Question about Kodak EasyShare C663 Digital Camera
Memory card I turn it on to auto, and it says internal memory is full...I press menu and it says reading memory card, then it says memory card requires formatting (continue or cancel) i click continue, fomatting will delete everything on memory card (continue or cancel) i click continue, it says formatting... then it says reading memory card...., and then it starts that all over agin, and im back at memory card requires formatting (continue or cancel) ??? I also tried formattiing it through the menu and it still dosent work? What do I do?
  • 2 more comments
  • ktfo Mar 14, 2008
    Have exactly the same problem with the EasyShare C633.
  • Anonymous Apr 09, 2008
    memory card can not open in mobile and i can not make a formate on mobile or my computer
  • judgefatboy Mar 13, 2009
    i have the same problem with my c663 it suks ***, there must be a fix for this if so many folk have the same problem
  • Anonymous Mar 28, 2014
    I tried to format the memory card and it wont work.
I have the same problem!!!
Posted on Apr 28, 2008
    An expert whose answer gotĀ voted for 100 times.
    Sniper:
  • 58 Answers
This cam will work up to 2gb sd/mmc
what's the capacity of your card? if it's above that, it's really not gonna work with this cam
if your card is 2gb or lower
2 possibilities:
defective card - please try another card
camera memory reading problem - arrange repairs with kodak
Posted on Feb 14, 2008
My screen says 'internal memory is full' I have only taken about 50 pictures. I then bought a new memory card but after 3 pictures the same message comes on screen.
You need to look at your image storage settings. Press "Menu", "up/down" and "OK" to choose "Image Storage"; is it set to "auto" or "internal"?
If it's set to "Auto" then there's some reason that it's not recognising your memory card. You should format it. Press "Menu", "up/down" and "OK" to choose "Format" and then select the memory card.
If it's set to "Internal" then you need to set it to "Auto". Then it will use the memory card if it's inserted. (Take the card out to access the photos in Internal Memory.)
Feb 01, 2011 | Kodak EasyShare V1003 Digital Camera
How do i format my sd card
1 Press the Menu button. 2 Press to highlight Setup Menu , then press the OK button. 3 Highlight Format , then press the OK button. 4.Highlight an option, then press the OK button: MEMORY CARD-deletes everything on the card; formats the card. CANCEL-exits without making a change. INTERNAL MEMORY-deletes everything in internal memory including email addresses and album names; formats the internal memory. 5.Highlight Continue Format, then press the OK button. (When the formatting is complete, the Setup menu appears)
Nov 09, 2010 | Kodak EasyShare CX6200 Digital Camera
I have a brand new PENTAX E70L camera, with SD memory card. i took a few photos on it and then turned it off. Now when i turn the camera on it reads -card requires formatting.I press continue , to format...
Make sure you don't have any pics on the internal memory. To be sure, with no card in the camera, go into the menu and find "format" and follow the on-screen instructions. Then, insert the card and go into the menu and do the format thing again to erase the card and optimize it. Use the menu and not the format option the camera has been giving you.
Sep 28, 2010 | Pentax Cameras
Internal memory full
You need to reformat the internal memory of your camera. For you to able to do that press menu, and look for setup then hit OK button Under the setup menu look for format press Ok then choose internal Memory then Hit Ok again to continue.
Please use Memory card 1GB or 2GB SDcard
Dec 06, 2009 | Kodak EasyShare C743 Digital Camera
Internal memory is full
Check the settings for the default storage.
On the camera press "Menu".
In the menu go to the camera settings symbol (camera and wrench).
Go to the "image storage". Is "internal" or "auto" selected?
Is internal selected copy the files to the memory card.
Leave the menu. Press "preview". You'll see only pic's from the internal memory.
Press "Menu" ... "Copy" and choose all.
After that go back to "image storage" and choose "Auto" and -if necessary- delete the files from the internal memory (remove the card before!)
May 17, 2009 | Kodak EasyShare Z740 Digital Camera
Memory full; how to clear
Sounds like you will need to format the internal memory of the camera. This will permanently erase all the data from the internal memory and then you will be able to use it again. To format the memory: Remove the xD card from the camera - Press the Menu button - right arrow to setup - right arrow to format option. You will see format yes or no. Choose Yes and press ok. This will clear the memory so it can be used again.
Apr 28, 2009 | Olympus FE-280 Digital Camera
Camera does not read SD Memory Card
thank you so much this worked great it solved my problem thanks.
Oct 31, 2008 | Kodak EasyShare M863 Digital Camera
Memory card
  • Insert your memory card into your computer's reader if you have one. If not, you can purchase a multi-format USB Memory Card reader from Amazon.com or Buy.com
  • 2 Open up 'My Computer'. You should see it under the list of available drives.
  • 3 Check its contents first to make sure that you have the right drive.
  • 4 In 'My Computer', right-click on the drive and choose 'Format'.
  • 5 Leave all the options as they are and click on 'Start'. This is a non-reversible process so make sure this is what you truly wanted to do in the first place.
  • 6 Once the process is completed, take the memory card out and insert it into your Digital Camera or any other device. Try to browse to it to make sure it works fine now.
  • Jul 03, 2008 | Konica Minolta DiMAGE Xg Digital Camera
    Internal memory photos download to sd card
    1. Ensure memory card is inside camera.
    1. Turn on camera.
    2. Press Review button on back of camera
    3. Then Press Menu Button on back of camera
    4. Select "Image Storage" option (by depressing the joystick on RHS of back of camera).
    5. Select "Internal Memory" option (by depressing the joystick on RHS).
    6. Select "Continue"
    7. Press Menu button.
    8. Press "Review" button
    9. Press "Review" button again.
    10. Press "Menu" button.
    11. Scroll down to "Copy" and select this option by depressing the joystick.
    12. Scroll down to "All", then select by depressing the joystick.
    13. Contents should now copy over from internal memory to SD card.
    14. Don't forget to reselect Auto detection of SD card afterward. This is done by turning camera off then back on again. Press "Review". Press "Menu". Select "Image Storage". Select "Auto". Select "Continue".
    Jun 27, 2008 | Kodak EasyShare C875 Digital Camera
    Cards not working with camera
    If you used the SD/MMC memory card in another brand of camera or device, you may need to format the card in your new EasyShare digital camera. (You may have noticed a "Memory Card Needs Formatting" message when you inserted the card.) CAUTION: Formatting deletes all pictures and videos, including those that are protected. Removing a card during formatting may damage the card. To format the SD/MMC memory card or the internal memory of the camera: Transfer images to the computer before formatting the memory card. Press the camera Menu button. Highlight SETUP MENU, and then press the OK button. Highlight FORMAT, and then press the OK button. Highlight an option - MEMORY CARD (deletes everything on the card), CANCEL (exits without formatting), or INTERNAL MEMORY (deletes everything in internal memory). Press the OK button. Highlight Continue, and then press the OK button. Wait until formatting is finished before removing the card. When formatting is complete, the SETUP MENU is displayed. Press the Menu button to exit the menu.
    Aug 29, 2005 | Kodak EasyShare C360 Digital Camera
    Kodak EasyShare C663 Digital Camera Logo
    396 people viewed this question
    Top Kodak Cameras Experts
    Jerry Greenberg
    Jerry Greenberg
    Computer Links
    Are you a Kodak Camera Expert? Answer questions, earn points and help others
