Question about Garmin NUVI 360 GPS Receiver
My battery is dying quickly (1/2 hour after a full charge). Can I change the batter myself? It looks like the replacement batteries that I see on the internet all have a connector (like a phone battery), so maybe there is no soldering?
  • Garmin Master
  • 2,130 Answers
Please don't try this yourself... you risk damaging the case. You need special tools and you risk damaging the LCD display, costing you much mor ethen the battery.
Please see this link for for more info
http://www.sharc.net/gps_battery_repair.htm
- Jim
Posted on Dec 14, 2009
Testimonial: "thanks for the info!"
Why is my Next book Premium 7 SE is not holding a charge. Loose connection. I have a 2 yr. warranty but cannot find my paperwork. Purchased at Walmart Bowl Green KY. 2012
Tablets use Li Ion batteries. These batteries have what is known as a "memory" if the devices are allowed to drain all the way, this often damages the battery.
Not charging the battery for a full 8-24 hours can also cause the battery to hold a lower charge. For example, when it says "Please put device on charger" you charge it only till it says full then remove (usually a 1 hour to 4 hour charge). This is not an actual full charge and can also damage the batter / cause it not to hold a long charge.
The battery can be replaced, and are usually not very expensive. The last tablet battery I replaced was about $15.00 for the battery itself. Some are a little cheaper.
Most repair shops should be able to perform the repair if the warranty paper can not be found.
Dec 01, 2014 | Computers & Internet
Neato vacuum display will not come on.
Here is a video showing a quick temporary fix and the full fix showing the change of all the electrolytic capacitors.
Jul 04, 2014 | Neato XV11 Vacuum
Took car for a drive and had it up to 95 mi per hour and the car died. Battery was completely dead. Jumped it and it ran for about a block and died again. Replaced the batter and check alternator and both...
If the battery was completely dead, then you either have an immense power drain (unlikely) or your battery or alternator are faulty.
When you say you replaced the battery. Was that with a brand new one?
Assuming your battery is fine and fully charged, then the vehicle should start.
If the vehicle starts, then check your instrument cluster for a charge warning indicator.(typical red battery sign). If this is on, then your battery is not being charged.
You can also check with a multimeter across your battery terminals when switched off. You are looking for a voltage around 12.6 volts.
With the vehicle running, run the same test across the terminals. A healthy alternator should be charging at anywhere around 14Volts.
When running, if the battery voltage is constantly dropping, then you have a faulty charging circuit.
Oct 31, 2012 | Chevrolet Cars & Trucks
Battery dies too quickly
Did you fully charge your battery when you first opened the phone? If not, the battery will never hold a full charge. it tells in the booklet that comes with your phone. Not giving your phone at least 16 hours on the first charge might cause battery trouble later. You may need to replace the battery. I hope this helps.
Mar 21, 2012 | Samsung Behold Cell Phone
After full charge, registers only half-charged.
Your battery need's replacement!!!
You can get a new battery from ebay for under 10.00, just search
insignia pilot battery.. I just got one for my pilot, I guess this wear out fast...!!! Hope that solve's the problem (It Should).
Jul 30, 2009 | Insignia Pilot MP3 Player
My K800i battery dies very quick
Dear Friend,
                 U are saying that u have bought this mobile 2 yrs back so check wither ur battery has been expired and change it.Otherwise switch off ur mobile and put it in charge and check it out the normal standby for any mobile is 2 to 3 hrs.Kindly check it and revert back
Regards,
Aysaam
May 06, 2009 | Sony Ericsson K800i Cellular Phone
Purchased new battery, now NOTEBOOK won't work on battery after full charge
Better you first charge the battery for 16 to 17 hours and recheck the same. If problem persists, change the battery from where you bought it. that battery is faulty. And yes there is no need to install the battery from device manager. Just open the battery compartment and replace the battery with new one.
Feb 13, 2008 | Toshiba Satellite A45-S250 Notebook
Battery
Uhm.. Do you plug it up to your computer to charge? Mine is old and dies after about two hours.. I know I need to replace. But in it's old age I guess (Bought from ebay) it won't charge connect to my computer.. So, maybe if you haven't tried already, to try that. Though, sounds like it's getting old like mine and will need a new battery soon.
Oct 12, 2007 | Philips HDD1630 MP3 Player
Battery dies quickly/ device shuts off randomly
ok maybe you have defective battery replace a new one!! and or you have virus inserted to your memory from your loader or loading station.
Sep 14, 2007 | Philips HDD1630 MP3 Player
Garmin NUVI 360 GPS Receiver Logo
96 people viewed this question
Top Garmin GPS Experts
Marvin
Marvin
Steve
Will Halftowaite
Are you a Garmin GPS Expert? Answer questions, earn points and help others
