Question about Lexmark X4270 All-In-One InkJet Printer
I have Lemark X4270 Although I have already set the black ink injet into the printer but I still get message that "the black ink missing " >. However printer works very good . How can I clear the message ? the level check in printer show up the black ink missing .What is wrong in the printer ? PL help me thanks very much
What had
Posted on Dec 14, 2009
Lexmark X4270 gives an error message...black cartridge missing. It is not missing. what is the problem
Make sure you are using genuine Lexmark black cartridge. Lexmark does not recommend the use of refilled, re-manufactured or clone cartridges. You might not get the print quality you expect from ink that is specially formulated by Lexmark.
Try to reinsert your black cartridge and make sure it is properly seated in the cartridge carrier. If error comes back up right after placing it in the printer, then it could be a faulty cartridge. Try to replace it with a new genuine Lexmark cartridge. If you are already using a genuine Lexmark cartridge, please contact Lexmark Technical Support Center for additional assistance.
Dec 02, 2011 | Lexmark X4270 All-In-One InkJet Printer
I have error 1200 on my lexmark x4270 fax machine after installing new black cartridge.
The 1200 error code indicates that the cartridge carrier has stalled. It could be due to the new black cartridge installed in the printer. Make sure you are using the correct version of black cartridge for your model and it's properly inserted in the cartridge carrier.
To remedy the problem, try to remove the black cartridge from the carrier > close the cover > unplug and re-plug the printer into the power source to reset it > when the printer turns on, re-insert the new black cartridge > check for any errors. If problem continues, try to insert a different known working black cartridge to determine if the new one is faulty.
For further troubleshooting, you may also refer to this article found in the Lexmark website: 1200 Error Message on a Lexmark X4250/X4270/F4270 All-In-One.
Jul 12, 2011 | Lexmark X4270 All-In-One InkJet Printer
I installed both a color and black cartridege but its telling me black cartridge is missing. I removed tape from both catridges and they are both placed in correct carrier.
It could be that your black cartridge needs cleaning. On your printer operator panel, press Options -> Maintenance -> Clean Cartridges. Your printer will then print a test page forcing ink through your cartridge nozzles. Try to print your document again to check if black cartridge is working now. If not, you could try to insert a different known working cartridge to determine if the other is faulty.
Apr 04, 2011 | Lexmark X4270 All-In-One InkJet Printer
Color ink cartridge
Well due to some problem in cartridge you would be facing this problem.however you can do try this.
Please clean your cartridge once again with some spirit.
Fix it well in the printer afterward.
Than use normal paper and print in color.
If than also it does not work that means the bar-code of the cartridge has problem in it so the printer is unable to read that code, so for that you need to change the whole cartridge.
Or if your printer had valid in warranty period and it still in that period just give it to a service center.
If you still had any confusion regarding the same problem or nay other please do reply.
Naiven.
May 31, 2010 | Lexmark X4270 All-In-One InkJet Printer
Missing Black Cartridge
hi..try these steps
1. clean the cartridge contacts in the printer..
2.unplug power adaptor(black box) from the bac of printer,,press and hold stop/clear button..plug the adaptor back in...display says clearing NVRAM,,,,after this printer would turn off and turn on automatically..reenter the intial set up details like language,country....
3.insert black cartridge...still same msg..printer is defective...call techsupport..your printer would be replaced if in warranty.
good luck
Jan 25, 2009 | Lexmark X4270 All-In-One InkJet Printer
I have a Lexmark x4270 printer and for two years no problems. I replaced my color and black cartridges and now I have a message that says the color cartridge is missing. This is stopping my printer from...
the printer cartridge might be loosed, remove this again and re-install one more time and do the ink calibration in order for your printer ot recognize the prensence of a new ink, the restart your printer again
Nov 27, 2008 | Office Equipment & Supplies
Lexmark all in one 4270 won't print in black
I know your problem. I just put in new cartridges and it will print the test page, but nothing else. Did you get an answer
Sep 12, 2008 | Lexmark X4270 All-In-One InkJet Printer
Error message 1203 on Lemark X4270
Does your unit have a printhead cleaning manager. Do this a few times. Check to see if you have to reset ink levels too.
Dec 19, 2007 | Lexmark X4270 All-In-One InkJet Printer
Black ink cartidge
If a black cartridge will not print, with no error messages, it is probably th printhead. Clean it with proper cleaning solution. Refilled ones if done yourself or by someone else, can also have air bubbles, Try blowing down refill hole with tissue under the cartridge to stop ink spills. Also, if you press a folder non scented wipe under the cartridge firmly, you should get a solid little black line or impression. This will tell you if the ink is getting down ok. Try reprinting.
Oct 13, 2007 | Lexmark X4270 All-In-One InkJet Printer
Lexmark X4270 All-In-One InkJet Printer Logo
44 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
mukhtar21 shaikh
mukhtar21 shaikh
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
