Question about Garden
Having trouble tightening the conrod to the crank does it go in a particular way (conrod)
Steering conrod
what do you call a steering conrod
conrods connect the piston to the crank shaft
provide more information as to make , model , year and type of equipment and exactly what that part does
Jun 04, 2017 | Cars & Trucks
Is YZ 125 Clutch hub nut left or right hand thread
I don't Know, but the nut will be set to tighten when the crank turns. So just check which way the crank rotates while running and loosen in the Same direction.
Feb 12, 2012 | 2003 Yamaha YZ 125
How fit a new conrod kit in to the crank shaft of a 2008 honda crf250
hi, the con rod kit is a press fit and requires the crankshaft removal, presing apart re fiting the new conrod and then it will need to be ballanced, specalist job,
Dec 16, 2010 | Honda CRF 250 R Motorcycles
I hear a knocking sound everytime I start my 96 Ford 150. Also, its getting louder and louder each day.
hi this sounds like the big ends are on there way out, these are the parts that connect the piston conrods to the engine crank, when the bearing wear this causes a gap between the conrod connection to the crank and that will give you the knocking noise, the low oil pressure is also an affect of this problem as the pressure is reduced as the engine is running, there are 2 ways to cure this both unfortunatley are expensive, first, complete engine change, which would be better to do, or a repair or replacement of the conrod bearings, dependent on how much they have warn or even how much the crank has warn if they are really bad then it would be a replacement of all the parts...hope this helps please vote thanks
Jul 13, 2010 | 1996 Ford F150 Regular Cab
My car is showing a red light for 'oil'. However there is enough oil. There is also a 'knock' sound whenever the car travels from 100km. Whet could this could be and what is the solution? Thanks.
Jul 13, 2010 | 1994 Mazda 323
Conrod bearings need to be replaced in the engine that is 3y engine model for hilux and i want to know whether any adjustments needs to be done after installing the bearings
If the bearings need replacing the crankshaft will need grinding. After the crank has been ground you will have to buy suitable main and conrod bearings EG: 10thou undersize.
After fitting new bearings to the reground crank no adjustment is necessary.
Jul 01, 2009 | 1987 Toyota Pickup
Internationl 345 v8 torque settings
Head bolt torque: 90-100 ft lbs., to be reached in 3 equal tightening steps, below is the sequence:
9 3 1 6 8
Front of vehicle
7 5 2 4 10
Main bearing cap torque: 75-85 ft lbs.
Rod bearing cap torque: 45-55 ft lbs.
Looks like u've been busy, and will be for a while. Good Luck!
Nov 15, 2008 | 1984 Dodge D150
G200 tourqe setting
If it's the 1.0 litre conrod is 2.5 -2.9 kg-m crank cap 5.4 -6.6 kg-m
if it's the four cylinder conrod is 3.5 -4.5 kg-m crank is 4.5 -5.5 kg-m
Sep 16, 2008 | 1992 Daihatsu Charade
Garden Logo
27 people viewed this question
Top Garden Experts
roeb
john h
Marvin
Marvin
