Question about Crosley Dryers
I have a Crosley Electric Dryer Model BYCD3722WI. You can hear the timer, but it will not get hot. What could be the problem?
  • 49 Answers
The heating element inside your dryer could have malfunctioned, it may need to be replaced.
Posted on Dec 13, 2009
My crosley electric dryer won't start, model cde4205ayj
Many things can cause this problem . Main timer , door switch,over heat thermal fuse , broken belt ,main power breaker
Nov 04, 2015 | Crosley Dryers
Crosley model ced5563rq, checked continuty on limiter fuse, door switch, off/on switch, checked heating coil, hi/low thermostats, circuit breakers and voltage. all seem to be ok. the dryer will not start....
What you still the actul circuits on the timer,the thing that can make a dryer not start are things you hav ealready checked plus also the timer&motor,and perhaps a belt switch i could not find your actual model number to see if it has a belt switch but lots of brand use a switch that cuts motor curcuit when belt is broke, but as i said it also could be timer or motor
GENE
Aug 17, 2011 | Crosley Dryers
Crosley dryer model # cde22b6v. Timer switch works but dryer will not turn or heat. I checked connections. Belt is good. Motor turns free. What do you think I need to check?
door switch, bypass by taping the wires together. here are some other things to check:
http://www.partselect.com/dryer+dryer-wont-start+repair.htm
Mar 30, 2011 | Crosley CDE6000 Electric Dryer
Timer runs dryer gets hot but drum does not come on to spin clothes
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor going bad...
Here are a couple of tips that I wrote will help you to figure out why your dryer will not run...
Dryer Repair - The
Dryer is not Turning
Dryer Repair - The
heatman101
Dec 13, 2010 | Crosley CDE6000 Electric Dryer
My dryer won't turn on. It's getting power. I tested the circuit. I can also hear the timer ticking when it's plugged in.
Your problem sounds like the door switch. You should hear a click from the switch when you open and close the door. If you don't you need to replace the switch. Here is a link to the part.
Nov 26, 2010 | Crosley CEDC392JQ Electric Portable Dryer
Dryer won't turn on but i can hear the timer tickin
The most common causes are the belt breaking or jumping off, or the motor goingbad...
Here are a couple of tips that I wrote will help you to figure out why yourdryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Nov 03, 2010 | Crosley CDE6000 Electric Dryer
Dryer will not turn on, i can hear the timer counting down
A dryer can not start for many reasons...
This tip that I wrote will help you to figure out what is happening...
http://www.fixya.com/support/r4460438-dryer_repair_dryer_will_not_start
heatman101
Apr 06, 2010 | Crosley CDE6000 Electric Dryer
My dryer is not getting hot
It could be the element,
the safety limits,
A burnt wire to the element, bad breaker or receptacle, or even the timer could have a burnrt contact in it. Here are some repair pictures:
General Electric/Hotpoint/RCA dryer repair pix Kenmore/Estate/Roper/Whirlpool repair pix Frigidaire/Westinghouse/Gibson/Kelvinator repair pix Maytag/Admiral/Crosley/MonkeyWards dryer repair pix
Dec 30, 2009 | Kenmore Dryers
My Crosley dryer not drying
You will have to ensure the tub belt is not broken or off the motor pulley. Also, you may have a bad push to start switch or door closed switch. Open door and manual hold in door switch and have someone to push the start button if there is any sound or attempt to start these switchs are most likely good and your problem is with the belt. Hope this helps God Bless
Sep 18, 2009 | Crosley CDE6000 Electric Dryer
Dryers Logo
69 people viewed this question
Top Crosley Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Craig Butler
Craig Butler
Are you a Crosley Dryer Expert? Answer questions, earn points and help others
