Question about Mitsubishi MSZ-A15NA Split System Air Conditioner
What sq m is covered by a MSZGA71KIT split air con?
    An expert whose answer gotĀ voted for 100 times.
    Sniper:
  • 81 Answers
That should cool up to a 60 metre squared room. I would have the room measured up by a professional and they will also calculate heat loss and recommend the right unit for the job.
Hope this helps I take the time to help you so please rate me
Posted on Jun 28, 2010
I have a split-type aircon (brand: LG) with remote control.It has power and display when i put on batteries. but the aircon unit does not respond to the remote control. what do i do to fix this?...
Lift the front cover of the air con, on the right hand side there is a button or a hole which has a button inside which you can press which is for manual starting of the air con. If this works, then you will know the remote is faulty, if it still doesn't work, check that the isolator switch for the air con hasn't been turned off. There will be 9Or should be) a switch outside next to the air con outdoor unit to switch power on / off to the air con. If not, there should be switch inside the meter box at the front of the house. Make sure they are switched on.
Apr 06, 2016 | LG LSC121PMA Split System Air Conditioner
WHAT IS FAULT CODE 00 01 Ad on Teco LU160DHRA1 Air Con
Carrier Split Air Conditioner Error Codes - AC Error Code
acerrorcode.com/carrier-split-air-conditioner-error-codes.html
Jan 25, 2015 - REMOTE CONTROLLER FOR AIR CONDITIONER (SPLIT TYPE). Carrier Split Air Conditioner Error Codes. 00-01-02-03. 11-12-04-05.
Nov 25, 2015 | Heating & Cooling
How do i open air conditioner to clean filters
A wall unit, split system can be tricky to get. Some filters slip out, some are behind a cover held in by screws, others the complete plastic needs be removed. The filter would be in the section where the air enters the air con.
Other units have the filter behind the return air grill, others a door needs be removed to access the filter rack
May 08, 2015 | Heating & Cooling
Air con dead
Larger split system air con gets power from the external unit while smaller air con gets power from the internal unit. Can you find any power switch or power socket/plug around the external or internal units?
Nov 19, 2013 | Cell Phones
Show me where the filter is located
dear sir /madam
please know what is type your air-con i mean widow type or split type or Central air conditioning's unit .if your air con is window type air conditioner then remove cover (grill) and find there is air filter if your air con split type of then open its cover there down side of cover there.is filter located
if air con is central cooling unit the find out your filter in duct side i mean air blower side where fresh cool air going to your room .
use this method i hope you will find solution of your problems
thank you
please vote!
Sep 06, 2010 | Heating & Cooling
IDEC aircon E5 error what does it mean?
i am air con tech and i face all ready this problem may be it will help u . e5 error is ur air con not have gas becoze of that the low presser switch give error on disply thanks best regard for all. pls let now if its help full
May 27, 2010 | LG LSC183VMA Split System Air Conditioner
White 'dandruff like' flakes blowing from front & back of air con
this stuff is mold and mildew that builds up in the blower and evaporator section of your unit the unit needs to be cleaned out i'm not familar with this particular brand so I cant tell you how to pull it apart but since it is a split system this means the freon lines will most likely have to be pulled loose. you may try removing the covers and vacuming the unit as well as you can and possibly blowing it out with compressed air. aside from that I would recomend alling a qualified service comapny. good luck peyton
Jan 30, 2009 | Maytag MBB1956GES Bottom Freezer...
Mitsubishi MSZ-A15NA Split System Air Conditioner Logo
117 people viewed this question
Top Mitsubishi Heating & Cooling Experts
vince
D. E. Hev
Stuart Slabber
Level 1 Expert
Are you a Mitsubishi Heating and Cooling Expert? Answer questions, earn points and help others
