Question about GE 24 in. Profile PDW7800 Built-in Dishwasher
My garbage disposal works but the water in the disposal side of the sink still wont drain. The reset button is pushed in. What can I do?
  • 95 Answers
Put a pail under the trap and empty and clean it check for leaks after reinstalling Does the disposal make noise like it is running ?
Posted on Dec 13, 2009
Why does kitchen sink drain water from drain side to garbage disposal side
The two drains are connected, but below the disposal. Likely if it's not draining down, you still have a clog, and the person the "cleared" the drain didn't.
Sep 03, 2014 | Garbage Disposals
Tip
Garbage Disposal Leak from bottom of motor
If you have a garbage disposal and you find that it is leaking then you need to first of all figure out where exactly the water is coming from. The reason is that depending on where it is leaking from will determine whether it is easily fixable or if it would be better to just replace the entire garbage disposal.
With this is mind the best way to find the leak is to put the plug in place and fill the sink with water. Then place a food coloring or non-toxic dye into the water. Red often is a very easy color to spot under your sink. Then let the water down the sink with the disposal running. If the water runs down the side of the garbage disposal then you have a leak at the seal where the garbage disposal hooks up to the sink. This can easily be fixed by removing the garbage disposal, cleaning the old plumbers putty off of the ring and sink bottom, and then reinstalling the garbage disposal.
If you do not see any water coming down the sides, but it comes out the drain pipe, then the drain may be clogged and/or the seals for the drain piping are bad. The seals can easily be tightened. They may have come loose from the vibration of the motor or just the expansion and contraction that occurs from hot and cold water going down the drain lines. If the drain lines are clogged a garbage disposal safe drain cleaner can be used or the drain can be taken apart, cleaned and snaked.
If you have the dreaded water coming out of the bottom of the garbage disposal then you have the worst problem. The internal seals that are to prevent the water coming into the motor where the shaft goes through to the actual grinding chamber have deteriorated to the point where they no longer keep the water from coming into the motor. The water will make its way down through the motor and run out the weep hole or the reset button.
These seals are replaceable, but a new motor is needed for a complete fix on many garbage disposals. Because of this, many times the parts to repair this leak will be at least 75% the cost of a new garbage disposal. This makes repairing your garbage disposal, not a very good option. Replacing the whole unit is often the best way to go to make sure you have a fix that will last for a longer period of time.
That should cover all of the potential ways that your garbage disposal can leak. Hopefully you are able to pinpoint the leak and make the correct call to fix your leaking garbage disposal.
on Sep 23, 2010 | Kitchen Appliances - Others
When dishwasher is emptying it is backing into sink
there is probably nothing wrong with Dishwasher itself.
Your Sink drain is stopped up or your Garbage disposal is clogged.
usually, dishwasher drain is connected to the Garbage Disposal, but if the dishwasher empties the water into the Garbage disposal, if its clogged then water will come out of the sink. Same if sink is clogged between sink and sewer.
If you fill up your sink and then water drains away, then you know your sink itself is not the problem. If its only the Garbage disposal side that does not drain, its the garbage disposal that is clogged.
Dec 22, 2013 | Dishwashers
Is there an override button is not clearing garbage
If disposal is not running, then push red reset button located bottom of disposal.
If disposal is clogged, Clean out drain line under sink, and bottom of disposal under cutter blade.
Copy following link for clogged disposal.
http://waterheatertimer.org/How-to-repair-and-install-Garbage-disposal.html
If you need further help, I’m available over the phone at https://www.6ya.com/expert/gene_9f0ef4df2f9897e7
Oct 19, 2012 | Badger 1 Insinkerator 76039h 1/3 Hp Feed...
My badger 5xp is leaking drain water from the red reset button?
You have to replace the disposal.
Disposals are sealed units, and cannot be repaired once they rust out.
If water is coming out red reset button, then that is very common point for water to exit the steel canister.
The motor is getting wet.
The electrical wires are getting wet.
This is a shock hazard, and sink and disposal should NOT be touched when switch is ON.
Oct 06, 2012 | Ace Hardware InSinkErator Badger 5, 1/2 HP...
Will not drain...but is turning....i tried to reset by pushing the red button and did nothing...i took the L wrench and turned it from the bottom and still nothing...sink is full of water too..what can i...
1) If disposal will not drain: Clean the tubular drain under sink.
Remove 2 nuts on p-trap, and trap falls loose, then remove tailpiece on side of disposal, hand rag over opening to direct water downward, turn on water, turn on disposal and see if disposal empties, clean p-trap, and then reassemble tubular drain.
2) If disposal will not drain and will not run: Clean tubular drain, check for power to disposal.
If disposal is getting power and will not run, and reset button is not tripped out, and cutter disk rotates freely, then disposal is bad.
I wrote ez disposal replacement steps that include tips for tubular drain.
http://www.fixya.com/support/r7929008-replace_garbage_disposal
Aug 21, 2011 | Ace Hardware InSinkErator Badger 5, 1/2 HP...
Making a metal grinding sound when turns on but dont feel any forks or spoons in it
Garbage disposals can get noisy and sound like they're eating spoons instead of banana peel.
You can put vacuum hose in sink opening and see if something is in there.
As long as disposal disk rotates freely, and disposal is not shaking around and causing pipes to leak, then you can use it until it dies.
Otherwise, the bearing is probably rusted, or something is loose. Disposals rust out and eventually freeze, or the motor slows down and overheats, or they rust a hole and water leaks under sink.
Garbage disposal mechanism cannot be disassembled for repairs.
Here are basic disposal parts:
1) Sink basket that connects to sink and is held with 3 screws from below.
2) Disposal body which connects to sink basket using metal ring.
3) Rubber washer between disposal and sink basket.
4) Dishwasher connects to upper part of disposal with a hose.
5) Electric wire coming from disposal switch connects to disposal near red reset button.
6) Tubular drain pipe connects to side of disposal
I wrote tips for replacing disposals that you can use when disposal gives out.
When I worked apartment maintenance, we replaced disposal with same brand and size disposal.
That way we didn't have to change out sink basket or move pipes around under the sink.
How to: Disconnect 2 nuts on p-trap and trap falls loose.
Rotate steel connector disk that holds disposal to sink basket, and disposal comes off.
Before installing new disposal.
Attach electric wire to new disposal, and push in reset button.
Attach dishwasher tube to new disposal. Knock out plug inside dishwasher opening.
Lift new disposal up into place, and attach to old sink basket.
There is a rubber washer between disposal and sink basket, Use new washer.
Attachment ring catches at three points, all three have to connect.
You can use bottle jack to lift disposal if you have problem.
Re-assemble tubular pipe.
If this is your home, you want new sink basket that comes with new disposal because it looks shiny and new.
Buy a tub of plumbers putty also.
Remove old sink basket and clean sink opening.
Put finger-size roll of plumbers putty around sink opening, and then push new strainer basket into plumbers putty.
Tighten basket from below, wipe away excess putty around sink opening.
Install new disposal as described above.
Tips for tubular pipes:
When taking apart tubular pipes, start at p-trap and take apart as few pieces as needed to do job.
On image above, loosen both upper and lower nuts, trap falls loose, and then work on disposal.
Any tubular drain pipe that gets moved while working under sink needs to be disassembled, cleaned and re-assembled.
Metal pipes have rubber washer >> always use new rubber washers.
Plastic pipes have plastic washers > plastic washers can be cleaned and re-used.
Plastic washers have flat side that goes toward nut, tapered side away from nut.
When reassembling tubular pipe, we use rectorseal on washers and joints.
Slap a good amount on washer just before pushing washer in place and attaching nut.
Rectorseal will ensure tubular drain pipes won't leak.
Add a comment for more free help.
Also take advantage of fixyas phone service.
For a price, fixya expert speaks with you over phone while you work on disposal.
Jan 08, 2011 | Ace Hardware InSinkErator Badger 5, 1/2 HP...
I put half a small lemon down the garbage disposal. The disposal kept working fine with the water running, but then it violently threw out water and food particles. I stopped the disposal immediately, the...
Sounds like a clog at or beyond the P trap of the sinks. With water coming back into the sinks, it has to be part of the drain line that is common to both sinks. If you try and unclog the sink, work on the side that does NOT have the garbage disposal in it. A small hand snake for sinks might do the job. You could also try a plunger on either side, but when you do, put a wet rag over the other drain so you are not just pushing air back and forth. Work on one side with the plunger while holding the wet towel down tight over the other drain. Sounds like a clog that was there prior to you putting the lemon in the GD.
Oct 02, 2010 | Ace Hardware InSinkErator Badger 5, 1/2 HP...
My waste disposal unit wont turn on
Theres a reset button on the side of the thing.  Also check the breaker box to see if the switch got flipped.
Nov 19, 2009 | Buck In-Sink-Erator BADGER 5XP BADGERVEXP...
Dble sink, one with the garbage disp. won't drain standing water
It's a drain clog within the disposal. Try a drain cleaner, if no luck, you will likely need to replace it.
Feb 18, 2009 | GE 24 in. Profile PDW7800 Built-in...
GE 24 in. Profile PDW7800 Built-in Dishwasher Logo
103 people viewed this question
Top GE Dishwashers Experts
Mike
Oloyede Monsuru
Are you a GE Dishwasher Expert? Answer questions, earn points and help others
