Question about Sony DAV-FR1 System
Flashing standby tried unplugging - Sony DAV-FR1 System
Hom do i fix sony cmt-cpz55?
Try unplugging your device, wait a few minutes and plug back and try turning it on.
Sep 18, 2016 | Sony Televison & Video
TV went off, standby timer light flashing
Try unpluging from the wall and theplug back in and try turning back on to reset. Sometimes holding the power button in while pluging back in will reset it, every brand is different for the hard reset.
Scott
Apr 17, 2010 | Sony FD Trinitron WEGA KV-24FS120 24" TV
Standby light continuously flashes with no picture or sound
count the number of blinks; you may have to unplug the set and try to turn on again--if it does not blink in a sequence(3 blinks, a pause etc) the set is in shutdown and many things can cause this.
Aug 06, 2009 | Sony KP-53HS10 TV
Pioneer VSX-918V-K Standby Light Flashes but will not turn on.
unplug it and press the power buton and then hold the power button, and while your holding the power button, plug it back in
hope it worked!!!
Jul 30, 2009 | Pioneer Audio Players & Recorders
Sony Trinitron won't turn on, Standby/Timer light now blinks 2x
your power unit maybe going bad
If you need further help, reach me via phone at https://www.6ya.com/expert/david_eb7ea98642566cc6
Jul 21, 2009 | Televison & Video
Sony Vega TV , On off switch
prolly u need the "D" board replaced--common to give error code of 5 to 6 flashes--unplug and wait to reset and try again
Jul 18, 2009 | Sony FD Trinitron WEGA KV-32FS120 32" TV
Standby lamp flashes
if the lamp light is flashing,remove the lamp and check it there is 98% of possibility that is bad.
May 19, 2009 | Initial HDTV-320 32 in. LCD TV
Tv went off while watching a program power standby red light blinks 6 times then pauses then repeats tried unplugging unit waiting a few minutes then replugged same results nothing. can anyone help me ?...
Here's an excerpt from the Sony Manual online. And the link - http://esupport.sony.com/US/perl/webtree.pl?template=EN&mdl=KDF55XS955&content_id=68&category_id=11&problem_id=52
The POWER/STANDBY (red) indicator flashes three times
If your power/standby indicator is flashing in a pattern of three flashes, this may indicates that the lamp cover is not attached securely. Follow the directions in the Operating Manual under changing your lamp that related to closing and securing the Lamp Cover. Ensure that the Lamp Cover Door is securely fastened by tightening each screw.
The POWER/STANDBY (red) indicator flashes continously
If your power/standby indicator is flashing continuously, and the lamp cover has been secured, your TV may be in need of service.
The POWER/STANDBY indicator is lit up green (not flashing)
A sustained green light indicates your TV is on.
The POWER/STANDBY indicator is lit up red (not flashing)
A sustained red light from your power/standby indicator simply indicates that your TV is in standby mode. This shows you that your TV is ready to be turned on with the remote.
Is it the power light and not the lamp light? If the lamp light is flashing then replace the lamp.
Apr 07, 2009 | Sony Grand WEGA KDF-55XS955 55" Rear...
TV comes on to standby, but with record led flashing. pressing power on , power light turns green for 1 second, click from within unit, back to standby with record led flashing
Initially, have you tried a full hard reset? If not, pls unplug from the mains. Most current devices would reset and revert back to factory default settings (assuming no internal hardware fault) when unplugged for a considerable period of time (a couple of hours).
Pls post back for any development(s) or even the lack of it.
Hope this be of initial help/idea. Good luck and kind regards.
Thank you for using FixYa.
May 01, 2008 | Televison & Video
Sony DAV-FR1 System Logo
85 people viewed this question
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Gyula Lacz
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
