Question about Samsung SGH-t639 Cellular Phone
How do i stop the keys from beeping when i use them? it is VERY annoying. otherwise i like the phone so far . the user manusal isnt very helpful on doing things with the phone.
Samsung SGH-D880. Cannot turn off annoying beep
Key tone volume
In Idle mode, press [Volume] to adjust the key tone volume.
You cannot adjust the key tone volume in any other way.....
Please rate this solution
Jun 09, 2009 | Samsung Cell Phones
Remove the sound from the keypad.
hi
well it quite simple
you need to go to your phone Profile section
then under customise profie find the key pad sound option
and turn it off
that will solve your problem
you can create different profile for different situations...some of them are already made for your use by phone manufacturer
thank you
Cheers
May 25, 2009 | Samsung Cell Phones
MY PHONE WONT STOP BEEPING HELP!!!!!!!!!!!!
mine usually does that too! But, I have noticed that if you turn it completely off for about five mins. the problem stops for a long time, maybe like a month or so.
Apr 29, 2009 | Kyocera K312 Cellular Phone
What can I do to stop that annoying beep sound
Usually that "beep" alert is an indication that your phone is NOT on vibrate, but on "beep". Check your side volume keys and make sure that your setting is on vibrate, then click "ok" to confirm your changed preference.
Mar 13, 2009 | LG CHOCOLATE VX8500 Cellular Phone
LG VIEWTY WON'T CHARGE PROPERLY
I've almost thrown my phone out of the window because of this problem. I really need a solution, I tried changing my charger and cleaning out the socket where it goes in but nothing works. it Just keeps beeping and beeping. This isnt really a solution, more of an agreement of how annoying this is!!
Feb 08, 2009 | LG KU990 Viewty
Please stop the annoying beeping when ive been texing
Your problem isn't totally clear but if you mean that it beeps every time you press a button when txting go into you sound settings and turn off your key volume. Otherwise if you've requested delivery reports to say your txt has been delivered to your sender, go into message settings and turn off delivery reports.
Oct 30, 2008 | Cell Phones
Need help
Make sure that in the set-up, you do not have the feature turned on that makes a beep for each minute in use. This is a common cause.
Check the user guide for details.
Jerry G.
Jun 03, 2008 | Samsung SCH-u340 Cellular Phone
PHONE KEEPS BEEPING WHILE RECHARGING
make sure your plug in is all the way inserted into your phone. If it is not completely in your plug-in, then it will make a beeping noise as it connects and disconnects from your phone. ALSO just common sense here, make sure its not just messages coming through.
Oct 14, 2007 | Samsung UpStage SPH-m620 Cellular Phone
Samsung SGH-t639 Cellular Phone Logo
49 people viewed this question
Top Samsung Cell Phones Experts
Ronny Bennett Sr.
Ronny Bennett Sr.
Fotis Papastamatiou
Are you a Samsung Cell Phone Expert? Answer questions, earn points and help others
