Question about Philips Televison & Video
Free list of codes for a magnavox mru3300 - Philips Televison & Video
  • 7 Answers
I'm not positive but these codes should work, if not try the CODE SEARCH function. I'll post the Code Search instructions first, then I'll post the Brand Codes (list is a bit long so it might take a couple of posts). Let me know if any of this helps you and I'll continue to search for a pdf type of code list for the mru3300 for you.
*CODE SEARCH
If your product does not respond after you have tried all
the codes for your brand, or if your brand is not listed,
try searching for your code by following these steps.
1. Manually turn on the device (TV, VCR, etc.) to be
controlled.
2. Press and hold the CODE SEARCH button until the
red indicator stays on, then release the CODE
SEARCH button.
3. Press and quickly release the desired mode button
(TV, VCR, etc.). The red indicator blinks off once.
4. Press the CHANNEL UP button repeatedly (up to
300 times) until the device to be controlled changes
channel. The red indicator blinks off with each
button press. If you accidentally overshoot the
code required, press the CHANNEL DOWN button
to backtrack through the library until the device
changes channel. Pressing CHANNEL UP changes
direction to forward again.
5. Press and release MUTE to install the code.
Most users will store VCR codes under the VCR button,
Cable codes under CABLE, etc. If (for example) you
want to store a VCR code under CABLE, first follow the
procedure for Direct Code Entry (previous page) and
press CABLE in step 2 of Direct Code Entry, then enter
ANY VCR code in step 3 of Direct Code Entry. Then
follow the steps above for Code Search (or Brand
Search, below). Note: If the device does not have a
CHANNEL UP button, use PLAY (VCR only) or
POWER instead. Code Search starts from the currently
stored 4 digit number under that mode.
Posted on Dec 13, 2009
  • 2 more comments
  • RaeNiCoLe Dec 13, 2009
    Programming a device using the Code Lists:
    Find codes for each device and brand below.
    1. Find codes for each device and brand below.
    2. Press and "HOLD" CODE SEARCH.
    3. Press and release the TV, VCR or Cable button you want to set up. If programming AUX for a device,
    press and release AUX first and then the device to be programmed (TV, VCR or Cable). When the
    selected device button flashes proceed to the next step.
    4. Enter the three digit code from the TV, VCR or Cable Box code lists.
    5. Release CODE SEARCH.
    6. With the device on, press another button, for example CHANNEL UP. If the device responds, no
    further programming is required. If the device does not respond, repeat steps 1-5 using another code
    number from the lists.
    TV Codes
    Admiral
    005
    MTC
    011,019,027
    Amtron
    064
    Multivision
    081
    Akai
    002
    NAD
    018,023
    Anam National
    038
    NEC
    011,014,019,027,038
    AOC
    011,019,027,088
    MTC
    0017,0023
    Bell & Howell
    005
    NEC
    0017,0023
    Candle
    011,027,033
    Panasonic
    012,013,038,086
    Citizen
    011,027,033,064
    Penny
    000,008,011,019,027,068,086
    Colortyme
    011,027,084
    Philco
    006,007,010,011,013,016,019,027
    Concerto
    011,027
    033,035,037,038,043,087,089
    Contec/Cony
    036,037,040,042,064
    Philips
    006,007,010,011
    ,013,016,033,035
    Craig
    064
    037,038,043,066,073
    TV Codes
    • Admiral 005
    • Amtron 064
    • Akai 002
    • Anam National 038
    • AOC 011,019,027,088
    • Bell & Howell 005
    • Candle 011,027,033
    • Citizen 011,027,033,064
    • Colortyme 011,027,084
    • Concerto 011,027
    • Contec/Cony 036,037,040,042,064
    • Craig 064
    • Curtis Mathes 000,011,015,027
    • CXC 064
    • Daewoo 011,019,027
    • Daytron 011,027
    • Dimensia 000
    • Electrohome 006,011,014,027,038,061,068
    • Emerson 011,026,027,028,029,030,031,032,037,042,053,064,065,067,075,076,079
    • Envision 011,027
    • Fisher 017,021,039,041
    • Funai 064
    • GE 000,008,009,011,012,027,038,068,086,089,091
    • Goldstar 003,004,006,011,019,027,037,050
    • Hallmark 011
    • Hitachi 009,011,027,036,037,040,047,048,063,080
    • Infinity 013
    • JBL 013
    • Jensen 011,027
    • JVC 012,024,036,037,040,048,051
    • Kawasho 002,011,027
    • Kenwood 006,011,014,027
    • Kloss Novabeam 035,043
    • KTV 078
    • Loewe 013
    • Luxman 011,027
    • LXI 000,013,018,021,023,054
    • Magnavox 006,007,010,011,013,016,027,033,035,043,066,087,089
    • Marants 013
    • Marantz 011,013,027,069
    • Memorex 005
    • MGA 006,011,014,019,022,027,041,056,061,068
    • Mitsubishi 006,011,014,019,022,027,041,056,061,068
    • MTC 011,019,027
    • Multivision 081
    • NAD 018,023
    • NEC 011,014,019,027,038
    • MTC 0017,0023
    • NEC 0017,0023
    • Panasonic 012,013,038,086
    • Penny 000,008,011,019,027,068,086
    • Philco 006,007,010,011,013,016,019,027,033,035,037,038,043,087,089
    • Philips 006,007,010,011,013,016,033,035,037,038,043,066,073
    • Pioneer 011,027,045,062,093
    • Portland 011,019,027
    • ProScan 000
    • Proton 011,027,037,072
    • Quasar 012,038,092
    • Radio Shack 000,021,025,036,037,059,064
    • RCA 000,006,011,019,027,034,038,044,046,088
    • Realistic 021
    • Sampo 011,027
    • Samsung 006,011,014,015,019,027,036,037,077
    • Sanyo 017,021,039,056,057,058
    • Scott 028,037,064
    • Sears 000,006,011,014,017,018,021,023,027,039,040,041,051,071,083,027,037,050
    • Sharp 011,020,025,027,037,052,053,059,060
    • Signature 005,094
    • Sony 002
    • Soundesign 011,027,033
    • Sylvania 006,007,010,011,013,016,027,033,035,043,049,066,087,089
    • Symphonic 064,076
    • Tatung 038
    • Technics 012
    • Techwood 011,027
    • Teknika 011,019,027,033,037,040,066
    • Telecaption 090
    • TMK 011,027
    • Toshiba 018,021,023,071,085,090
    • Universal 008,009
    • Victor 051
    • Vidtech 019,027
    • Wards 000,005,006,007,008,009,010,013,019,025,027,028,035,043,059,066,076,082,089
    • Yamaha 006,014,019,027
    • Zenith 001
I have a GE universal remote and need the code to program a magnavox TB110MW9 SDTV tuner
Hi Jerry, The link below is a Free 44 page GE universal remote instruction manual, You'll find the high lighted codes on page 32...... CHEERS..
Magnavox.... 5001, 5006, 5007, 5009, 5010, 5014, 5015, 5018, 5021, 5024, 5026, 5032, 5038, 5040, 5041, 5043, 5044, 5047, 5049, 5051, 5072, 5090, 5101, 5134, 5138, 5141, 5151, 5155, 5205, 5210, 5257, 5285, 5308, 5314, 5325, 5368, 5411
https://byjasco.com/sites/default/files/product/manuals/24914_Manual-v2.pdf
Apr 30, 2016 | GE Televison & Video
Ii'm trying to program a magnavox universal remote
My Magnavox STB instructions say that if Magnavox codes do not work you should try Sylvania. My Philips/Magnavox universal remote instructions list the same codes for both so here they are: 002, 009, 109, 118, 209, 309, 402, 408
Nov 16, 2012 | Televison & Video
DIRECTV Universal Remote Remote Control: need direct tv codes for magnavox tv. codes listed...
Try
http://www.remotes.com/
Thanks
Frank
Live-Tech
1-888-361-8511
http://www.mylive-tech.com.
May 17, 2010 | Universal Remote Control DIRECTV Universal...
Goldstar tv code for magnavox remote
Depending on the age of your magnavox remote, it may require a 3 digit or 4 digit code. Check the manual of your magnavox remote and see if it requires 3 or 4 digit codes. Once you know what type of codes the remote requires, use the 3 or 4 digit code banks below. Start with the first code in each listing and continue down the list until you find one that works.
Here is a listing of 3 digit codes for GoldStar TVs:
GOLDSTAR: 002 - 102 - 117 - 207 - 217 - 307 - 502 - 818 - 914
Here is a listing of 4 digit codes for Goldstar TVs:
GOLDSTAR: 0019 - 0030 - 0032 - 0056 - 0178
Aug 06, 2009 | Televison & Video
Need Tivo IR code for Magnavox ZV450MW8 DVD/VCR
Set-up (Programming) procedure is too much to type in here, and is not practical and it will differ brand-to-brand remote controls. If you wish to get more; check the sites linked here. The site has set-up code list & set-up procedure to many popular brand remote controls. The site has general set-up codes to check with TVs and other devices are given, in the order of the 'device's brand name list' in alphabetical order. Set-up code list to many brand remote controls also is given. Pull up older posts. Search the sites by type in the brand name to your device in its search box at the top right part of the display window. It will help you to find the document easily.
http://homenol.blogspot.com/
http://remotesearch.blogspot.com/
http://electrohelponline.blogspot.com/
Programming Notes
• If your device does not respond to the remote after trying all codes listed or your brand is not listed in the code list, use the Auto Code Search method to program your remote.
• Sometimes the first code that "works" with your device may operate only a few functions of your device. There may be another code in the code list that performs more functions. Try other codes from the code list for more functionality.
This is a trial and error procedure; and quiet time consuming. You might have to check different codes said for your device..
Mar 10, 2017 | Televison & Video
Need code,so my dish remote will work with magnavox vcr/dvd
Such a code may or may not exist. If none of the codes listed in your owners manual work (you didn't list a model number so I can't give you specifics)you have 3 options. 1) Contact DishNetwork and see if they have additional codes not listed in the manual. 2) Contact Magnavox and see if the have additional codes to try. 3) Purchase a 3rd party remote that works with both devices.
Jun 03, 2009 | Philips Magnavox DVD/VCR Dual Player
Region free code for Philips Magnavox MWR20V6
Not possible on this product. You need to have a special software hack to get that type of region free operation. The web lists a website in england that says they can do it. I cannot verify this claim. I hope this information helps you with your problem.
Apr 22, 2009 | Philips Magnavox MWR20V6 DVD Recorder/VCR
Remote control code for magnavox dvd/vcr combo
I need codes for my Universal Philips Magnavox remote for a Sanyodvd vcr combo ?
Sep 07, 2007 | Philips Magnavox Learning Universal Remote
Televison & Video Logo
859 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
