Question about Harman Kardon SoundSticks II Computer Speakers
Connecting Harman Kardon Sound Sticks to IMac remotely
I have Harman Kardon SoundSticks II which are connected to my IMac remotely (via airport). However, I can only listen to them when using ITunes.
I believe I have to connect change my computer's sound output device in "System Preferences - Sound" option but the output device corresponding to the 'sound sticks' is not listed there.
Is there a way of registering the 'sound sticks' in the system preferences without pluging them directly to the computer?
Thanking you in anticipation
Claude Changing your computer’s sound output device
Installed software called Airfoil.
Posted on Dec 14, 2009
SOURCE:
Hello
It seems that the power supply section of your speaker systen has the fault. Check the fuse inside it. If it found blown out, never replace an other fuse in place. Check the power supply circuit board for any short circuited components in it, before replacing an other fuse.
Mar 21, 2012 | Harman Kardon SoundSticks II Computer...
My harman kardon soundsticks base light flickers, no sound
Ok this needs careful observation to determine this type of problem
Please unplug these speakers and plug it into an mp3 player and write back to me if the speakers work ok? I'll tell you more from there
Mar 15, 2010 | Harman Kardon SoundSticks II Computer...
I have just bought some Harman Kardon SoundSticks II. When I plug them into my iPhone, they are perfect, however, I want to use them with an airport express and as soon as I plug them in I get a loud...
this is from Harman support site First you need to determine where the problem is. Try connecting your speakers to another audio source such as a portable CD player. If you receive the proper sonic results, this will tell you that the problem is in the computer and/or soundcard setup. In this case there are many things to try. 1. Interference may be causing the distortion. Please check all surrounding electrical objects and place the speakers away from the problem object. 2. Ensure that the speaker input jack is pushed all the way into the appropriate jack. Check all the connections and secure them. 3. The volume on your soundcard may be set too high. Decrease the volume in your volume control panel. Also check the volume and tone controls on the speaker. 4. Sound card or audio source material may cause a problem. *note* the quality of the audio source is also a factor (i.e. bad recording). The compatibility of your CD/DVD rom drive, soundcard and software will contribute to the quality of your sound.
Good luck
Nov 03, 2009 | Harman Kardon SoundSticks II Computer...
No sound from sound sticks ... they're almost new
Never mind... I found the USB Output in the "sound" icon on my control panel... one click and sound came a blazin'
Mar 09, 2009 | Harman Kardon SoundSticks Computer...
Harman Kardon Soundsticks II left speaker
Hi, Kazim
Firts things First:
1) check connector for 2 way sound. you can use a headphone for this.
2) you also buy Ipod dock sound speakers, there is Ihome speakers, great ones, for less than 25.00 dollars.
3) you have to see balance on those speakers.
good luck
Jan 21, 2008 | Harman Kardon SoundSticks II Computer...
Harman Kardon SoundSticks II Computer Speakers Logo
602 people viewed this question
Top Harman Kardon Audio Players & Recorders Experts
Don Hart
 Grubhead
Grubhead
Are you a Harman Kardon Audio Player and Recorder Expert? Answer questions, earn points and help others
