Question about Pioneer SD-533HD5 53" Rear Projection HDTV
  • Pioneer Master
  • 8,617 Answers
No alot of sets have fuses that are white to begin with. Check it for continuity to see if its blown. If so radio shack should have a replacement.
Posted on Jan 20, 2008
How do i tell if fuse is blown
Switch it with another one that you know works.
Aug 18, 2014 | Cars & Trucks
I have no power to my ignition
check for blown fuse-able links at starter or blown fuse in fuse box under the hood...
Jul 14, 2012 | Isuzu Cars & Trucks
I bought a 1995 volvo 850 tubo and the dash lights do not work What may be the problem
I have the same problem. I found out that the dimmer /rheostat is not working. If you know where the dimmer switch is located, take it out using a small screw driver. After taking it out you will see there are color coded wirings, brown for voltage supply, black for ground dimmer, white supply voltage with headlights, pink output voltage and white/black for grounds with headlights. I jumpered the brown wire to pink wire and put everything back.
Jan 09, 2011 | 1995 Volvo 850
DVD wont open, Fuse is white?
its blown
please rate my help++++Thanks for using FIXYA
May 08, 2010 | Sony SLV-D370P DVD Player/VCR
My envisaion monitor only shows white light
There are two causes for white screen: The connector has worked loose, or the lcd panel 5 volt fuse has blown. 98% fuse blown is not repairable. Must replace the lcd panel.
Monitor Mike
Apr 01, 2010 | Envision 19" Widescreen Flat Panel LCD...
Cant find fuse for headlights on 94 bravada
The 94 Bravada did not use a conventional fuse, instead uses a "fusible link" that comes directly from the starter post and supplied battery voltage to the headlight switch.
The fuse link looks like an ordinary wire with usually a short " white plastic sleeve" that appears to be part of the wire.
The blown fuse link will pull apart easily if it is blown.
Any other questions, let me know.
May 07, 2009 | 1994 Oldsmobile Bravada
Microwave stopped working when i pushed the start button
Yes. The white inside the glass that you are describing is a blown fuse. To find out what size fuse it is look around the base or top of the fuse. You will see engraved something like "125V 5A. You can pick these up at Home Depot or Lowes in the electrical isle. You can also type and enter the word "fuse" and then the size it is. (125V 5A) If you have found this information at all helpfull, please rate my solution. Thanks D. Lange
Apr 23, 2009 | LG Microwave Ovens
I have taken out my standerd sterero in ford fiesta 1996 and cut off the block dont know what wires are what and now clock dont work ant think i have blown the stereo can any one tell me what wires are...
you may have blown the one of the fuses in your car look in the fuse box and check the fuse for the clock ps if you find out what wires are what please let me know as ive got the same problem in my fiesta. cheers kez
Apr 13, 2009 | Car Audio & Video
Blown TV fuse
It is a T type fuse rated at 4 amps.
Jun 05, 2008 | GE 27GT616 27" TV
No power!
The thermal fuse may be blown. The fuse is a white plastic item located behind the back cover on the blower box housing. It has two blue leads attached to it.
  1. Unplug the dryer.
  2. Remove the back cover.
  3. Identify the thermal fuse (white, two blue leads, one screw)
  4. Remove the two blue leads.
  5. Using a multimeter set to ohms, check the continuity of the fuse, it should "peg" the meter if the fuse is good, if the meter does not react, the fuse is blown.
  6. Remove and replace the fuse. Replacements can be found either online or at your nearest Sears.
Nov 01, 2007 | Kenmore 64952 Electric Dryer
Pioneer SD-533HD5 53" Rear Projection HDTV Logo
51 people viewed this question
Top Pioneer Televison & Video Experts
Jaime Hernandez
Are you a Pioneer Televison and Video Expert? Answer questions, earn points and help others
