Question about Jenn-Air 48" Side-By-Side Built-In Refrigerator, JS48F
There is a vibration, a rotating vibration which stops when you open either door
    Scholar:
  • 82 Answers
It sounds like there is ice build up on your evaporator fan motor. remove food from your freezer and remove the bottom back panel in your freezer. Locate fan and hold the door switch in to see if the fan is hitting something.
Posted on Dec 13, 2009
Loud vibration noise that lasts 5 - 10 minutes. stops when door is opened at that point sound of something rotating slowing to stop. Re and re filter, ran water, turned off ice maker, but no change.
Strange that it slows to stop after the door is opened. I have a new LG French door and the ice maker makes a rotating sound then dumps the ice and the water runs. I do know what it cost to have the repair man come. There is another web site called ask dot com where you can ask a pro, it will cost, but probably not much more than 25-30 bucks. Vibration means that something is loose, just like in a car. Sorry I can't be of more help.
Jan 26, 2018 | Refrigerators
LG DLE3733 loud vibration from bottom
If that vibration is while running it may be from an imbalance of the clothes in the drum. Open the door, when the drum stops reorder the clothes around the drum and see if the rumbling stops.
Jan 22, 2013 | LG DLE3733 Electric Dryer
How stop front loading electric dryer vibration while drum is rotating clothes.
110 means you have a whirlpool dryer. If the filter is on top then I would say you have a bad glide, if the filter is in the door you have a bad wheel, very rare. At any rate you need to open it up and inspect it.
Videos and more on kenmore dryers
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Mar 06, 2012 | Kenmore Dryers
How to check terminals on a dualshock2 ps2 controller
does it stop working?or stopped vibrating?if the vibration stopped then wire connecting to the rotating motor is detached this is the common problem with dual shock because of constant vibration.Solution is to open the controller and connect the loose wire,dust is also a big factor if buttons are already not responding so try also to remove accumulated dust on the button touch board.
Jan 24, 2009 | Sony PS2 Dual Shock 2 Controller...
Noisey fridge freezer
Please check the fallowing:
-Loose flooring or floor not firm.
- Cabinet not level.
- Tubing in contact with cabinet, other tubing or other metal.
- Drip tray vibrating.
- Fan hitting another part or worn fan motor bearings. Unplug the unit and rotate fan manually by your finger.
- Compressor mounting grommets worn or missing; mounting hardware loose or missing.
- Free or loose parts causing or allowing noise during operation
- Check compressor it may contact with tubing or other parts.
- Check the body of your unit is not touching the wall or other object
Jan 25, 2008 | Freezers
Noise
Turn of the circuit breaker before doing this or plug out the power cord..
- check if the fan motor is not stuck up by touching the fan blade by your finger if it rotate freely. If stuck up full out the fan motor and put a little oil and rotate it manually until it turns freely.
- Check and rotate the fan blade manually and be sure that it is not mis align and not touching the fan blade frame.
- Check for loose bolts and screws that cause the fan motor vibration.
- Check for foreign object that obstructing the rotation of the fan motor.
- Check for defective bearing or bushing.
Jan 03, 2008 | Samsung RS2556 Side by Side Refrigerator
Washing machine stops in middle of spin cycle, have to pull control knob out over and over to complete cycle.
If the machine restarts immediately, vibration may be disabling the door closed switch. This switch is designed to stop the machine when the door opens, and if it becomes misaligned any large vibrations may cause it to sense that the door is open. This will not happen usually under the relatively mild vibrations from the wash cycle. Try running it while holding the door down. It can be adjusted but the top usually must be removed to do so.
Nov 30, 2007 | Washing Machines
Jenn-Air 48" Side-By-Side Built-In Refrigerator, JS48F Logo
224 people viewed this question
Top Jenn-Air Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Jose Pino
Are you a Jenn-Air Refrigerator Expert? Answer questions, earn points and help others
