Question about Vacuums
Hoover steam vac dual model F7425900
I have a hoover steam cleaner that the wheel do not rotate
  • vem6 Sep 24, 2008
    I have a new Shop Vac and have misplaced the screws to put the rollers on. Also don't find a manual. It is a 6 gal. model # 9300611 Please help Thanks Verna Milburn email Thanks
  • 1,673 Answers
If you are talking about the brush block, take it out and see if the shaft that goes up into the turbine is broken off, if not, then the turbine has gone bad and will have to be replaced. The turbine is what turns the brushes.
Posted on Jan 21, 2008
Hoover carpet cleaner f5915905 the handle release won't lock. what should I do ?
Repairing the Hoover Steam Vac Deluxe - YouTube
? 6:01
Apr 21, 2009 - Uploaded by general0ne
I think Ill make one for the Dual V steam cleaner and provide some tips on maintenance. Good job ... The ...Missing: lock
Dismantling the Hoover Steam Vac Deluxe - YouTube
? 6:16
Jan 12, 2010 - Uploaded by general0ne
Dismantling the Hoover Steam Vac Deluxe. general0ne .... Aftercleaning the screen as shown on the video ...Missing: f5915905 ‎lock
Nov 29, 2015 | Hoover Vacuums
Brushes stopped turning
check the drive peg that turn the brushes it may have broke and needs replaceing this link is for the manual it will show you how to get the brushes off.
Aug 11, 2012 | Hoover Steam Vac Dual V w/ SpinScrub...
Hoover steam vac dual v carpet cleaner has stopped dispensing soap. Water is still flowing fine
You probably have a solenoid valve which has failed and will not open. This will require replacement of the valve. For temporary use you can mix a soap solution and put it in the rinse tank. The correct mix is 5 ounces of Hoover shampoo to a gallon of hot water.
May 17, 2011 | Hoover Steam Vac Dual V w/ SpinScrub...
I have the hoover automatic dual vac 5. this is the 3rd hoover rug cleaner i purchased and always the same problem the spray underneth the rotator bars hardly dispenses and the floor hardly gets wet, this...
The carpet is not intended to get soaked, like what you see with a spray application. If you are seeing a stream of water in the nozzle/tank during the recovery stroke, this is working properly.
Jan 17, 2010 | Hoover Steam Vac Dual V w/ SpinScrub...
How do you connect the stair and upholstery hose to the hoover steam vac
You can download your manual at under Service and Support - Download Manuals. It's acutally very easy to connect: With cleaner unplugged, open the hose connection port on the top of the suction nozzle (much easier to just follow the pictures than to figure out from my description) and plug in the short hose end. Plug the solution tube into its connection port on the side of the lower unit (in front of the wheel). You'll also want to check out the instructions for cleanup.
Oct 04, 2009 | Hoover Steam Vac Dual V w/ SpinScrub...
Water tank leaks
If the tank is leaking, when removed from the cleaner, it is not user serviceable.
Oct 01, 2009 | Hoover Steam Vac Dual V w/ SpinScrub...
Hoover F5914 SteamVac Deep Cleaner
There is no belt on this model. what is your exact problem?
Nov 06, 2008 | Hoover Steam Vac Dual V w/ SpinScrub...
Hoover Steam Vac
how do i get a manual on how to operate my hoover steam vac dual v spin scrub heated cleaning machine. i bought it used at a flea market and they did not have the manual. can you help me.
Thank you nessa
Oct 11, 2008 | Hoover F7220900 SteamVac V2 Upright Vacuum
Spin brushes spin freely on steam vac when not attached to cleaner indicator screen not dirty speed selector is in high position brushes are clean spin brush indicator when brushes attached to machine...
If this is a Hoover Steam vac, the turbine which drives the brushes is bad. If not a Hoover, then what is it, they are different, need brand and model number.
May 14, 2008 | Vacuums
Vacuums Logo
188 people viewed this question
Top Vacuums Experts
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
