Question about Kenmore 24032\24036 Top Load Washer
Machine does not spin clothes dry enough during normal cycles. Often have to give another spin cycle to complete the job.
    Scholar:
  • 82 Answers
The clutch is bad. The clutch is on top of the transimission. You would have to remove the 2 trim pieces on the left and right side of the console, loosen the console and rotate back, remove the cabinet, agitator, pump, motor, and then transmission. The clutch is held on by a retaining ring. Reassemble in the reverse order.
Posted on Dec 13, 2009
Washing machine makes loud knocking noise
drain or drain pipes blocked
bearings gone
Aug 18, 2014 | Washing Machines
My Whirlpool spins... It just does not do a very good job
It's very possible that the impeller in the drain pump is striping out and not allowing the pump to get up to high enough spin to completely drain.
Jan 16, 2014 | Whirlpool Cabrio WTW6600SBT Top Load...
Ge washing machine fills up with water on spin cycle
Sounds like the timer is screwed... Sending out the wrong signals and the dryer is doing the rinse cycle when it should just be the spin cycle. Do t know what your timer looks like in that washer but most now days look like the picture. 11_11_2013_2_52_52_am.png
Aug 16, 2013 | Washing Machines
My Hoover 700 LA Top loading washer does not spin dry clothes after the was cycle ? The drum does not spin fast enough for the clothes to dry out as before.
Just got Hoover 700 la manual top loader 2. hand...it is taking maximum amount of water on low arrange, and takes an hour on delicates. it also spin dries very strongly, just ruined my clothes..what you would suggest folks..
cheers aysh
Jul 06, 2012 | Washing Machines
Kenmore 90 tub spins excessively clockwise during wash cycle.
there should be 2 or 3 springs that hold it, they mite have broke, take off back panel an check.
Jan 04, 2010 | Kenmore 24032\24036 Top Load Washer
My LG TROM wash googd but dosn't want to spin
Check and see what type detergent you are using. I bought regular liquid detergent and the machine began making noise during the spin cycle and the drum would not spin. I was informed that you have to use detergent that is labeled HE (High Efficiency). The regular liquid detergent will suds up during the wash cycle which then causes the drum to slip and not spin during the spin cycle. What you are hearing during the spin cycle is the drum slipping. Unplug your washer for 30 minutes and let it reset. This lets the suds dry out. Run a cycle with no spin to rinse out the drum. This should eliminate your problem. If you have clothes in the machine, run a cycle with no spin, just don’t add any more detergent. Then run the normal cycle with spin a second time with no detergent. I hope this cures your problem.
Apr 11, 2009 | LG TROMM WM2688H 4.0 cu.ft. Front Loading...
Cloths Soaked after Spin Cycle
If the motor has a transmission, it could be stuck in 1st gear. I think the agitator running is normal.
Jan 17, 2009 | LG WM1814CW Front Load Washer
Kenmore front load wet clothes
Before going further it is important to determine if the machine is reaching full spin. Make sure the unit is set to MAX extract and watch the inner tub. The tub should be spin really fast (1000 rpm's or better) during the final spin. If not you have lost one of the phases on the motor.
Jan 08, 2008 | Kenmore Elite 45986 Front Load Washer
Broken washer/dryer
This sounds like a motor control board is faulty. Please load a couple of towels in the machine run it. Watch the machine as it goes through its' cycles.
1. Do the towels tumble when the machine is washing ?
2. When it begins to spin, does it spin one way at a fast pace or does it spin one way and then the other ?
Answering these two questions will help in troubleshooting your problem.
Jan 07, 2008 | Kenmore Elite 45986 Front Load Washer
Washer spins but not enough to extract water from clothes or tub.
Check your exit hose spigot, it may be clogged. This is if your filter is all clean. There should be air for passage in the standpipe behind. Your hose should not fit airtight into the standpipe and neither too deep into it. Snaking out your standpipe would be good too.
Rate me pl.....if helped.
Dec 31, 2007 | Washing Machines
Kenmore 24032\24036 Top Load Washer Logo
169 people viewed this question
Sal De
fordexpert
Jim Goldsmith
Jim Goldsmith
