Question about Kenmore 3.2 cu. ft. Plus Top Load Washer
Wont spin out and leaking out the back, have tried to push the switch down but only makes a noise for about 10 sec
  • Kenmore Master
  • 8,220 Answers
How do i reprogram my key on peugeot 307 hdi 2001
Many cars have a different process to enabling passive systems, some require turn the key on and off 3 times then hold it in the on position while holding down the remote, or you may hear a chirp to start the calibration process, the safest way of course to marry the unit to the vehicle is to scoot down to the Peugeot dealer and get them to do the program, it may cost, but they also have to make sure everything works correctly too, so they will stand by the service they provide you. hope this helps, happy holidays.
Nov 29, 2014 | 2001 Peugeot 307
Maytag dependable care plus will fill up with water but wont start cycle
sounds like you have a bad lid switch part 3949247 and it's around 50 dollars.open the lid,look at the right side,you'll see a hole,stick a screw driver into the hole and push down easy with the machine set on spin,if it doesn't spin and when you push up and down on the switch with the screw driver the lid switch is bad.watch video
http://www.youtube.com/watch?v=V5aW9WkTFhE
Mar 29, 2013 | Whirlpool Ultimate Care II LSQ9564J Top...
Wont turn on pressed the reset when it froze and now it wont go back on
Press the Power ON/OFF slide button.
To power ON, push Slide UP & hold for 5 sec's
To power OFF, push Slide UP & hold for 5 sec's
If no go,
Use the Stylus and push into Reset hole, at bottom of device.
(not on back side, but at the bottom, where there is a single hole.
Press and hold for a second or two, or until it turns off/on.
Pushing Slide DOWN, put's it HOLD mode (make sure the slide
switch is Not in the Down position) is probably in Hold mode?
I've had this problem before and finally realized that I was putting it in
the hold mode every time, by pushing the Slide Power button, down.
Instead of UP.
May 24, 2011 | Mach Speed T3000 MP3 Player
Will not spin, and drain water
could be a couple things
first check the switch on the door lid. sometimes it is not being pushed down enough. Try pushing with a screwdriver, lightly. You should hear a clicking sound as it engages.
If it clicks but still no spin. You will need to access the switch by lifting the lid or from the back. unplug the washer then unplug the switch and use an ohm meter to check that the switch is conntecing when being pressed down. if not replace the switch.
Another quick test is to jump the two wires together and if it spins then the switch is bad and needs to be replaced.
If you hear a humming noise then something under the unit is the problem. depending on make and model it could be a belt for the old ones. could be a rubber grommet above transmission on the direct drive styles.
Start with those and see what you find.
Mar 03, 2011 | Kenmore Washing Machines
Washer makes noise but, wont drain or spin
Check the lid switch (the part that gets pushed down when you close the lid). Try pushing it down with something. If you do not hear it make a CLICK sound, then it needs to be replaced.
Note: ALWAYS unplug appliances before attempting to make any repairs!!
Mar 14, 2009 | Kenmore Washing Machines
Riello oil burner RDB with red plastic cover at the front wont ignite. I've tried bleeding the valve. The motor seems to make an electrical humming noise for about 12 secs, then the system attempts to...
The motor should spin when the boiler is switched on. One end of the motor spins the fan the other end works the pump. The control box then starts the transformer that starts a spark. The control box then opens up the oil. The boiler should then light if any of the above or the boiler does not light, the boiler will go to lockout.
From what you say the motor is not spinning, thus it could be the motor or more like the pump.
YOU SHOULD NOT PLAY WITHE THE PUMP
If the wrong setting is made it could 1 burn out the back of your boiler 2 go to soot and the boilers in an hour would be filled up and become a fire risk. 3 not start at all if the setting is too low it is a fine line to get it to work and needs the right tools.
regards
oil eng.
Oct 26, 2008 | Heating & Cooling
Tray wont open
well, my bros does that as well. and i just push on the disc tray a little, like push it up if the console is laying down.. it also could mean the motor that pushes the disc tray is off or disfunctional.
Aug 04, 2008 | Microsoft Xbox 360 Console
Admiral Washing Machine not spinning
y Admiral washing Machine modle # lnc6760b71 will fill with water and agitate. But when it come time for the spin cycle it wont spin. I can hear the motor making noise. and now stop and it does not work, does not smell to burned What should I do??
Jan 06, 2008 | Admiral AW22 Top Load Washer
Motor wont spin
whats makes the noise on spin if motor not turning at all.. i kinda confused... I Would check lid switch and see if maybe that might be the problem.. havnt had a lot of experince with hover but most washers have lid switchs to prevent spinning when lida opened
Sep 02, 2007 | Hoover AAA140 Front Load Washer
Kenmore 3.2 cu. ft. Plus Top Load Washer Logo
Sal De
fordexpert
Jim Goldsmith
Jim Goldsmith
