Question about Dell Dimension 5100 (D51L1) PC Desktop
No powerup I recently moved my computer. Before powering backup, I disconnected everything, opened the side cover, connected my grounding strap, blew out the inside with air duster and vacuumed out the dust. Now the computer will not power up. The green led is lit on the motherboard but it will not start. I checked to make sure all plugs are connected securely. Not sure what to do?
    Genius:
  • 1,067 Answers
Is ram pushed in good cpu setted well video cards pshued in tight power pushed in good main one plus 12 v atx power ? 4 pin
Posted on Jan 20, 2008
6ya staff
SOURCE:
The passenger side electric window will not go down on a Ford F-250. You'll hear a click from inside the door panel but the window does not move.
I would open the door panel up and check to see if everything is connected first. Then if it is I would disconnect the motor then check to see if your getting power to the motor by testing the hot wire (red) to the red lead of your multimeter and the black lead to ground. Also, check the ground wire by connecting the black wire to the red lead of the multimeter and the black lead to ground. If your getting power then your motor is bad. If your not getting power or enough power check your wires. If you don't have a ground then repair the ground wire. I am betting your motor is either bad or something is not connected properly in there.
Nov 04, 2016 | Ford F-250 Cars & Trucks
How do I replace the valve cover gasket on a 2002 Saturn L200, 2.2 engine?
Disconnect the camshaft cover grounding strap.Right side of engine.
Remove ignition module, 4 bolts , and disconnect the electrical connection to it. Pull straight up to remove.
Remove 4 spark plugs.
Remove the coolant pipe bracket.
Remove the fuel line bracket.
Remove the 12 bolts holding down the cover, then pry up around the edges GENTLY to remove. You might want to use a rubber mallet at this stage, just don't overdo hitting it, its cast aluminum..
The gasket around the edge and around the spark plug holes don't need sealant, the new design does away with this.
Now would be a good time to check the wear on the Teflon timing chain shield between the camshaft sprockets.
Installation is in reverse order.
Camshaft cover bolts : Tighten to 89 INCH pounds.
Camshaft Ground Strap Bolt : 89 INCH pounds.
Spark Plugs : 15 FOOT pounds.
Ignition coil to camshaft cover bolts : 71 INCH pounds.
Coolant pipe AND Fuel line bracket bolts: 89 INCH pounds.
Good luck.
Feb 21, 2015 | 2002 Saturn L-Series
Visio e422ar no sound no picture
Just got one of these in. Same problem. You may not have to purchase parts for this one. If you can open the back cover,(there will be two wires still connected to cover upon opening, remove these, to actually pull cover off) be careful. You will find a power supply board on the left side. Take the power supply out. (Be sure your TV has not been plugged in for about 4 hours to reduce shock.) You will need to resolder the pins on resistor RP 12. I found a bad ground. Also resolder pins on Transfomer T2 and T3( these are yellow boxes on top of board). We are are soldering under the board of coarse. Now on the right side of the power supply board, find the signal board. You will see four grounding strips taped in black. Purchase at hardware store, metal tape (used for taping duct work). Retape the four ground straps, while pressing down on these springing ground straps. Many, many times a bad ground will cause problems as described. Replace boards and cover and cover wires (as mentioned on removal). If you cannot do this, take this info to a TV tech. Let me know how this works. Thanks for asking, sincerely Matt of Martins TV Repair.
Jun 04, 2013 | Televison & Video
My monitor went off, is there any other way to turn the desk top computer off other than disconnecting it? Gateway GT5676
The internal components of the computer are sensitive to electrostatic discharge (ESD). Damage to the motherboard, memory modules, and peripheral cards can occur if these parts are exposed to ESD. If you are familiar with and have a grounding strap, use it while handling any internal components. If you do not have a grounding strap, it is a good idea to touch the computer case anywhere on the bare metal prior to disconnecting the power cord.
Jul 22, 2012 | Computers & Internet
My nitro 1600w four channel amp will not power on at all, no glow or power. i gave good ground and power and fuses are good. it worked in the car that i bought it off of
Disconnect all speaker connections and rca cables. Leave power, ground and remote wires intact. Try turning on again. If you still have a protection light your amp is faulty. Hopefully you have warranty. Doub .A thumbs up would be greatly appreciated if this answer is helpful to you. nitro-1600w-four-channel-lv2kkrmxrai4iihdvw4m3np2-2-0.jpg
Sep 07, 2011 | Nitro BMW-486 Car Audio Amplifier
On powerup of Dell Dimension 5100 running Windows XP the computer hangs with diagnostic lights 1, 2 and 3 a steady green and 4 off. The onscreen message is: 300XT BIOS P.N 113-A33437-102 which appears on a...
try this:
Power the PC off, open the case cover, remove/reseat the video card in the slot.
* Power the PC off
* Disconnect the PC power cord from the rear of the PC
* Remove the computer cover
* Move the RTCRST (Clear CMOS) jumper from pins 1/2 and place it on pins 2/3
* Press the PC power button
* Move the jumper back to pins 1/2
* Remove/reseat the video card in the slot
* Replace the power cord and cover and then power the PC on
Hope it helps
Nov 05, 2010 | Dell Dimension 5100 (D51L1) PC Desktop
How to remove dash for heater core removal
1981-87 Models
  1. Disconnect battery ground cable.
  2. Discharge A/C system and disconnect refrigerant and heater lines from unit.
  3. Move shift levers away from dash.
  4. Remove right side cowl trim panel, if equipped.
  5. Remove 4 screws at base and remove glove box.
  6. Remove brace through glove box opening and remove ashtray.
  7. Remove right half of lower reinforcement (7 screws to instrument panel and 1 to cowl side of trim panel).
  8. Disconnect radio ground strap.
  9. Remove right upper air duct by removing mounting screw and pulling duct out through glove box opening.
  10. Remove instrument panel center brace and right instrument panel cluster pivot bolt.
  11. Remove instrument panel cluster, disconnect shift indicator cable and lower steering column.
  12. Remove steering column studs and radio.
  13. Remove scoop connecting heater to center distribution duct (2 screws).
  14. Remove center distribution duct by pulling bottom of dash out to gain clearance.
  15. Remove floor air distribution duct.
  16. Disconnect temperature control cable through glove box.
  17. Remove 7 retaining nuts from firewall and screw that retains assembly to cowl side sheet metal.
  18. Flex dash out and remove heater assembly.
  19. Remove nuts from door arms and remove door arms.
  20. Remove 7 screws to remove cover from housing.
  21. Remove evaporator core.
  22. Reverse procedure to install.
Oct 17, 2009 | 1985 Dodge Ramcharger
Need help with dash removal.
  1. Remove the A-pillar and cowl side Trim Panels
  2. Remove the front floor console.
  3. Depower the supplemental restraint system (SRS).
  4. Remove the instrument panel side finish panels.
  5. Remove the 2 steering column opening cover screws.
  6. Remove the steering column opening cover.
  7. Remove the 3 lower steering column cover screws.
  8. Remove the lower steering column cover.
  9. Disconnect the steering column electrical connectors.
  10. Disconnect the RH side bulkhead electrical connector.
  11. Disconnect the RH side body harness electrical connector.
  12. Remove the 2 parking brake release handle screws.
  13. Disconnect the LH side instrument panel electrical connectors.
  14. CAUTION: To avoid damage to the clockspring, do not allow the steering column shaft to rotate while the intermediate shaft is disconnected.
  15. Remove the pinch bolt..
  16. Disconnect the adjustable pedal electrical connector.
  17. Disconnect the brake light switch electrical connector.
  18. Remove the 2 LH instrument panel center brace bolts..
  19. Remove the 2 LH instrument panel center brace nuts.
  20. Remove the LH instrument panel center brace.
  21. Disconnect the transmission range selector lever cable.
  22. Disconnect the RH side bulkhead electrical connector.
  23. Disconnect the LH side body harness electrical connector.
  24. Remove the 3 ground strap bolts.
  25. Disconnect the inertia switch electrical connector.
  26. Disconnect the RH side instrument panel electrical connectors.
  27. Remove the 2 RH instrument panel center brace bolts.
  28. Disconnect the vacuum connector.
  29. Remove the 2 RH instrument panel center brace nuts.
  30. Remove the RH instrument panel center brace.
  31. Remove the cowl panel grille
  32. Remove the instrument panel bolt located under the cowl panel grille
  33. Remove the instrument panel defroster grille.
  34. CAUTION: To avoid damage to the sunload sensor and electrical connector, remove the grille just enough to disconnect the connector.
  35. Disconnect the sunload sensor electrical connector.
  36. Remove the 2 instrument panel top cowl bolts.
  37. Disconnect the antenna lead-in cable.
  38. Disconnect the RCM electrical connector.
  39. Disconnect the center ground strap bolt.
  40. CAUTION:To avoid damage to the instrument panel, an assistant is required to support the panel before carrying out this step.
      • Before removing the instrument panel make sure all electrical connector wiring is free and not hindered.
  41. Remove the 4 instrument panel bolts.
  42. Remove the instrument panel.
  43. To install, reverse the removal procedure.
Feb 11, 2009 | 2005 Ford Explorer
H950
The backlight power supply in the H950 series suffers from a manufacturing defect. Hansol might replace the unit even if it's not covered by warranty anymore. Contact them.
Otherwise (and if you have electronics skills), replace the electrolytic caps in the monitor's power supply. Take proper high voltage precautions!
  • Disconnect mains
  • Wait at least one day for caps to discharge a bit
  • Remove monitor stand (four screws)
  • Put the monitor face-down on the table, plugs facing to you
  • Remove back cover (snap-in, difficult to open without minor damage) - be cautious: front buttons are connected using a rather short cable, do NOT try to remove front cover
  • Remove EMV casing screws (four screws) and ground wire
  • Disconnect CCFL tubes (four connectors), noting connector orientation
  • Disconnect front buttons pcb
  • Lift EMV casing side facing to you
  • Disconnect power supply board (left) from signal board
  • Unscrew/remove power supply board - caution: C12 is likely to store mains voltage even after days!
  • Replace caps (C34 and C66 are likely failure candidates for IPHS19-S rev1.2 boards; you might also replace C31, C32, and C35 while you are at it) - higher voltage and temperature rating are okay, capacity has to match
  • Assemble everything again
Nov 10, 2008 | Hansol H950 19" LCD Monitor
Dell Dimension 5100 (D51L1) PC Desktop Logo
64 people viewed this question
Ekse
Clive
Clive
Alun Cox
