Question about Dryers
Ceiling fan light works with wall switch, but comes on dim when I pull the chain for the fan
I have a second hand Hunter fan with no instructions. I have a black, white and red wire in the ceiling box. I connected the fans wires in this way: black/white stripe to white supply, white to red supply, and black to black supply. The light works correctly when I flip the wall switch but when I use the pull chain to turn on the fan, the light comes on dimly on the first pull, a little dimmer on the second pull, and not at all on the third pull. The model number I found on the fan is 21721.
  • Anonymous Jul 08, 2008
    Have similiar problem, but just reverse, fan turns slowly on high speed when light is off, when light is turned back on, it goes back to high speed.!! With light off fan acts as if ina strain to turn at all, when light is turned on, strain disappears and fan returns to appropriate speed!!!
  • 397 Answers
Is the fan working correctly, if it is not it could be a bad armature or field
Posted on Jan 20, 2008
Hunterfan com
If you have a remote then you can't use the dimmer switch on the wall. Put in an on/off switch.
Sep 20, 2013 | Hunter 52" Ceiling Fan With Light And...
Fan on the ceiling fan works, light does not, it is an Emerson unit wall switch only not remote control
Try pulling the chain once and then try the wall control. Is it a wall REMOTE or dual control? Do you have the number of the wall control?
Aug 31, 2013 | Hunter 52" Ceiling Fan With Light And...
Hunter fan works light broken
Check to make sure light wires are connected at light kit & remote. Otherwise it's probably a bad receiver. If there is a pull chain for the light pull it once & try the remote light button again.
Mar 10, 2013 | Hunter Ceiling Fan Light Switch Control
The remote controls the fan speed but wont dim or control the light. the unit wont work if the light switch is off so I cant use the fan at all unless the light is turned on
mcdevito75 here, Generally the Ceiling fan motor is hooked up by-passing the wall switch but still to the hot laed going to the wall switch whlie the lights are hooked up to the hot lead after the wall switch, So without the remote, Manually operate your fan and lights. First with the wall switch off the fan should work and the lights no work. Now turn the fan off with the pull chain on the fan shroud close to the ceiling. Now turn wall switch on and lights should work with wall switch and the fan should also work. if so, re-program the remote or change the batteries or even re--place the remote.
Jul 26, 2010 | Hunter Ceiling Fan Light Remote Control
Hunter 52, fan works but light no longer works with remote or chain pull
mcdevito75 here, Don"t the fan lights work off the wall switch, The chain pull should be for fan speed. Check make sure electricity is going to the fan.
Jul 19, 2010 | Hunter 52" Ceiling Fan With Light And...
I have a Hunter fan with remote. The fan or the light comes on by itself with no one around
See my post below: (Sorry, we're in the same boat)
Hunter ceiling fan with remote, have 5, 4 are seriously impaired! Lights dim to half strengh after variable time 10 seconds-30 minutes. And lights or fan turns on randomly (come home & fan on full blast), and one in which the lights won't dim (just blinks when try to dim)! Hunter "kinda" admits there is serious problem with remote but doesn't have a solution. Tells people to try changing to different code due to possible interference (pain in **** to change code on ceiling base!), was totally ineffective. Then replaced receiver in ceiling base (another total pain) in 3 fans with new ones sent Hunter, still totally useless. Hunter's suggestion, don't use the remote, just use the pull chain. If I had wanted a pull chain fan, I'd have bought a pull chain fan. TOTALLY USELESS! Moral of story: If you want a remote ceiling fan (my friend found out that all their remotes are made by the same company in Taiwan), don't buy Hunter!!!!! P.S. I found a "Kinda"- fix for the lights dimming to half strenth. After turning on the lights, wait 1 second, then dim lights slightly, they will then stay on the strength that you dim them to. - P.P.S. When I changed the receiver in the one where the lights won't dim, it "solved" that problem...Now it has the same problem as the others, lights or fan turn on randomly!
Apr 02, 2010 | Hunter 52" Ceiling Fan With Light And...
I think our house is haunted. Just installed
See my post below: (Sorry, we're in the same boat!) Hunter ceiling fan with remote, have 5, 4 are seriously impaired! Lights dim to half strengh after variable time 10 seconds-30 minutes. And lights or fan turns on randomly (come home & fan on full blast), and one in which the lights won't dim (just blinks when try to dim)! Hunter "kinda" admits there is serious problem with remote but doesn't have a solution. Tells people to try changing to different code/channel on the remote due to possible interference (pain in **** to change code on ceiling base!), was totally ineffective. Then replaced receiver in ceiling base (another total pain) in 3 fans with new ones sent Hunter, still totally useless. Hunter's suggestion, don't use the remote, just use the pull chain. If I had wanted a pull chain fan, I'd have bought a pull chain fan. TOTALLY USELESS! Moral of story: If you want a remote ceiling fan (my friend found out that all their remotes are made by the same company in Taiwan), don't buy Hunter!!!!!
- P.S. I found a "Kinda"- fix for the lights dimming to half strenth. After turning on the lights, wait 1 second, then dim lights slightly, they will then stay on the strength that you dim them to. - P.P.S. When I changed the receiver in the one where the lights won't dim, it "solved" that problem...Now it has the same problem as the others, lights or fan turn on randomly!
Mar 20, 2010 | Hunter 52" Ceiling Fan With Light And...
I have a Hunter ceiling fan with light kit. The controls for the fan and light are on the wall. It is a Hunter dimmer and 3 speed control switch. The fan works fine and the lights do not come on. I have...
Usually you have to press the light switch 3 times and hold to get dim effect adjustments, it is often radio transmitted in some newer models, if the pull switch is bad replace it anyways it could be dangerous if let alone!
Aug 23, 2009 | Hunter (25417) Ceiling Fan
Hunter fan will not operate
Hello
Did somebody pull one of the chains hanging from the fan to the off position? Could be a bad switch connected to the chain? Bad motor? Bad switch on wall? Take fan down and make sure there is power coming into the fan and at the switch.
John
Aug 17, 2009 | Hunter 21564 The Brunswick Bronze Ceiling...
Dryers Logo
740 people viewed this question
Top Dryers Experts
Marvin
Marvin
