
for audio connect cables from DVD Player to Home Theater you can listen the audio
for video please connect the HDMI video to TV Where You can enjoy both.
Jan 07, 2009 | Audio Players & Recorders
Cant get the wiring figured out.........
TV is HD correct? Use the Y/CB/CR from the Sat to the TV. Use the Digital optical cable for sound from the sat to the receiver. Use the s-video from the dvd player to the tv and the l/r to the receiver for sound. I would suggest upgrading to another set of Y/CB/CR cables to connect your dvd to the TV and benefit from better picture. Also, buy another optical cable for dvd sound (so you can enjoy surround sound). Your receiver has two optical inputs so youre covered there.
Sep 03, 2008 | Kenwood VR-407 Receiver
No Audio
cant use both hdmi and opti outs try sum setting in blue ray but u nee dto plug all blue ray dish directto samsung hdmi then 1 master digital out form tv to sterio digital i n ok tell samsung your output also
Jan 20, 2008 | Sony STR-DG510 Receiver
No sound from digital cable thru AVR3200 after adding HDTV - DVD plays fine
you need a digital coax cable and then connect it to 6.1 also the digital cable type is not a coomon type so check that also
Jan 04, 2008 | Denon AVR-3200 Receiver
Panasonic legacy connection
s-video is a legacy connection. legacy means obsolete and this will impare your image.
what you should do is connect the cable box and blue ray directly to tv with hdmi cable, then run audio cables back to the reciever from these devices. the vcr and regular dvd player would be routed through the reciever the conventional way. you would have to change the inputs on the tv between the cable box, and blue ray if u have one, and a seperate single tv imput for components running thru the stereo. you would have to use the reciever to select between audio sources, and the video sources between the vcr and dvd only.
Nov 04, 2007 | Panasonic TH-50PHD8UK 50 in. Plasma...
 Grubhead
Grubhead
