Question about Air Purifiers
Our carrier reverse cycle airconditioner is leaking inside the house after a hour of use. how can we fix this? we have cleaned the filters in the inside unit and it still leaks,it works fine as a heater but to cool we have to deal with leaking.
  • 614 Answers
Did you blow out the drain? If so pull the front off of the air handler unit. Ckean out drain pan. This drain pan had small holes on either side that run from the sode drain clean those out. Also if your coil is dirty it will pull water back and cause it to leak. Try cleaning coil and dain pan plus blow out drain. Rus
Posted on Dec 13, 2009
Irobot troubleshooting
if your Roomba is less than a week old it should be only about and hour. after about 4-7 full cleaning cycles your batter should go for about 2 and a half hours to 4 hours
May 21, 2013 | Roomba Irobot 780
I just bought the purepro 200. I ran it for about 7 hours in a normal house setting and it turned off and the cleaning light came on.I have unplugged it and tried it again. This time it went off in 10...
John, when the clean filter light came on, did you clean the filter? Or just unplugged it and tried again?
In 7 hours, the unit probably picked up a lot of dust, that's why the clean filter light came on. Try cleaning the filter( if you haven't already) and that may solve your problem. When you reinstall the filter, be sure that it is seated properly, so the the safety trigger switch is activated.
Hope this helped you to solve the problem.
Mar 23, 2011 | Montgomery Ward Pure Pro Air Purifier
How do I clean the inside of my Alpine Air? Not
If it's an XL-15 or Classic, there are four screws through the bottom that hold the main chassis in-place. But first:
1) Unplug the unit, and remove the lint filter in back.
2) You'll need to remove the power switch (carefully pry out with a screwdriver or putty knife), disconnect the spade terminals (note which wires attach to which terminals), and remove the knobs for Fan and Ozone controls.
3) Remove the four screws. As the chassis slides out the back, you'll need to disconnect the spade terminals to the fan motor as well.
Clean thoroughly, make sure everything is re-assembled with good connections in reverse-order. Be particularly careful to leave any sensors clean and connected.
If I can be of further assistance, or if you have questions about any of my response(s), please let me know before rating me.
If this solves the issue, please rate it accordingly. My goal is to earn a "FixYa" rating from everyone I help.
Thanks for using Fixya.com,
Jon
Sep 09, 2009 | Alpine Air XL-15 Air Purifier
I have the Renewaire Energy Recovery ventilator system, Model EV130, installed in my house but do not know how to set it to the proper setting. The runtime numbers go from 10 to 100 and I am not sure what...
The RenewAire system is sized per ASHRAE 62-1999, residential air exchange of .35 air changes per hour, or 8 air changes per day. You can find an operation sheet for the PTL @ www.renewaire.com, downloads, residential, controls, PTL. A chart shows a starting point of ventilation based on the square footage x 8 foot ceiling height with a run time percentage for each model. For 2250 square feet with 8 foot ceilings, the run time for an EV130 is 85%, cycling hourly.
Actual run time will vary by tightness of house, number of occupants, lifestyle (number and frequency of pollutant generating activities). Outside weather conditions should have little effect on run time percentage. I run my system @ 50% year round, when the windows are shut.
The ERV tempers humidity and temperature extremes of the ventilation air year round. It is not a substitute for heating or A/C; it does not dehumidify the house in summer (it does reject some of the incoming summer humidity content, when the net humidity is greater outside than inside). It will lower humidity of the house in winter, or whenever the net humidity outside is lower than inside.
It will ventilate the house in an energy efficient manner all year long. Based on this information, choose a setting and manage the amount of run time to achieve your best IAQ.
Apr 25, 2009 | Air Purifiers
Unit shuts off after about 4 hours of running
You can get a manual on line. Go to www.brookstone.com , select "customer service", then select "product manual archives". It will come in a printable pdf file.
Dec 02, 2008 | Brookstone Pure-Ion (506840) Air Purifier
Clean Filter Red light
I cleaned the filters as well earlier and the red filter light still blincked to clean the filters. Then I pushed the power button for about 10 seconds continously and then turned it on and the light turned off.
May 22, 2008 | Brookstone Pure-Ion UV Air Purifier
Brake pads jammed on rear cycle wheel
Hi Moon river,
Make and model of the bike pls?
May 12, 2008 | Air Purifiers
Water Filter Leaks
Since you weren't very specific where it leaks or when it started (like after a filter change) it could be tough to troubleshoot this leak.
If it is leaking at the faucet connection try tightening up where it screws onto the faucet. Depending on your strength (or lack of) you may need to use pliers to get a tight connection. Don't go crazy tight or it will crack the plastic fitting. If it still leaks remove the unit from the faucet and check the rubber washer inside where it screws onto the faucet. Make sure it's still there and is centered inside the cup and seated properly. Then reattach the unit to the faucet and tighten it well.
If it's leaking from the main body try removing the filter and reinstalling it making sure you have seated the filter properly and screwed on the cover correctly, and all the way. When it is tight the water outlet will be exactly at the bottom of the unit. Sometimes it's tricky getting it tight enough especially with wet hands.
Finally, if the leak is coming from the filter on/off selector this could be tough to fix. I would try firmly pushing and pulling the selector knob in and out several times while in both the on and off positions. This may re-seat the leaking seal. I wouldn't be too hopeful about this fix though. You may need to replace the unit if this part is leaking.
Nov 18, 2007 | PUR (FM-9500) Air Purifier
Ecoquest Breeze AT
Make sure you have the filter on the back on the right way and not reversed. On the Ecoquest Breeze you should plainly see the obvious pull tab, at the top of the back filter panel, after putting the filter back in place.
Nov 13, 2007 | Ecoquest Living Air Classic Air Purifier
Cleaning the fresh air purifier
You have cleaned the purifier. Now on the front there is a reset button next to the power button push that to reset cleaning cycle.
Oct 10, 2007 | Ecoquest Fresh Air Air Purifier
Air Purifiers Logo
138 people viewed this question
Top Air Purifiers Experts
Michael Youngman
Michael Youngman
Are you an Air Purifier Expert? Answer questions, earn points and help others
