Question about Viking Kitchen Ranges
Model VGIC3054BSS - 30In gas convection. Switched stove from LP to natural gas. Burners on top do not seem to be as hot as they should be. Flame length from low to high is not significantly different. Changed regulator cap to NAT, adjusted air ent so flame is blue, adjusted valve via screw behind control knob. What am I missing ? Thanks, Paul
CrazyLarry
  • 173 Answers
SOURCE: Gas range top burners hard to light...
Gas burners use propane or natural gas...refer to the manual to see what it takes and sometimes you have a switch to select the proper gas. you can call a gas man to confirm this and correctly tell you whats going on. but he will propably make a trip. good luck
Posted on Aug 31, 2007
Amigaman
  • 248 Answers
SOURCE: cannot adjust flame on gas burner
Is this lp or natural gas? The screw you turned adjusts the low flame only. Did this just start, or has it always done this? Let me know.
Posted on Nov 20, 2007
jumptrout51
  • 3361 Answers
SOURCE: I cannot get a clean blue flame on any of my burners
You have to adjust the air flow to the burner. You are getting too much gas.
Verify the LP orifice changeout is correct.
Posted on Apr 07, 2009
  • 3600 Answers
SOURCE: Installed stove, no flames on burners?
It may still have air in the system, turn on one burner on and allow the gas to flow with a lighter in the path of the gas see if the gas lights of at least explodes I mean until it goes Poof, once it does that if it does not light then pull the top off the stove and adjust the vents on the pipes to focus the flames and how much air is blended in with the gas, also turn the burner so that the holes are half way open, I am not sue about your stove but most have an adjustment by turning the burner 1/4 of a turn to change the flame characteristics. if this does not help post here and I will see what else I can find out on your stove. I need the modle of the stove and the regulator number where the gas hooks up.
Posted on Jul 23, 2009
MNfisherman
  • 11896 Answers
SOURCE: Flame on my Whirlpool gas stove burners are too high on low
either turn down the gas knob or turn knobs to lowest setting without going out. That is about your only options
Posted on Aug 25, 2009
Control knob doesnt adjust flame height?
Use a manometer to insure lp gas pressure is correct. The regulator for the stove may need adjusting. The air mixture adjustment may not be correct for PL as well.
Aug 18, 2014 | DCS Professional RDU305N 30" Pro-Style...
Simmer flame to high
Tighten your spuds down with good fitting wrench till you get that flame how you like it. This video shows how to convert a stove from natural gas to LP gas. It shows you how to adjust them burners though. Take a looksee:
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Nov 17, 2010 | Frigidaire FGF316 Gas Kitchen Range
Oven burner flame is low
0000000.jpgOn top of that safety valve is a nut. Get a good fitting wrench. Turn on the oven and use that good fitting wrench on that nut. Turn it counterclockwise till the flame comes up about midways of the flame spreader. Don't get the flames too high. Midways of the spreader now. LOL
Jan 02, 2009 | Ovens
How do I adjust the flame on my Frigidaire model FGS383BADK stove?
its going to be listed in the installation manual ,not use and care, youre going to need to convert oven for lp gas. i would call the manufacture with the modelk number and ask for hte coorect conversin kit, for such a thing
Nov 03, 2008 | Frigidaire Ovens
I want to convert a tappan stove to lp gas.
hi thanks for the question the brass fitting at the burner unscrews to change from natural gas to lp if its screwed in all the way back that off till you get a nice blue flame do it to all burners thanks the appliance doc
Sep 24, 2008 | Tappan MEF500 Electric Kitchen Range
Magic chef oven
how long have you had the stove?
has the stove been converted from lp to natural?
When the burner that is giving you a problem is on its lowest setting does it go out?
May 14, 2008 | Ovens
Low flame
so you stove was converted from natural gas to LP using WB28K10043 KIT-CONVERSION L.P. ? is this correct?
Aug 23, 2007 | Hotpoint RGB745 Gas Kitchen Range
Flames in oven are WAY too high! Having trouble lowering them.
Did you change the orifice in the regulator? The orifice opening for LP is a different diameter than the opening for Natural Gas. If you've already attempted changing the settings from Natural to LP, you may want to double check the orifice under the regulator cap, or...you may have a regulator problem. You will need to turn the gas off prior to attempting this. The regulator will be located in the back of the oven somewhere near where the gas line connects to the stove. There is a gas orifice that needs to be turned over to change gas settings. "LP" should be present if it is set correctly. Let me know if this helps.
Jul 29, 2007 | Hotpoint RGB745 Gas Kitchen Range
Kitchen Ranges Logo
204 people viewed this question
Top Viking Kitchen Ranges Experts
Steve Allison
Steve Allison
Paul Carew
Craig Butler
Craig Butler
Are you a Viking Kitchen Range Expert? Answer questions, earn points and help others
