Question about Whirlpool 24 in. DU900PCD Built-in Dishwasher
Whirlpool DU900PCDQ6 Dishwasher Will Not Fill With Water
I have a Whirlpool "Quiet Wash" built in dishwasher, model DU900PCDQ6, that doesn't fill with water. I have no experience working on appliances. I attempted to pull the dishwasher out of its space in the kitchen counter, was surprised to find it wrapped in insulation, and decided I have absolutely no idea what I'm doing and should ask an expert before I damage it further or hurt myself. What should I do to figure out what the problem is? Can I pull it all the way out of the wall without breaking anything? It's about halfway out of the "hole" in the counter at the moment.
  • Whirlpool Master
  • 3,740 Answers
Wow a 13 Dec 2009 post. I just started in Jan 2010 and am going thru questions.
Hi and welcome to FixYa. I am Kelly.
Before you go taking it out from under the counter... (at this point thre really is not a need to do so) lets back up a bit.
There are 2 main suspects at this point.
1. The internal Float and Switch assy sticking / inoperative
FLOAT (Item32 of link)
http://www.appliancepartspros.com/partsearch/model.aspx?model_id=262340&diagram_id=104009#d104009
The float should move freely up and down. If the stem gets coated with debris it can stick in the up position. Make sure the float moves up and down while listening for an audible switch "click" as it nears the top position and just as you begin to lower it again.
The Float Switch (Item 30 of above link)
This is the switch that you should hear as you move the float up and down. No click = no fill
and
2. The water valve assy not functioning correctly
Water valve (Item 16 of above link)
The failures of a water valve are:
a. An open coil
b. A clogged diaphram
c. A sticking internal needle valve that is actuated by the coil
I am pretty sure that it is either a stuck float or a bad water inlet valve.
Thanks for using FixYa.
Kelly
Posted on Mar 23, 2010
Whirlpool dishwasher wont wash
if the bottom tub is filling with water but not washing the issues is with the wash motor, some of this model use a start capacitor that can fail, if it has a capacitor on the side of the motor it may have failed but are difficult to diagnose but are cheap to replace so worth trying, if this doesn't help or if it doesn't have a capacitor then the fault is with the wash motor.
Mar 08, 2012 | Whirlpool Gold 24 in. Built-In Dishwasher...
Whirlpool gu 980scggo quiet partner dishwasher leaking out water feed fitting on left side
probily just needs tightened if that dont work its just the rubber washer in the fill line just turn off water unhook like from the dishwasher side look inside the line [ where the threds are] you should find a rubber washer and take to hardwear store and replace... good luck. i hope this helps
Aug 13, 2011 | Whirlpool Gold 24 in. Built-In Dishwasher...
It will start and fill with water, but doesn't
1)check door safety switch. 2)check wash pump working.
Jun 03, 2010 | Whirlpool GU2400XTP Built-in Dishwasher
My 6 year old Whirlpool dishwasher is loud
This is a bad wash pump. Looking at about $175 for just the sump assembly. You could do it yourself, but unit would need to be uninstalled.
May 28, 2010 | Whirlpool Gold 24 in. Built-In Dishwasher...
Whirlpool DU1055XTP dishwasher fills with water but won't wash.
Can you be more specific? Does the dishwasher fill and then overflow?
Apr 11, 2009 | Whirlpool 24 in. DU1055XTP Built-in...
Whirlpool Quiet Partner II not washing or sensing.
I have a whirlpool quiet partner II and for some reason it does not drain the water out any more and I cannot figure out why....people say that it is the filter but that is unbelievably hard to get to and I cannot find any instructions online or paper work that tells how to break it down. If anyone has any insight please let me know
Nov 16, 2008 | Whirlpool GU2400XTP Built-in Dishwasher
Whirlpool 24 in. DU900PCD Built-in Dishwasher Logo
300 people viewed this question
Top Whirlpool Dishwashers Experts
Oloyede Monsuru
Mike
Are you a Whirlpool Dishwasher Expert? Answer questions, earn points and help others
