Question about Minolta CF2001 Copier
COF37 error code
Can you tell me how to fix this code so I don't have to call a rep.? It prints blank copies when you tell it to make a black copy and it prints very faint when you tell it to print a color copy.
    President:
  • 4,402 Answers
C0F37: Abnormally high toner density detected by Black ATDC Sensor
Toner density that is 4 % or more higher than the target level is detected ten consecutive times during a printCOF37 error code - 1.gif cycle, ATVC, or image stabilization sequence.
The sensor for this error is in the black imaging unit not the toner hopper. See the steps below. If that doesn't work then visit my website1.gif for contact and I will sell you a full service and or parts manual on CD.
Step
Check Item
Result
Action
Imaging Unit Bk is installed correctly.
NO
Check and correct ATDC
drawer CN of imaging unit Bk.
Each of Imaging Unit Bk contacts makes
NO
Clean or correct.
good contact.
ATDC Sensor harness is open-circuited.
YES
Change Imaging Unit Bk.
Posted on Jan 21, 2008
Epson stylus dx6000 only copy in color mode
Any ink in the black cartridge or can you use clean mode to clean it?
Mar 15, 2014 | Office Equipment & Supplies
Blank copies
you have a registration error , which will require removable of the transfer belt and cleaning of the sensors below the transfer belt
Feb 12, 2014 | Konica Minolta Bizhub C364 Color Copier /...
Have a Canon MP830. in the middle of printing, it came up with error code 6A00, and now all it does is flash the alarm light and copy light. how to fix?
http://www.usa.canon.com/cusa/support/consumer/printers_multifunction/pixma_mp_series/pixma_mp830#BrochuresAndManuals
I would download the manual for windows 7 and see if the 'alarm and copy light flash' error is listed. I could not find it referred to in the support area of the canonusa.com website. Also, you could call 1-800-OK CANON and talk to a rep. about this problem.
Good luck on this repair.
Feb 06, 2011 | Canon PIXMA MP830 All-In-One InkJet...
Error code P9 and P21 appears on screen and when printing or photocopying using color black, blank copies are outputed
hi piz Error code P9 and P21 appears on screen and when printing or photocopying using color black, blank copies are outputed
Apr 29, 2010 | Konica Minolta bizhub C250 All-In-One...
We have a xerox 2520, that has a J2 error code. We can't fix a service rep locally.
1. turn off XD125f
2. Turn on
3. within 4 seconds press, clear, auto, clear, auto. LED Should go blank,
if not try again
4. use copy quantity keys to enter 24, then push start
5. Again use copy quantity keys to enter 7, then push start
6. turn off
when you restart the cartridge count will be set to zero
I have done this twice and never replaced the drum cartridge.
Sep 16, 2008 | Xerox Office Equipment & Supplies
Code cof37
Toner density that is 4 % or more higher than the target level is detected ten consecutive times during a print cycle, ATVC, or image stabilization sequence.
Step
Check Item
Result
Action
NO
NO
Clean or correct.
good contact.
YES
Dec 19, 2007 | Minolta CF2001 Copier
Minolta cf 2001
The sensor for this error is in the black imaging unit not the toner hopper. See the steps below. If that doesn't work then visit my website for contact and I will sell you a full service and or parts manual on CD.
Step
Check Item
Result
Action
NO
NO
Clean or correct.
good contact.
YES
Dec 18, 2007 | Minolta CF2001 Copier
Print and copy comes out blank paper
mac,
please press menu then start black copy (blue button) then fortimes arrow-up (tel.index). machine will switch to maintenance mode and all buttons will flash. press 8 then zero then severaltimes start black copy until error A1
will appear on the lcd. repeat pressing menu nine times and write down the error codes. Plz post them here again.
To leave the mode press stop then 9 then 9.
Dec 06, 2007 | Brother MFC 420CN All-In-One InkJet...
Fault Code COF37
COF37 is a code for ATDC high black density failure. Several different things can cause this code & I assume it does not clear by turning the machine on & off.It may be a dirty sensor or may need a black developer change. Either way I would recommend contacting a tech as the process unit can be tricky to remove.
May 28, 2007 | Minolta CF2001 Copier
250 people viewed this question
Top Minolta Office Equipment & Supplies Experts
Adorjani Laszlo
Norman  J Weimar Jr
Norman J Weimar Jr
Ben
Ben
Are you a Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
