I bought a Starbucks Saeco Sirena espresso maker a month. Now it has a problem that the blue water light does not go off even though thereis water. The light is on steadily (not blinking). I just can't reset the light. I tried lifting the watertank, wiping the bottom plug, putting it back. I trieda few times, it still does not work. With the blue waterlight on, the machine simply does not work.
Greatly appreciate your help!
Kan
Comments:
Feb 06, 2008
- The problem is that the blue water light is not blinking. If it is blinking, then priming the unit will solve the problem. But it is not blinking, then nothing can be done --- it is the sensor problem. Anyway, I returned the unit and exchange for a new one.
-   Have a Starbucks Sirena. When I first power it up, there was a blinking blue light. I put water, open the steam valve, and it shot only 4 oz of water and stopped. Turn the valve to off position and back on, another 4 oz of cald water. Blinking light still flashing. Pressing buttons on the front panel doesn't do anything. No other button on the front panel is working except the power one, which turns machine on and off. I took the magnet out of the container, and was sliding it along the machine wall, but was never able to find a position where it will stop blinking (on the bottom it's fully lit, some 2 inches up it's blinking, above that it's lit up again. Have no warranty, and can't replace it. Any help if I go with opening it? Thx.
-   pajonate
Feb 21, 2009
-   I have a steady blue light and the machine has water. I have had the Sirena espresso machine for two months and no problems. What do I do,-   birgitta716
you did the basic stuff if you take the water container in our hand emty off course shake it you feel the level sensor move it will make noise if it doesnt help you have warranty dont mess with it it gonna give them a reason to void the warranty cheers
Comments:
Feb 07, 2008
- in the water tank there a float if that thing move well that a magnet inside the machine were the water container is there a little white sensor that what receive the signal from magnet you have to open the machine if it warranty dont break our head exchange it thanks for using fitya pierre
The problem is that the manual says "Press the on botton, the light will blink and priming will begin" but this is completely inaccurate. If priming is needed the machine will turn on, the "water" light will blink and nothing will happen.
What needs to be done is to turn the machine on and move the steam/hot water knob clockwise. The pump will activate and churn away and then stop. Just repeat this step until water flows to finish priming. HTH
Where in North-Central London can I purchase a replacement gasket for a 1-2 cup vigano stovetop...
(More)
Where in North-Central London can I purchase a replacement gasket for a 1-2 cup vigano stovetop espresso maker?
Is there a way to make the b60 coffee maker run more water to fill cups fuller? mine only fills a...
(More)
Is there a way to make the b60 coffee maker run more water to fill cups fuller? mine only fills a typical coffee cup half full. I run the brew twice to fill up 1 cup. Can this be changed?
How do I clean my braun coffee pot. It came with a spring of some sort to clean it but I cant figure...
(More)
How do I clean my braun coffee pot. It came with a spring of some sort to clean it but I cant figure out what do do with it.
