Question about Bissell 3576 CleanView II Bagless Upright Vacuum
There is no suction, even though the container is empty
The canister the collects the dirt comes apart in the bottom. There is a foam filter ring that you need to take outside and shake out. It fixed out suction problem.
Posted on Apr 03, 2010
  • 8,404 Answers
Your hose is clogged and needs to be cleared. You may have to remove one or both ends of the hose that connects the dirt to the container.
You might have success trying to "back vacuum" the hose. A broom handle is sure to clear the clog, however.
Thanks for posting at FixYa.com
Posted on Dec 13, 2009
Re: Bissell Cleanview 2 - Thank you to the person who knew that the cannister comes apart at the bottom. I've been wondering why dirt & dust was shooting out when I vacuumed. You just kept me from throwing the darn thing in the garbage!! Gracias...
Posted on May 16, 2010
Suction not working. Opened machine and dirt is not going into the bag even though it is empty. Inside of machine is dirty.
Check that the hose is not plugged. If you hang it over a railing, then look down into it, you won't need a second person. Alternately drop a golf ball or a marble through it. If the ball makes it through, then it can't be clogged.
Mar 08, 2015 | Miele S548 Bagged Canister Vacuum
No suction FIRST TIME TO USE
If new take it back. If used remove dirt container and empty. Try running with container detached.
Jan 14, 2015 | Bissell Vacuums
The Hoover switches on and the brush rotates but the actual Hoover doesn't come on?
Hi, is there suction when you open the top of the wand handle?
If no, have you emptied the container. next check the tubes that are removable, you may find there is a blockage of hair and bits, have you removed filter and given it a goos wash.
Jun 04, 2014 | Dyson DC25 All Floors Bagless Upright...
Willl not vacuum up the water
Means the suction is clogged by carpet or other debris take apart and clean as necessary.
Apr 13, 2010 | Hoover SteamVac F5914-900 SpinScrub...
Suction problem? The carpet fiber and pet hair
You've probably got a lesser blockage further down the pipework, which is reducing the airflow. Check everywhere possible for blockages, and also make sure the washable filter is clean and dry.
Feb 05, 2010 | Dyson DC07 Animal Bagless Upright Cyclonic...
Royal vacuum has no suction
If a vacuum has not suction then there has to be something plugged up in the port. You will probably have to remove the bottom. Either with a bag or bagless, find the suction port and usually it's plugged with all kinds of stuff. Sometimes if you have access to compressed air you could blow it out from where the bag hooks up or if bagless where it empties into the container. It's not that unusual for it to plug up. My parents have old old old carpet from I think the 70's, (The shag type that you can use a rake with) and there vacuum is always getting plugged up. Good luck.
Jul 25, 2009 | Hoover U6437-900 / U6439-900 Windtunnel...
No suction on my Electrolux central vacuum in all outlets even though motor is running and there is no clog in the hose.
go to the main unit,you have a blockage where the suction originates.can you disconnect the main suction line to the unit?do that and turn it on.if you have suction then then the main suction tube is blocked.a towel or rag of some sort got sucted in and got caught before it made it to the dirt tank please leave feedback
May 05, 2009 | Electrolux Central Vacuum
Auto-matic suction shut-off didn't resume once tank was emptied
look on the bottom of the tank and there should be a fitting on there take it off and clean..there should be some hind of float inside the tank.turn it right side up and tap on the tank the float might be stuck
Apr 07, 2009 | Kenmore 25512/ 25513 Progressive Canister...
Suction always seems very poor
you have to have something clog somewhere
Feb 09, 2009 | Eureka 5892AVZ Bagless Upright Cyclonic...
Bissell 3576 CleanView II Bagless Upright Vacuum Logo
471 people viewed this question
Top Bissell Vacuums Experts
Jim Parker
Jim Parker
Are you a Bissell Vacuum Expert? Answer questions, earn points and help others
