Question about Toshiba Satellite M45-S165 Notebook
What modern hard drive can i replace my old one with?
  • Toshiba Master
  • 3,866 Answers
You can go up to 120 GB on this on a pata hard drive otherwise you would need to go external if you want anything bigger then that.
thanks I hope this was Very Helpful for you!
Posted on Dec 13, 2009
Problems with my iHP-120 iRiver mp3 player
Good chance it is the hard drive - that's a fairly old technology. I have heard of some people having some success replacing the HD with a compact flash card on some older mp3 players, I seem to recall the connector is the same. I guess if you have a suitable CF card reader, you may be able to remove the hard drive and check it out with the reader - there are some hard drive diagnostic tools out there you can try. Gibson research's spinrite was pretty good back in the day, not sure it is still useful for more modern drives.
Dec 10, 2014 | iRiver iHP-120 MP3 Player
Xerox 7435, got from company who pulled out the hard drive, so I am missing hard drive and the OS, how can I get in going?What type of hardrive do I need?
Hi Arthur
Look at the cable that would connect to the hard drive.
The Data side is either SCSI, or ATA or SATA.
Look these up on Google and see what matches.
All modern Hard Drives are 3.5" for desktop computers or 2.5" for laptops. Visit a site such as OWC (Other World Computing) to purchase a drive.
Only Xerox would have the OS unless you know where there is an old copy.
Check out
https://www.google.com.au/?gws_rd=ssl#q=xerox+7435+specs
Sep 09, 2014 | Xerox Workcentre 7435 Color Multifunction...
Why is my quantum fireball hdd's led light flashing, bios failed to detect hdd?
Wow, you have a Quantum Fireball? I haven't heard about that hard drive model family in years, decades actually. They were last marketed back in 2001 but were most popular in the early to mid 1990s. Given the very low Mean Time Before Failure (MTBF) values of drives in that era, I am surprised that the drive has survived up to this time.
If I were to make a guess, I would say that your old IDE Fireball has gone the way of the dodo bird. Time to get something new and much more modern. IDE drives are no longer manufactured as it is an outmoded technology in favor of SATA. If you still have a machine that uses IDE, then definitely replace the machine with something much more modern and faster that will have a more spacious SATA drive.
Sep 01, 2014 | Computers & Internet
What volt adapter for WD 3200H1U-00?
Most external hard disks use a 12 volt 2 amp power supply. The modern ones are small and cheap. Be aware the power plug should be the same as the power plug on the old power supply. and the polarity also.
Jul 09, 2014 | Western Digital My Book Essential 1TB...
How difficult is it to replace a hard drive?
Replacing the hard drive is not too difficult. You will need the operating system disc to reinstall windows or you could try a free Linux (like Ubuntu) operating system.
On the bottom of the laptop there is a 2 access panels the small one is the memory and the larger is the hard drive. You just need to remove the screw and and the hard drive will be below. You just need to see what type it is by the connection. There are 2 types IDE or SATA; Ide had a wide ribbon connector and SATA has a small connector. The old hard drive will also have the type stamped on the label. You should go will a larger capacity than what was in there. For example if you have a 250GB you can add a larger 750GB or more. Make sure the power is off and remove the battery before starting the process.
If you just need more storage and the old hard drive is still working you could just buy an external usb hard drive and keep all your pictures and music on that.
Thanks for using FixYa
May 29, 2011 | Computers & Internet
My gtx 465 which was made by kfa, keeps shutting down my whole pc down, it heats up fast and then shuts down while im playing call of duty modern warfare2, I do have a great air flow in my case plus fans,...
Test your PSU or replace it if your power supply units fan is not working your PSU is faulty
One bad lead can cause a computer to continue on a cycle or to shutdown or fail to detect your hard drive
Test all leads that attach to your hard drive including electrical extensions,IDE,SATA
the leads from your ((motherboard to your hard drive)) make sure they have a secure connection and are not faulty or just replace them there probably old and faulty
make sure all leads that are attached to your drives dvd\cd 3 1/2 inch floppy have secure connections and are not faulty even the electic extensions or just replace them they could be faulty a computer needs its connections to continue its cycle and have an end so any faulty leads will end up with a computer error
hope this helps
Apr 10, 2011 | Nvidia Technology GeForce GTX 465 PCI...
Modern Warfare 2 Map packs wont load. Says "Disc
did you download Modern Warfare 2 to your hard drive?? If you have the space download your games to your hard drive cuts out lag time and errors.
Nov 08, 2010 | Microsoft Xbox 360 Hard Drive (120GB)
How do i find out if my hhd is pata or sata,etc.?
Hi, this is pretty easy,
Computers about 5 - 6 years old are usually use IDE hard drives, most modern units, are indeed Sata,but if your want a proper reassurance, just open the case and look at the cables. If you see a wide, gray cable that sticking out the hard drive, then your computer is using IDE hard drives. If they're thin (a little wider than your thumb), then you computer is using SATA hard drives. A picture of both types of cables is included below. :D Source(s): IDE Cable:http://amigakit.leamancomputing.com/cata…
SATA Cable:http://sierra-cables.com/SATA/images/SAT…
Both cables, for comparison:http://www.ackadia.com/computer/images/s…
Sep 10, 2010 | Acer Aspire 3680 Laptop
Where can I locate a Maxtor: 7245A 245MB 3.5"/SL IDE / AT
That is a *VERY* old disk-drive, not a printer.
Modern disk-drives from MAXTOR are, for example, 200GB or 300GB,
namely about 1000 times as much capacity as the 245MB disk-drive.
Try any local computer-store that sells "used" hardware.
Probably, any hard-drive *SMALLER* than 8.4GB can be substituted, and still be compatible with your computer's motherboard.
Nov 18, 2009 | Office Equipment & Supplies
Hard drive for Tower PC
Hi I have a gateway tower about 7-9 years old. could you tell me how much a 60- 80 gig harddrive will cost and where I could get such an animal? I need to run a couple of programs and I don't have enough room.
Sep 09, 2008 | Gateway GT4022 PC Desktop
Toshiba Satellite M45-S165 Notebook Logo
61 people viewed this question
Top Toshiba Computers & Internet Experts
pankaj rautela
pankaj rautela
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
