Question about Whirlpool Duet GHW9150P Front Load Washer
Extremely noisy!!!!!! - Whirlpool Duet GHW9150P Front Load Washer
  • 6,784 Answers
A washing machine may wiggle, rattle or move across the floor. It is often accompanied by excessive, or loud noise. There can be several causes and the problem is worse with some units more than others.The most common cause is an unbalanced wash load. Open the lid/door, and attempt to redistribute the clothing to balance the weight. Heavy loads, especially things like comforters, are more likely to become unbalanced than small loads. If you do a lot of heavy loads, you should consider a heavy duty/large capacity washer when it comes time to replace your current unit. A washer must be level both from side to side as well as from front to back. Washing machines have adjustable feet to enable you to level them. See your manual on how to level your washing machine.The outer tub/basket, is supported by springs, pistons or counterweights to keep it balanced. The weight of all that water in a wash load requires a powerful balancing mechanism. If the balancing system becomes detached from one or more points, it will not be able to balance the load properly. Furthermore, even if everything appears to be in place, as the appliance ages, the springs or pistons/shock absorbers, may begin to wear out and not support as much weigh as needed.
Unplug the washer and open the cabinet. Because of the variety of balancing mechanisms, you will have to inspect your machine to determine how it is balanced. Once you discover the mechanism, then inspect it for integrity. In the case of old parts that appear to be in working order, you may not be able to tell if they need to be replaced. They may be weak but appear to be in good condition. If no other solution resolves the problem, then replacing the balancing springs or other moving support parts may be the best action.Another common cause for excessive movement, or clunking, is the floor on which the washer rests. The washer is heavy and even more so when filled with water. Any floor, other than a concrete slab, will tend to pick up and amplify the vibrations from the machine.There are a couple things you can try. If you have access to the joists under the floor, you may be able to beef up the support. Another thing to try is placing a large sheet of plywood under the washer. It should be 3/4" or even 1" thick and as large as possible to distribute the weight. Use a sheet big enough for both the washer and dryer to sit on. If possible fasten the plywood to the existing floor.
NOTE_ Verify That the shipping system including shipping bolts, spacers and cables are removed. This is a common issue when a new washer is installed.
Posted on Dec 13, 2009
Is it normal for the Pfaff snips cutter to be extremely noisy?
I bought a new Pfaff and was alarmed at how noisy it was, particularly the snips cutter. This was unacceptable and I sent the machine back, but I don't know if all machines with snips make this awful noise.
Apr 05, 2017 | PfaFF Sewing Machines
Brand new fridge extremely noisy now. What's occurring?
Some compressors can be very noisy, but it really depends on the type of noise.
Mar 07, 2015 | Refrigerators
Why is my dewalt grinder extremely noisy
lite grease is washed out to the edg of gear box, just give it a mix so gears get the lub again, good look
Apr 11, 2012 | Saws
HP Pavilion dv6449us laptop noisy fan
you may find replacemente in some electronics shops dedicated to laptops spares.
Nov 27, 2009 | HP Pavilion dv6000z Notebook
LG washer WM2032HS that is extremely noisy now!
If the machine is noisey when spinning it means the seal at the back of the bowl has failed,Letting water past & into the bearings,It is a large job as the whole bowl assembly needs to come out to repair it,Sorry for the bad news,Kind Regards.
Jul 30, 2009 | Washing Machines
Ariston Margarita 2000 NOISY spin cycle....
Remove drum drive belt, and spin drum by hand, if there is any resistance,. or it feels rough or noisy, the the main bearigs have probably failed.
If it is o/k then check motor for worn or noisy bearings,
Please rate my solution.
Thanks.
Jul 24, 2009 | Ariston Technologies Ariston AWD12 Front...
Noisy refrigeration without a icemaker.
Lift the arm up on the icemaker to shut it off some models have a switch on the side of the ice maker you can turn off as well a green indcator light
May 10, 2008 | Refrigerators
Whirlpool Duet GHW9150P Front Load Washer Logo
234 people viewed this question
Dan Webster
Dan Webster
Sal De
